I also thought it was shmutz.
S
S
Finally followed all the good advice and did complete, bootable USB, with persistance, with successful build of Piaware on x86 PC. But what now? I donât know bash commands to see if Dmp1090-mutability is running? Assuming it is, do I need to unclaimed my Pi version in order to see the PC version? I created a new FA user thinking that user could âclaimâ the PC version. But no, even when I use the âclaim my deviceâ link, there is no device to claim. So, back to the beginning of this post. What next?
What is the output of following command?
sudo systemctl status piaware
This command will output the feeder-id currently in use as guest (unclaimed).
sudo piaware-config -show feeder-id
When claiming, the computer running Piaware, and the computer from which you are claiming should be on the same LAN (Local Area Network)
I have rebooted the PC today:
pi@raspberrypi:~ $ sudo systemctl status piaware
Unit piaware.service could not be found.
pi@raspberrypi:~ $ sudo piaware-config -show feeder-id
sudo: piaware-config: command not found
Piaware is not installed or not configured.
How you installed it. Please give link to post or web page where this method is documented.
3rd question: everthing on same home wifi
I thought it was you in message that gave me 3 commands to test that dmp1090_mutability was installed and running. Perhaps not you. It included a bash command that âwill show me the data page for my adsb data.â Didnât work.
Dmp1090_mutability was installed and running yesterday. Did I loose it with the reboot. I was running a âpersistanceâ system when I got it all loaded.
There are 2 independent pieces of software, and BOTH are required to feed Flightaware:
The receiver-decoder software, i.e. dump1090-fa OR dump1090-mutability.
Piaware data feeder.
It seems you have installed dump1090-mutability, but did NOT install Piaware data feeder.
Piaware data feeder
sudo apt-cache policy piaware
Dump1090-mutability
sudo apt-cache policy dump1090-mutability
Piaware data feeder
Dump1090-mutability
sudo systemctl status dump1090-mutability
As a side-noteâŚ
I was running VirtualBox 5.0.x and the rtl-sdr feed to dump1090-fa would die almost immediately.
Upgraded to virtualbox 6.0.0 and poof. Seems to be running nice and stable now.
(just in case anyone wonders.)
Cheers,
-Ben
To summerize what I have done uptill now:
Clicked âInstallâ icon on Desktop, and loaded modules âdevx.sfsâ and âsources.sfsâ
Downloaded and installed package âdpkg-dev_1.18.4ubuntu1.5_all.debâ from this Web Page:
1.18.4ubuntu1.5 : dpkg-dev : i386 : Xenial (16.04) : Ubuntu
Used PPM and installed following packages:
(a) âgit-hub_0.9.0-2â
(b) âdebhelper_9.20160115ubuntu3â
(c ) âbuild-essential_12.1ubuntu2â
(d) âdh-systemd_1.29ubuntu4â
Downloaded & installed .deb package âlibrtlsdr-devâ (dependency for dump1090, but not available in PPM) from following web page:
0.5.3-5 : librtlsdr-dev : i386 : Xenial (16.04) : Ubuntu
Downloaded & installed .deb package âlibncurses5-devâ (dependency for dump1090, but not available in PPM) from following web page:
6.0+20160213-1ubuntu1 : libncurses5-dev : i386 : Xenial (16.04) : Ubuntu
root# dpkg-buildpackage -b
dpkg-buildpackage: source package dump1090-fa
dpkg-buildpackage: source version 3.6.3
dpkg-buildpackage: source distribution stable
dpkg-buildpackage: source changed by Oliver Jowett <oliver@mutability.co.uk>
dpkg-buildpackage: host architecture i386
dpkg-source --before-build dump1090
dpkg-checkbuilddeps: error: cannot open /var/lib/dpkg/status: No such file or directory
dpkg-buildpackage: warning: build dependencies/conflicts unsatisfied; aborting
dpkg-buildpackage: warning: (Use -d flag to override.)
7. Created missing file
root# touch /var/lib/dpkg/status
Strange that found dependency problem althoug I have installed these dependencies as listed above.
dpkg-checkbuilddeps: error: Unmet build dependencies: debhelper (>= 9) librtlsdr-dev libusb-1.0-0-dev pkg-config dh-systemd libncurses5-dev
Went all the way OK , but when almost at the end, got stuck
root# dpkg-buildpackage -b -d
debian/rules clean
dh clean --with=systemd
dh_testdir
dh_auto_clean
make -j1 clean
make[1]: Entering directory '/root/dump1090'
rm -f *.o compat/clock_gettime/*.o compat/clock_nanosleep/*.o dump1090 view1090 faup1090 cprtests crctests convert_benchmark
Package libbladeRF was not found in the pkg-config search path.
