BLUF: I purchased both FA bandpass filters and when I install either of them, my system is reporting ADS-B packet per second are reduced to almost zero.
With my current setup, I’m receiving (peak) 700-800 packets/sec and about (avg) 300-500 packets/sec. When I install the filter, I’m at 0.3-0.8 packets/sec. I tried both filters, 1090 & 1090/978, with the same effects. I’m thinking I might need to adjust gain or place filter directly after LNA, but I’m kind of confused about what’s happening. Any one have any suggestions? I can provide more information if needed.
Ah, not familiar with that but after a little Google-fu and some reading I understand.
I plan on installing a couple more feeders in other locations and am trying to figure out to put together the optimal setup, hence LNAs and filters. Sounds like I should be able to use a filter in locations where I won’t be using a powered LNA.
I followed @wiedehopf GitHub page about optimization to end up with that gain. Any lower and I started losing packets. Noise is high and I figure I’ll burn out my RTLSDR sooner than later. Coax is short, maybe 12 feet.
With the filter in the circuit between the dongle and the LNA it’s blocking the bias-T voltage. With no power that LNA acts as an open circuit and you don’t see any messages. If you have to add that filter put it between the LNA and the antenna.
