If you mean the gear menu on the My ADS-B page, the option is there. While I have not used this method myself, it should work.
Yes the gear menu. Giving it a try now. Will download the new Piaware version in case anyway.
Suggestion:
Make the “Web Interface: PiAware Skyview (requires local network connection)” link on the My ADS-B page to go to the #extended version of Skyview. It currently points to port 8080.
I used to upgrade from there, before switching to the re-image card method. The only problem I remember having in those days, was that sometimes I had to power cycle the Pi after the upgrade.
The rpi3b updated ok, but the rpi2b says:
“run-apt-get(30217): E: The method driver /usr/lib/apt/methods/https could not be found”
I’ll pwr cycle it and try again, if fails it’s easy to re-image the card.
That is what I did last night. I re-imaged my card.
After the upgrade I am seeing plots a bit further out. I was running the stock settings before and they stayed the same after the upgrade.
I am wondering DUMP1090 FA was tweaked for better decoding?
I don’t know the answer, but I noticed that the version displayed on the top right corner of Skyview is different than mine. What is 3.6.2~bpo8+1? Mine says 3.6.2 only.
Also, did you check the gear box to see if the settings there have changed?
Just updated one of mine. Skyview reports 3.6.2~bpo8+1 however on the FA site under my own Feeder Type: it shows PiAware (SD Card) 3.6.2 .
Try a CTRL-F5 page refresh.
many thanks, it 's ok i can see colors, altitude, speed now
Before upgrade, on top-right of SkyView: 3.5.3
After upgrade, on top-right of SkyView: 3.6.2~bpo8+1
What is ~bpo8+1
Looks like bpo8+1 refers to a Debian Jessie backport.
Ref: overview
Additional info here: Instructions
One major difference: Jessie and Stretch
(1) Upgraded by command:
sudo apt update
sudo apt upgrade
Checked Piaware version, it is
3.6.2~bpo8+1
Checked OS version, it is JESSIE
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
(2) Upgraded by re-imaging
Checked Piaware Version, it is 3.6.2
There is no~bpo8+1
after3.6.2
(please see screenshot below) -
Checked OS version, it is STRETCH
pi@piaware:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
Make sure the ports that you are connecting to are still enabled on the RPI.
netstat -an | grep LIST
They may need to be re-enabled on the RPI.
Jon
In Piaware SD Card image 3.6.2
pi@piaware:~ $ sudo systemctl restart piaware
sudo: unable to resolve host piaware
pi@piaware:~ $ sudo systemctl restart dump1090-fa
pi@piaware:~ $ sudo systemctl restart pfclient
pi@piaware:~ $ sudo systemctl restart fr24feed
NEXT without sudo
pi@piaware:~ $ systemctl restart dump1090-fa
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to restart 'dump1090-fa.service'.
Authenticating as: root
Password:
I can connect to the ports …
Telnet 192.168.1.20 30106
Trying 192.168.1.20…
Connected to 192.168.1.20.
Escape character is ‘^]’.
MLAT,3,1,1,484C53,1,2018/07/28,17:34:11.384,2018/07/28,17:34:11.384,21998,430,111,52.8609,2.4201,-2551,
MLAT,3,1,1,06A0B5,1,2018/07/28,17:34:13.286,2018/07/28,17:34:13.286,39991,462,284,51.2557,6.6127,65,
MLAT,3,1,1,407040,1,2018/07/28,17:34:14.788,2018/07/28,17:34:14.788,37007,502,136,50.4571,2.377,23,
MLAT,3,1,1,40127A,1,2018/07/28,17:34:14.903,2018/07/28,17:34:14.903,27004,345,117,52.8431,3.3133,25,
MLAT,3,1,1,484C53,1,2018/07/28,17:34:18.732,2018/07/28,17:34:18.732,21693,420,110,52.8586,2.4393,-2569,
MLAT,3,1,1,3E39E2,1,2018/07/28,17:34:19.388,2018/07/28,17:34:19.388,30814,359,29,52.2832,5.3568,1007,
^C^]
telnet> quit
Connection closed.
telnet 192.168.1.20 30003
MSG,5,1,1,4009C7,1,2018/07/28,17:34:30.1532799270,2018/07/28,17:34:30.426,36000,0,0,
MSG,7,1,1,4CACAE,1,2018/07/28,17:34:30.1532799270,2018/07/28,17:34:30.426,37000,
MSG,7,1,1,392AE2,1,2018/07/28,17:34:30.1532799270,2018/07/28,17:34:30.426,5175,
MSG,4,1,1,485870,1,2018/07/28,17:34:30.1532799270,2018/07/28,17:34:30.426,202,239,-896,0
MSG,8,1,1,4CA566,1,2018/07/28,17:34:30.1532799270,2018/07/28,17:34:30.427,0
MSG,8,1,1,4CA660,1,2018/07/28,17:34:30.1532799270,2018/07/28,17:34:30.427,0
MSG,8,1,1,440052,1,2018/07/28,17:34:30.1532799270,2018/07/28,17:34:30.427,0
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:30002 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:8754 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:30003 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:30004 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:30005 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:30104 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:30053 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:30054 0.0.0.0:* LISTEN
tcp6 0 0 :::80 :::* LISTEN
tcp6 0 0 :::30002 :::* LISTEN
tcp6 0 0 :::30003 :::* LISTEN
tcp6 0 0 :::30004 :::* LISTEN
tcp6 0 0 :::30005 :::* LISTEN
tcp6 0 0 :::22 :::* LISTEN
tcp6 0 0 :::30104 :::* LISTEN
tcp6 0 0 :::30105 :::* LISTEN
tcp6 0 0 :::30106 :::* LISTEN
tcp6 0 0 :::31004 :::* LISTEN