Perhaps you should add the directory containing `libbladeRF.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libbladeRF' found
make[1]: Leaving directory '/root/dump1090'
dh_clean
rm -f debian/debhelper-build-stamp
rm -f debian/dump1090.substvars
rm -f debian/dump1090.*.debhelper
rm -rf debian/dump1090/
rm -f debian/dump1090-fa.substvars
rm -f debian/dump1090-fa.*.debhelper
rm -rf debian/dump1090-fa/
rm -rf debian/.debhelper/
rm -f debian/*.debhelper.log
rm -f debian/files
find . \( \( \
\( -path .\*/.git -o -path .\*/.svn -o -path .\*/.bzr -o -path .\*/.hg -o -path .\*/CVS \) -prune -o -type f -a \
\( -name '#*#' -o -name '.*~' -o -name '*~' -o -name DEADJOE \
-o -name '*.orig' -o -name '*.rej' -o -name '*.bak' \
-o -name '.*.orig' -o -name .*.rej -o -name '.SUMS' \
-o -name TAGS -o \( -path '*/.deps/*' -a -name '*.P' \) \
\) -exec rm -f {} + \) -o \
\( -type d -a -name autom4te.cache -prune -exec rm -rf {} + \) \)
rm -f *-stamp
debian/rules build
dh build --with=systemd
dh_testdir
dh_update_autotools_config
dh_auto_configure
debian/rules override_dh_auto_build
dh_auto_build -- RTLSDR=yes BLADERF=no DUMP1090_VERSION=3.6.3
make -j1 RTLSDR=yes BLADERF=no DUMP1090_VERSION=3.6.3
make[2]: Entering directory '/root/dump1090'
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c dump1090.c -o dump1090.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c anet.c -o anet.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c interactive.c -o interactive.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c mode_ac.c -o mode_ac.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c mode_s.c -o mode_s.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c comm_b.c -o comm_b.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c net_io.c -o net_io.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c crc.c -o crc.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c demod_2400.c -o demod_2400.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c stats.c -o stats.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c cpr.c -o cpr.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c icao_filter.c -o icao_filter.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c track.c -o track.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c util.c -o util.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c convert.c -o convert.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c sdr_ifile.c -o sdr_ifile.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c sdr.c -o sdr.o
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c sdr_rtlsdr.c -o sdr_rtlsdr.o
cc -g -o dump1090 dump1090.o anet.o interactive.o mode_ac.o mode_s.o comm_b.o net_io.o crc.o demod_2400.o stats.o cpr.o icao_filter.o track.o util.o convert.o sdr_ifile.o sdr.o sdr_rtlsdr.o -lpthread -lm -lrt -lrtlsdr -lusb-1.0 -lncurses
cc -DMODES_DUMP1090_VERSION=\"3.6.3\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c view1090.c -o view1090.o
cc -g -o view1090 view1090.o anet.o interactive.o mode_ac.o mode_s.o comm_b.o net_io.o crc.o stats.o cpr.o icao_filter.o track.o util.o -lpthread -lm -lrt -lncurses
make[2]: Leaving directory '/root/dump1090'
dh_auto_test
make -j1 test
cc -DMODES_DUMP1090_VERSION=\"\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -DENABLE_BLADERF -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -c cprtests.c -o cprtests.o
cc -DMODES_DUMP1090_VERSION=\"\" -DMODES_DUMP1090_VARIANT=\"dump1090-fa\" -DENABLE_RTLSDR -DENABLE_BLADERF -g -O2 -std=c11 -O2 -g -Wall -Werror -W -D_DEFAULT_SOURCE -I/usr/include/ -g -o cprtests cpr.o cprtests.o -lm
