Antenna - Rotation Matters
#1
hi all,
found something that maybe you were not really aware (me too - up to 60 minutes before) of and might help you with your site.
while doing my antenna testing i found that - at least my jetvision - omnidirectional antenna is not really omnidirectional.
turning the antenna around her axis in steps of about 90 degree i can clearly see big differences.
tom
#2
If it is a PCB antenna, tuning fork shaped, it cannot be truly omnidirectional.
The dipole, monopole whip with ground plane, Cantenna, and wire collier with coils are most close to a perfect omni directional.
As far as I know Flightaware antenna is a wire collinear with coils, and should be nearly perfect omni directional.
By the way, have you seen this:
Antenne active PCB 1090 MHz / 1090 MHz Active PCB antenna
