The script which has to be used coming from FA website if you run already a Raspberry with a running Raspbian on it. So not the disk image you provide.
We donāt provide any install scripts on the FA website. Do you mean the package install instructions at PiAware - dump1090 ADS-B integration with FlightAware - FlightAware ? I would not expect to see that problem if you used those instructions.
Script/Package, however you will call it ![]()
Iāve removed the file as instructed by you. Error is gone, this is the current status of apt-get upgrade:
The following packages have been kept back:
mlat-client piaware
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
forget about the mlat client, thatās a different install
Unfortunately I canāt offer much support here - this system has obviously had a bunch of things done to it that arenāt from our side, and without a detailed description of what you installed and changed, in what order, and the full output of the upgrade attempt etc I canāt help. You may want to consider reimaging if you continue to have problems.
Well youāll need to dist-upgrade instead of upgrade i suspect.
sudo apt dist-upgrade
Does that help?
In doubt:
sudo apt purge piaware
sudo apt purge piaware-repository
Then do the install process again.
I would expect the piaware stretch repo was installed as the 3.8 repo package wasnāt available yet.
Maybe the bpo repo was then installed after that or something like that to spice it up a bit ![]()
piaware-repository 3.7.2 ā 3.8.0~bpo9 is the stretch upgrade path; both install piaware-stretch.list
piaware-repository 3.8.0 is the buster path; it installs piaware-buster.list
Neither install piaware.list. That is only created by piaware itself if an upgrade is requested and the correct repository-package-installed sources file is not present.
So the only way I can see this happening is if at some point a piaware upgrade was requested when the piaware-repository package was not installed. Which does not match the current description of events, which was ā3.7.2 was installed, then later updatedā.
edit: Oh, ok. I think I see the path of events. This is a Pi 4, so it must be a Buster install, but it had 3.7.2 installed on it; so it had the stretch versions (piaware-repository 3.7.2, piaware 3.7.2) installed. An update would have installed piaware-repository 3.8.0~bpo9 and piaware 3.8.0~bpo9. Then a manual update request would have seen that piaware-buster.list was missing and would have created the fallback list. So far, this is harmless because thereās piaware-stretch.list and piaware.list present, and they have different contents; apt will be able to see both the Stretch packages and the Buster packages, and it will pick the Buster packages because they have a higher version number (3.8.0 > 3.8.0~bpo9)
Then, installing the Buster piaware-repository (3.8.0) explicitly would have removed piaware-stretch.list and installed piaware-buster.list. Now we have duplication between piaware-buster.list and piaware.list
tl;dr: itās due to the unsupported combination of installing the 3.7.2 Stretch packages on Buster.
Iāve edited the top post FAQ about 3.7.2 buster installs to add a step for removing piaware.list if it exists.
(ITT you get to see why mixing packages across distributions is a nightmare. I would be so happy if I only had one distribution to supportā¦)
Yes, that made the trick:
Preparing to unpack .../piaware_3.8.0_armhf.deb ... Unpacking piaware (3.8.0) over (3.8.0~bpo9+1) ...
Yeah itās not fun.
Anyhow it provides for interesting puzzles sometimes.
Well mostly they are kinda boring, but you have to take what you can get ![]()
+1 for PiAwareBSD 4.0.0 ![]()
Would you happen to know roughly when 3.8.1 will be available please? No big deal and Iām not chasing. Iām reimaging before the weekend so if itās imminent Iāll wait for it rather than work around the bug and then do an upgrade anyway.
Itās not imminent, Iād go ahead and reimage with 3.8.0
Curious⦠just upgraded to 3.8.0 yesterday. I run three (3) PiAware systems⦠one upgraded to 3.8.0 (as noted on the map), but the other two (same OS build) upgraded to 3.8.0~bpo9+1 (as noted on their maps). Doesnāt seem to affect performance, but have not seen this before. Thanks.
Is the one with 3.8.0 a Pi 4?
I seem to recall @obj saying that the ~bpo version was for the earlier Pi hardware? I have a 3B+, and thatās what mine shows.
bpo means something with back port to make it Stretch compatible as far as i remember.
But i have the same result while looking on my two devices. the 3B is on 3.8.0-bpo while the 4B shows 3.8.0 only.
Both are on Buster
the command "sudo apt dist-upgrade worked on 4B only. But as long as both are operating, i donāt careā¦
All of my RPis are 3B+
3.8.0~bpo9+1 is the Stretch package.
If you installed the 3.7.2 Stretch version on a Buster sdcard before Buster support was released, then upgraded to 3.8.0, then you should follow the instructions in the top post to get the correct repository package and upgrade to the Buster packages.
Iām tempted to purge and reload all three systems with fresh Raspbian and PiAware software (3.8.0). I just donāt want to lose my FA data over the last year.
I now followed the instructions on my RPi 3B (uninstall and reinstall) and now the device is also on V3.8.0
Thank you for these instructions!