./cprtests
testCPRGlobalAirborne[0,EVEN]: PASS
testCPRGlobalAirborne[0,ODD]: PASS
testCPRGlobalAirborne[1,EVEN]: PASS
testCPRGlobalAirborne[1,ODD]: PASS
testCPRGlobalSurface[0,EVEN]: PASS
testCPRGlobalSurface[0,ODD]: PASS
testCPRGlobalSurface[1,EVEN]: PASS
testCPRGlobalSurface[1,ODD]: PASS
testCPRGlobalSurface[2,EVEN]: PASS
testCPRGlobalSurface[2,ODD]: PASS
testCPRGlobalSurface[3,EVEN]: PASS
testCPRGlobalSurface[3,ODD]: PASS
testCPRGlobalSurface[4,EVEN]: PASS
testCPRGlobalSurface[4,ODD]: PASS
testCPRGlobalSurface[5,EVEN]: PASS
testCPRGlobalSurface[5,ODD]: PASS
testCPRGlobalSurface[6,EVEN]: PASS
testCPRGlobalSurface[6,ODD]: PASS
testCPRGlobalSurface[7,EVEN]: PASS
testCPRGlobalSurface[7,ODD]: PASS
testCPRGlobalSurface[8,EVEN]: PASS
testCPRGlobalSurface[8,ODD]: PASS
testCPRGlobalSurface[9,EVEN]: PASS
testCPRGlobalSurface[9,ODD]: PASS
testCPRGlobalSurface[10,EVEN]: PASS
testCPRGlobalSurface[10,ODD]: PASS
testCPRGlobalSurface[11,EVEN]: PASS
testCPRGlobalSurface[11,ODD]: PASS
testCPRGlobalSurface[12,EVEN]: PASS
testCPRGlobalSurface[12,ODD]: PASS
testCPRGlobalSurface[13,EVEN]: PASS
testCPRGlobalSurface[13,ODD]: PASS
testCPRGlobalSurface[14,EVEN]: PASS
testCPRGlobalSurface[14,ODD]: PASS
testCPRGlobalSurface[15,EVEN]: PASS
testCPRGlobalSurface[15,ODD]: PASS
testCPRGlobalSurface[16,EVEN]: PASS
testCPRGlobalSurface[16,ODD]: PASS
testCPRGlobalSurface[17,EVEN]: PASS
testCPRGlobalSurface[17,ODD]: PASS
testCPRGlobalSurface[18,EVEN]: PASS
testCPRGlobalSurface[18,ODD]: PASS
testCPRGlobalSurface[19,EVEN]: PASS
testCPRGlobalSurface[19,ODD]: PASS
testCPRGlobalSurface[20,EVEN]: PASS
testCPRGlobalSurface[20,ODD]: PASS
testCPRGlobalSurface[21,EVEN]: PASS
testCPRGlobalSurface[21,ODD]: PASS
testCPRGlobalSurface[22,EVEN]: PASS
testCPRGlobalSurface[22,ODD]: PASS
testCPRRelative[0]: PASS
testCPRRelative[1]: PASS
testCPRRelative[2]: PASS
testCPRRelative[3]: PASS
testCPRRelative[4]: PASS
testCPRRelative[5]: PASS
testCPRRelative[6]: PASS
testCPRRelative[7]: PASS
testCPRRelative[8]: PASS
testCPRRelative[9]: PASS
testCPRRelative[10]: PASS
testCPRRelative[11]: PASS
testCPRRelative[12]: PASS
testCPRRelative[13]: PASS
testCPRRelative[14]: PASS
testCPRRelative[15]: PASS
testCPRRelative[16]: PASS
testCPRRelative[17]: PASS
testCPRRelative[18]: PASS
testCPRRelative[19]: PASS
testCPRRelative[20]: PASS
testCPRRelative[21]: PASS
testCPRRelative[22]: PASS
testCPRRelative[23]: PASS
testCPRRelative[24]: PASS
testCPRRelative[25]: PASS
testCPRRelative[26]: PASS
testCPRRelative[27]: PASS
testCPRRelative[28]: PASS
testCPRRelative[29]: PASS
debian/rules binary
dh binary --with=systemd
dh_testroot
dh_prep
dh_auto_install
install -d debian/dump1090
install -d debian/dump1090-fa
debian/rules override_dh_install
dh_install
install -d debian/dump1090-fa/usr/share/dump1090-fa/html
cp --reflink=auto -a ./public_html/config.js debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/db debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/dbloader.js debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/flags-tiny debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/flags.js debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/formatter.js debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/images debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/index.html debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/jquery debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/layers.js debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/markers.js debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/ol debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/planeObject.js debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/registrations.js debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/script.js debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/spinny.gif debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/style.css debian/dump1090-fa/usr/share/dump1090-fa/html/
