Airline seats!
#1
To call a first class flat bed a suite is an exaggeration of mythical proportions. Long ago when the loud planes head flat beds
for their long hauls, these were called berths. A suite at a hotel is a
room with a private bath and living area, at least. So to call a seat on a plane that can go flat a suite ( with or without a sliding door) is a flat out ( no pun intended) lie. I think the airlines should reinstate the word berth. It sounds classy, elegant and above all, true.
#2
Definitions:
Berth (as it applies to passenger accommodations): a built-in bed or bunk
Suite: A set of things belonging together.
Per Seatguru, “Suites: These seats offer the utmost in privacy and comfort. Each suite is essentially its own mini-cabin which includes a fully-flat bed, work station and television.”
A lie-flat bed does not necessarily make a seat a suite.
The FAA, per FAR 25.785 (below), recognizes that there is a difference between a seat and a berth.
There are berths on airliners. These are used by the crew for breaks on long-distance flights.
Seats, berths, safety belts, and harnesses.
(a) A seat (or berth for a nonambulant person) must be provided for each occupant who has reached his or her second birthday.
(b) Each seat, berth, safety belt, harness, and adjacent part of the airplane at each station designated as occupiable during takeoff and landing must be designed so that a person making proper use of these facilities will not suffer serious injury in an emergency landing as a result of the inertia forces specified in Secs. 25.561 and 25.562.
© Each seat or berth must be approved.
(d) Each occupant of a seat that makes more than an 18° angle with the vertical plane containing the airplane centerline must be protected from head injury by a safety belt and an energy absorbing rest that will support the arms, shoulders, head, and spine, or by a safety belt and shoulder harness that will prevent the head from contacting any injurious object. Each occupant of any other seat must be protected from the head injury by a safety belt and, as appropriate to the type, location, and angle of facing of each seat, by one or more of the following:
(1) A shoulder harness that will prevent the head from contacting any injurious object.
(2) The elimination of any injurious object within striking radius of the head.
(3) An energy absorbing rest that will support the arms, shoulders, head, and spine.
(e) Each berth must be designed so that the forward part has a padded end board, canvas diaphragm, or equivalent means, that can withstand the static load reaction of the occupant when subjected to the forward inertia force specified in Sec. 25.561. Berths must be free from corners and protuberances likely to cause injury to a person occupying the berth during emergency conditions.
(f) Each seat or berth, and its supporting structure, and each safety belt or harness and its anchorage must be designed for an occupant weight of 170 pounds, considering the maximum load factors, inertia forces, and reactions among the occupant seat, safety belt, and harness for each relevant flight and ground load condition (including the emergency landing conditions prescribed in Sec. 25.561). In addition–
(1) The structural analysis and testing of the seats, berths, and their supporting structures may be determined by assuming that the critical load in the forward, sideward, downward, upward, and rearward directions (as determined from the prescribed flight, ground, and emergency landing conditions) acts separately or using selected combinations of loads if the required strength in each specified direction is substantiated. The forward load factor need not be applied to safety belts for berths.
(2) Each pilot seat must be designed for the reactions resulting from the application of the pilot forces prescribed in Sec. 25.395.
(3) The inertia forces specified in Sec. 25.561 must be multiplied by a factor of 1.33 (instead of the fitting factor prescribed in Sec. 25.625) in determining the strength of the attachment of each seat to the structure and each belt or harness to the seat or structure.
(g) Each seat at a flight deck station must have a restraint system consisting of a combined safety belt and shoulder harness with a single-point release that permits the flight deck occupant, when seated with the restraint system fastened, to perform all of the occupant’s necessary flight deck functions. There must be a means to secure each combined restraint system when not in use to prevent interference with the operation of the airplane and with rapid egress in an emergency.
(h) Each seat located in the passenger compartment and designated for use during takeoff and landing by a flight attendant required by the operating rules of this chapter must be:
(1) Near a required floor level emergency exit, except that another location is acceptable if the emergency egress of passengers would be enhanced with that location. A flight attendant seat must be located adjacent to each Type A or B emergency exit. Other flight attendant seats must be evenly distributed among the required floor-level emergency exits to the extent feasible.]
(2) To the extent possible, without compromising proximity to a required floor level emergency exit, located to provide a direct view of the cabin area for which the flight attendant is responsible.
(3) Positioned so that the seat will not interfere with the use of a passageway or exit when the seat is not in use.
(4) Located to minimize the probability that occupants would suffer injury by being struck by items dislodged from service areas, stowage compartments, or service equipment.
(5) Either forward or rearward facing with an energy absorbing rest that is designed to support the arms, shoulders, head, and spine.
(6) Equipped with a restraint system consisting of a combined safety belt and shoulder harness unit with a single point release. There must be means to secure each restraint system when not in use to prevent interference with rapid egress in an emergency.
(i) Each safety belt must be equipped with a metal to metal latching device.
(j) If the seat backs do not provide a firm handhold, there must be a handgrip or rail along each aisle to enable persons to steady themselves while using the aisles in moderately rough air.
(k) Each projecting object that would injure persons seated or moving about the airplane in normal flight must be padded.
(l) Each forward observer’s seat required by the operating rules must be shown to be suitable for use in conducting the necessary enroute inspection.
#3
Way to kill that gnat with a sledgehammer.
#4
Someone with too much time on their hands…
#5
  • He made a statement. I responded with comments.
  • It took me less than 3 minutes to find the information.
  • When the idiots in charge destroy the economy as the present idiots in charge have done then there are people who are laid off. I, unfortunately, fall into that category. Therefore I have time to research items in between looking for a job.
#6
That’s some good police work there, Lou…
#7
That’s a quote from…?
#8
the simpsons
#9
Etihad has suites with beds. They cost an arm, a leg and a torso.
#10
*Just to get back to seat basics for a couple of seconds, a couple of weeks ago I travelled in the economy :cry: section of a Cathay Pacific Airbus Industrie A330. When it came time to recline the seat’s back, I was astounded to discover that when I pressed the button on the arm rest, that the seat back remained unmoved and the cushion moved forwards a few centimetres!! What the?? :unamused: *
#11
It’s a new trend where you choose between recline and destroying your own kneeroom, rather than someone elses.
#12
Yes the new seats on the American 737-800’s do this too.
I think it’s by far more fair than restricting the leg room of the person behind you.
