HI all,
Have upgraded to 3.6.2 and VRS isn’t reporting ADSB but is reporting MLAT.
I tried both fixed above (added line to /etc/hosts and changing VRS options to Beast and port 30005) but no dice.
Any further thoughts?
I upgraded to 3.6.2 a few days ago on my RPi 3 B+. Ran the update through the MyFA config.
Since the update, I’ve seen my daily stats cut by ~50%. The gain is still set to -10 … in fact, I made no configuration changes at all. Any suggestions for what I should do to restore my levels of flights and messages?
PiAware 3.6.3 is now released! See the release notes at the top of this thread for more information. The major change in this release is that Skyview is updated to make “extended Mode S” data a first-class feature. As a result, the layout of the aircraft details pane has changed.
Just upgraded and now really wished i had not.
Even with the info pane split at 50/50 with tracked aircraft its about 8 scrolls of a mouse wheel to see the info. The old popup box was much better, this now makes the UI feel cluttered
is there a way to go back to an older version of PiAware?
EDIT: i just figured if you hover over the aircraft it actually displays the popup info box so you can just slide the bottom info pane on the right all the way to the bottom so its out of view completely
The aircraft details pane looks like this (now shows a lot more information; for example, see the Speed, Navigation, Tracking Information and Accuracy sections):
Extended information is quite sporadic in some locations. Transponder need to have the ADSBv2 upgrade and local ATC need to request for the extended information. Extended information is very good for Europe and somewhat good in the USA. This will continue to improve in other locations as we get to closer to the 2020 ADSB deadline.
sadly it looks like this for me, if i want to see altitude on the info pane on the right then i simply cant see it as i have to scroll down, then if i change planes… i have to scroll down again.
If there was an option to re-arrange the order of the details then it would be useful.
Also the popup hover box for an aircraft would be useful if it didn’t auto close when the mouse moved and instead it only disappeared if you clicked on a blank part of the map.