cp --reflink=auto -a ./public_html/test debian/dump1090-fa/usr/share/dump1090-fa/html/
install -d debian/dump1090-fa/etc/lighttpd/conf-available
cp --reflink=auto -a ./debian/lighttpd/88-dump1090-fa-statcache.conf debian/dump1090-fa/etc/lighttpd/conf-available/
cp --reflink=auto -a ./debian/lighttpd/89-dump1090-fa.conf debian/dump1090-fa/etc/lighttpd/conf-available/
install -d debian/dump1090-fa//usr/share/dump1090-fa/bladerf
cp --reflink=auto -a ./bladerf/decimate8-x40.rbf debian/dump1090-fa//usr/share/dump1090-fa/bladerf/
cp --reflink=auto -a ./bladerf/README debian/dump1090-fa//usr/share/dump1090-fa/bladerf/
install -d debian/dump1090-fa/usr/bin
cp -a dump1090 debian/dump1090-fa/usr/bin/dump1090-fa
cp -a view1090 debian/dump1090-fa/usr/bin/view1090-fa
dh_installdocs
install -d debian/dump1090/usr/share/doc/dump1090
install -p -m0644 debian/copyright debian/dump1090/usr/share/doc/dump1090/copyright
install -d debian/dump1090-fa/usr/share/doc/dump1090-fa
cp --reflink=auto -a debian/README.librtlsdr debian/dump1090-fa/usr/share/doc/dump1090-fa
chown -R 0:0 debian/dump1090-fa/usr/share/doc
chmod -R go=rX debian/dump1090-fa/usr/share/doc
chmod -R u\+rw debian/dump1090-fa/usr/share/doc
install -p -m0644 debian/copyright debian/dump1090-fa/usr/share/doc/dump1090-fa/copyright
dh_installchangelogs
install -p -m0644 debian/changelog debian/dump1090/usr/share/doc/dump1090/changelog
install -p -m0644 debian/changelog debian/dump1090-fa/usr/share/doc/dump1090-fa/changelog
dh_systemd_enable
install -d debian/dump1090-fa/lib/systemd/system
install -p -m644 debian/dump1090-fa.service debian/dump1090-fa/lib/systemd/system/dump1090-fa.service
echo "# Automatically added by dh_systemd_enable">> debian/dump1090-fa.postinst.debhelper
sed "s/#UNITFILE#/dump1090-fa.service/" /usr/share/debhelper/autoscripts/postinst-systemd-enable >> debian/dump1090-fa.postinst.debhelper
echo '# End automatically added section' >> debian/dump1090-fa.postinst.debhelper
echo "# Automatically added by dh_systemd_enable">> debian/dump1090-fa.postrm.debhelper
sed "s/#UNITFILES#/dump1090-fa.service/" /usr/share/debhelper/autoscripts/postrm-systemd >> debian/dump1090-fa.postrm.debhelper
echo '# End automatically added section' >> debian/dump1090-fa.postrm.debhelper
(grep -a -s -v misc:Depends debian/dump1090-fa.substvars; echo "misc:Depends=init-system-helpers (>= 1.18~)") > debian/dump1090-fa.substvars.new
mv debian/dump1090-fa.substvars.new debian/dump1090-fa.substvars
dh_installinit
install -p -m0644 debian/dump1090-fa.service debian/dump1090-fa/lib/systemd/system/dump1090-fa.service
install -d debian/dump1090-fa/etc/default
install -p -m0644 debian/dump1090-fa.default debian/dump1090-fa/etc/default/dump1090-fa
echo "# Automatically added by dh_installinit">> debian/dump1090-fa.postinst.debhelper
sed "s/#SCRIPT#/dump1090-fa/g;s/#INITPARMS#/defaults/g;s/#ERROR_HANDLER#/exit \$?/g" /usr/share/debhelper/autoscripts/postinst-init >> debian/dump1090-fa.postinst.debhelper
echo "# Automatically added by dh_installinit">> debian/dump1090-fa.prerm.debhelper
