Sorry, my mistake. I missed the command git fetch --all immediately after cd to folders dump1090 and piaware_ builder.
Thanks to @obj for pointing it out. I have now corrected that post.
It is in liblimesuite-dev. I guess you just needed a newer version. My x86 test machine is also on 18.04 but I have recent myriadrf packages installed.
If you don’t actually need the support for other SDRs, it’s possible to build the dump1090-fa package with a subset of SDR support, e.g. --build-profiles=custom,rtlsdr will build with rtlsdr support only (see the README for more details)
More than a year of feeding with lots of readings in the discussions, but still things to learn.
Thanks. I’ve tried it on my both feeders and worked without issues.
Two new dependencies for v4.0 (in addition to those for ver 3.8.1)
Updated RPi4b and built and installed the updated packages for my RockPi.
All good.
Good clean update!
Thankyou soo much
all sorted working 4.0 model
I updated my installation on x86 Ubuntu 20.04.1 LTS, using your instructions, by simply replacing in your instructions arm64 with amd64
Thank you!
We will look into this
Now finally it added support for a screen, and then it doesn’t even work. Screen is just white. Got excited for nothing.
What LCD hardware do you have, and what image did you try?
Hi. I assume I have missed something. I am currently running a Pi Zero with WiFi. Image version 3.8.1 on the SD Card. Thought I would go the hog and use a Pi 3+ with the LCD screen. Downloaded the 4.0 LCD image and installed to new SD card. After booting in the Pi 3+, it configures itself and after I connect the antenna I get Aircraft on the screen. Unfortunately, the MLAT is no going active. After reader some of the posts here it apparently has something to do with generating a new Unique Identifier. So, my question is, how do I get my original UI, from the Pi Zero installation, onto the new installation for the Pi 3+.
Thanks in advance.
Hey folks, I was interested in the Mode A/C hit count referenced above and found the following lines in my aircraft.json file. Am I correct that these “category”:“A3” entries are those?
{"hex":"c0480f","category":"A3","version":2,"sil_type":"perhour","mlat":[],"tisb":[],"messages":3657,"seen":81.0,"rssi":-24.1},
{"hex":"c08081","category":"A3","version":2,"sil_type":"perhour","mlat":[],"tisb":[],"messages":5150,"seen":295.0,"rssi":-23.7}
You will need to manually add the feeder-id to piaware-config.txt file to claim your existing feeder-id. Insert the SD card into a computer, open that file, and at the end of the file add the line:
feeder-id XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX
where XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX is the feeder-id of your Pi Zero.
Sorry for the hassle, the next release will make it more convienent to do this via the LCD screen itself.
I tried the image, that supports LCD Displays (or so i thought atleast), With the name of “piaware-sd-lcd-card-4.0.img”.
The LCD display i have looks as same as the display used in your pictures, however, it just stays White, without showing anything.
Check what model & manufacturer. There are many similar-looking LCD screens that are mutually incompatible. The sdcard image supports only specifically the Waveshare 3.5" model linked in the top post. A white screen indicates that the framebuffer is not initializing correctly, which usually means the sdcard configuration does not match the LCD model (either that or hardware damage)
No, A3 is the ADS-B emitter category. The new fields are modea and modec. They only appear if true. You will only see them if you have mode A/C decoding enabled, obviously.
(Also the changelog wording is a bit inaccurate - it’s a true/false flag, not a count)
Thank you for your support.
I’ve done a fresh install in another RPi using the latest Piaware image, then a fresh install of Raspberry OS lite and still couldn’t add the "terrain limit rings.
Then I’ve done a fresh install of Piaware_3.7.2 and after having the file upintheair.json in /usr/share/dump1090-fa/html/upintheair.json I got the “terrain limit rings”.
In all excitement, I see upgraded sites with altered site ID. Remember to set feeder-id. The most future-proof way is to add a line
feeder-id 1234abcd-5678efgh-XXXX
to /boot/piaware-config.txt. Use the feeder-id when you first registered. (You can find that in your feeder page by selecting the old site.) I had this issue a when I first came up and had to make a new image. (Search led me to an old topic in this forum. But this probably belong to an FAQ and perhaps include in each release notes.)
@pretoescuro @hphillip @grsham Turns out OpenLayers6 Geometry constructors now require a coordinate array even if it’s empty. I’ll commit a fix in the next release.
For a quick fix, edit line 947 in /usr/share/dump1090-fa/html/script.js and add an empty array.
var geom = new ol.geom.LineString([]);
Let me know if this fixes your issues.
Problem solved, thank you.