sed "s/#SCRIPT#/dump1090-fa/g;s/#INITPARMS#/defaults/g;s/#ERROR_HANDLER#/exit \$?/g" /usr/share/debhelper/autoscripts/prerm-init >> debian/dump1090-fa.prerm.debhelper
echo '# End automatically added section' >> debian/dump1090-fa.prerm.debhelper
echo "# Automatically added by dh_installinit"> debian/dump1090-fa.postrm.debhelper.new
sed "s/#SCRIPT#/dump1090-fa/g;s/#INITPARMS#/defaults/g;s/#ERROR_HANDLER#/exit \$?/g" /usr/share/debhelper/autoscripts/postrm-init >> debian/dump1090-fa.postrm.debhelper.new
echo '# End automatically added section' >> debian/dump1090-fa.postrm.debhelper.new
cat debian/dump1090-fa.postrm.debhelper >> debian/dump1090-fa.postrm.debhelper.new
mv debian/dump1090-fa.postrm.debhelper.new debian/dump1090-fa.postrm.debhelper
dh_systemd_start
echo "# Automatically added by dh_systemd_start">> debian/dump1090-fa.postinst.debhelper
sed "s/#UNITFILES#/dump1090-fa.service/" /usr/share/debhelper/autoscripts/postinst-systemd-start >> debian/dump1090-fa.postinst.debhelper
echo "# Automatically added by dh_systemd_start"> debian/dump1090-fa.postrm.debhelper.new
sed "s/#UNITFILES#/dump1090-fa.service/" /usr/share/debhelper/autoscripts/postrm-systemd-reload-only >> debian/dump1090-fa.postrm.debhelper.new
echo "# Automatically added by dh_systemd_start"> debian/dump1090-fa.prerm.debhelper.new
sed "s/#UNITFILES#/dump1090-fa.service/" /usr/share/debhelper/autoscripts/prerm-systemd >> debian/dump1090-fa.prerm.debhelper.new
echo '# End automatically added section' >> debian/dump1090-fa.prerm.debhelper.new
cat debian/dump1090-fa.prerm.debhelper >> debian/dump1090-fa.prerm.debhelper.new
mv debian/dump1090-fa.prerm.debhelper.new debian/dump1090-fa.prerm.debhelper
dh_perl
dh_link
dh_strip_nondeterminism
dh_compress
cd debian/dump1090
chmod a-x usr/share/doc/dump1090/changelog
gzip -9nf usr/share/doc/dump1090/changelog
cd '/root/dump1090'
cd debian/dump1090-fa
chmod a-x usr/share/doc/dump1090-fa/changelog
gzip -9nf usr/share/doc/dump1090-fa/changelog
cd '/root/dump1090'
dh_fixperms
find debian/dump1090 -print0 2>/dev/null | xargs -0r chown --no-dereference 0:0
find debian/dump1090 ! -type l -print0 2>/dev/null | xargs -0r chmod go=rX,u+rw,a-s
find debian/dump1090/usr/share/doc -type f ! -regex 'debian/dump1090/usr/share/doc/[^/]*/examples/.*' -print0 2>/dev/null | xargs -0r chmod 0644
find debian/dump1090/usr/share/doc -type d -print0 2>/dev/null | xargs -0r chmod 0755
find debian/dump1090/usr/share/man debian/dump1090/usr/man/ debian/dump1090/usr/X11*/man/ -type f -print0 2>/dev/null | xargs -0r chmod 0644
find debian/dump1090/usr/include -type f -print0 2>/dev/null | xargs -0r chmod 0644
find debian/dump1090/usr/share/applications -type f -print0 2>/dev/null | xargs -0r chmod 0644
find debian/dump1090/usr/lib/i386-linux-gnu/perl5/5.22 debian/dump1090/usr/share/perl5 -type f -perm -5 -name '*.pm' -print0 2>/dev/null | xargs -0r chmod a-X
find debian/dump1090 -perm -5 -type f \( -name '*.so.*' -o -name '*.so' -o -name '*.la' -o -name '*.a' -o -name '*.js' -o -name '*.css' -o -name '*.jpeg' -o -name '*.jpg' -o -name '*.png' -o -name '*.gif' -o -name '*.cmxs' \) -print0 2>/dev/null | xargs -0r chmod 0644
find debian/dump1090/usr/lib -type f -name '*.ali' -print0 2>/dev/null | xargs -0r chmod uga-w
find debian/dump1090-fa -print0 2>/dev/null | xargs -0r chown --no-dereference 0:0
find debian/dump1090-fa ! -type l -print0 2>/dev/null | xargs -0r chmod go=rX,u+rw,a-s
find debian/dump1090-fa/usr/share/doc -type f ! -regex 'debian/dump1090-fa/usr/share/doc/[^/]*/examples/.*' -print0 2>/dev/null | xargs -0r chmod 0644
find debian/dump1090-fa/usr/share/doc -type d -print0 2>/dev/null | xargs -0r chmod 0755
find debian/dump1090-fa/usr/share/man debian/dump1090-fa/usr/man/ debian/dump1090-fa/usr/X11*/man/ -type f -print0 2>/dev/null | xargs -0r chmod 0644
find debian/dump1090-fa/usr/include -type f -print0 2>/dev/null | xargs -0r chmod 0644
find debian/dump1090-fa/usr/share/applications -type f -print0 2>/dev/null | xargs -0r chmod 0644
find debian/dump1090-fa/usr/lib/i386-linux-gnu/perl5/5.22 debian/dump1090-fa/usr/share/perl5 -type f -perm -5 -name '*.pm' -print0 2>/dev/null | xargs -0r chmod a-X
find debian/dump1090-fa -perm -5 -type f \( -name '*.so.*' -o -name '*.so' -o -name '*.la' -o -name '*.a' -o -name '*.js' -o -name '*.css' -o -name '*.jpeg' -o -name '*.jpg' -o -name '*.png' -o -name '*.gif' -o -name '*.cmxs' \) -print0 2>/dev/null | xargs -0r chmod 0644
find debian/dump1090-fa/usr/bin -type f -print0 2>/dev/null | xargs -0r chmod a+x
find debian/dump1090-fa/usr/lib -type f -name '*.ali' -print0 2>/dev/null | xargs -0r chmod uga-w
dh_strip
strip --remove-section=.comment --remove-section=.note debian/dump1090-fa/usr/bin/view1090-fa
strip --remove-section=.comment --remove-section=.note debian/dump1090-fa/usr/bin/dump1090-fa
dh_makeshlibs
rm -f debian/dump1090/DEBIAN/shlibs
rm -f debian/dump1090-fa/DEBIAN/shlibs
dh_shlibdeps
install -d debian/dump1090/DEBIAN
install -d debian/dump1090-fa/DEBIAN
dpkg-shlibdeps -Tdebian/dump1090-fa.substvars debian/dump1090-fa/usr/bin/dump1090-fa debian/dump1090-fa/usr/bin/view1090-fa
dpkg-shlibdeps: error: no dependency information found for /lib/libc.so.6 (used by debian/dump1090-fa/usr/bin/view1090-fa)
Hint: check if the library actually comes from a package.
dh_shlibdeps: dpkg-shlibdeps -Tdebian/dump1090-fa.substvars debian/dump1090-fa/usr/bin/dump1090-fa debian/dump1090-fa/usr/bin/view1090-fa returned exit code 2
debian/rules:32: recipe for target 'binary' failed
make: *** [binary] Error 2
dpkg-buildpackage: error: debian/rules binary gave error exit status 2
root#
Try with BLADERF=no in the debian/rules ?
Anyway quite a few packets missing apparently.
Yes, got this problem although I have set BLADERF=no, as in post #102, before giving dpkg-buildpackage command
I am also surprized as I have installed all those packages either from PPM (Puppy Package Manager) or if not available there, searched, downloaded and installed from https://launchpad.net/ubuntu/xenial/i386/
It checks if they are installed via the debian package system, so thatâs probably why.
since in last attempt I used flag -d
, it did not anymore stuck due to dependencies issue. It is something else at the end of output:
dh_makeshlibs
dh_shlibdeps
root#
yeah same problem the package infrastructure is not working (dpkg-shlibdeps).
you could try building it on a proper i386 ubunu xenial and then check if installing it on your live thingy works.
wouldnât make for a good guide though
(unless you just supply the debian package with it.)
This is really a pitty I did not succeed in installing dump1090-fa on Xenialpup.
The Xenialpup7.5 (both the 32 bit and 64bit versions) is:
override_dh_shlibdeps:
dh_shlibdeps --dpkg-shlibdeps-params=--ignore-missing-info
if your rule file hasnât the dh_shlibdeps call in it. Thatâs usually the case if youâve
%: dh $@
as only rule in it.
If you want it to just ignore that flag, change the debian/rules line from:
dh_shlibdeps
to:
Yet another way, without modifying build scripts, just creating one file.
You can specify local shlib overrides by creating debian/shlibs.local with the following format: library-name soname-version dependencies
For example, given the following (trimmed) ldd /path/to/binary
output
libevent-2.0.so.5 => /usr/lib/libevent-2.0.so.5 (0x00007fc9e47aa000)
libgcrypt.so.20 => /usr/lib/libgcrypt.so.20 (0x00007fc9e4161000)
libpthread.so.0 => /usr/lib/libpthread.so.0 (0x00007fc9e3b1a000)
The contents of debian/shlibs.local
would be:
libevent-2.0 5 libevent-2.0
libgcrypt 20 libgcrypt
libpthread 0 libpthread
The âdependenciesâ list (third column) doesnât need to be 100% accurate - just use the library name itself again.
Of course this isnât needed in a sane debian system which has this stuff defined in /var/lib/dpkg/info
(which can be used as inspiration for these overrides).
Instead of merely ignoring the error, also fix the source of the error, which is usually either a missing or an incorrect package.shlibs
or package.symbols
file in package which contains the shared library triggering the error.
Documents how dpkg-shlibdeps uses the package.shlibs resp. package.symbols, files:
https://manpages.debian.org/jessie/dpkg-dev/dpkg-shlibdeps.1.en.html
Documents the format of the package.shlibs and package.symbols files:
https://www.debian.org/doc/debian-policy/ch-sharedlibs.html
Finally I did it in the brute way:
I edited the script /usr/bin/dpkg-shlibdeps, changing this :
my $ignore_missing_info = 0;
to
my $ignore_missing_info = 1;
Did you try any of these workarounds?
(1) Edited file debian/rules
and disabled dh_shlibdeps
root# cd dump1090-fa
# NOTE: I have renamed cloned folder dump1090 to dump1090-fa
#as I have cloned dump1090-mutability also
#and renamed it dump1090-mut
root# nano debian/rules
In file debian/rules
, the last two lines are:
dh $@ --with=systemd
Below last line added following two lines, then Saved & Closed file:
(2) Ran build command:
dpkg-source --before-build dump1090-fa
debian/rules clean
dpkg-gencontrol: warning: Depends field of package dump1090-fa: unknown substitution variable ${shlibs:Depends}
dpkg-gencontrol: warning: File::FcntlLock not available; using flock which is not NFS-safe
dpkg-deb: building package 'dump1090' in '../dump1090_3.6.3_all.deb'.
dpkg-deb --build debian/dump1090-fa ..
dpkg-deb: building package 'dump1090-fa' in '../dump1090-fa_3.6.3_i386.deb'.
dpkg-genchanges -b >../dump1090-fa_3.6.3_i386.changes
dpkg-genchanges: binary-only upload (no source code included)
dpkg-source --after-build dump1090-fa
dpkg-buildpackage: binary-only upload (no source included)
root#
(3) Checked
root# cd ../
root# ls
Choices dump1090-fa_3.6.3_i386.changes my-documents
Desktop dump1090-fa_3.6.3_i386.deb network
distro.ibiblio.org dump1090-mut puppy-reference
Downloads File-Sharing spot
dump1090_3.6.3_all.deb ftpd Startup
dump1090-fa my-applications
(4) Tried to install
root# dpkg -i dump1090-fa_3.6.3_i386.deb
(Reading database ... 673 files and directories currently installed.)
Preparing to unpack dump1090-fa_3.6.3_i386.deb ...
Unpacking dump1090-fa (3.6.3) over (3.6.3) ...
dpkg: dependency problems prevent configuration of dump1090-fa:
dump1090-fa depends on init-system-helpers (>= 1.18~); however:
Package init-system-helpers is not installed.
dump1090-fa depends on adduser; however:
Package adduser is not installed.
dump1090-fa depends on lighttpd; however:
Package lighttpd is not installed.
dpkg: error processing package dump1090-fa (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
dump1090-fa
Do not understand why it says:
init-system-helpers, adduser, and lighttpd not installed.
CHECKED, FOLLOWING PACKAGES ARE INSTALLED:
init-system-helpers_1.29ubuntu4
adduser_3.113+nmu3ubuntu4
lighttpd-dev_1.4.35
Try this:
dpkg -i --ignore-depends=package1,package2 package3.deb
package3.deb would be dump1090-fa_3.6.3_i386.deb
(it seems they call the packages by different names on the live image, notice the ubuntu in the name. and lighttpd is lighttpd-dev not lighttpd.)
