After migration to Trixie, using the same feeder ID, stats page shows offline
Everything is working locally with skyaware, and as best I can tell I’m sending data to FA:
PiAware master process (piaware) is running with pid 8903.
PiAware ADS-B client (faup1090) is running with pid 8924.
Local ADS-B receiver (dump1090-fa) is running with pid 4093.
dump1090-fa (pid 4093) is listening for ES connections on port 30005.
However the stats page on FA shows I’m red and offline. It’s reporting an old site local IP so I’m wondering if there is some stale data there?
Not sure what else to look at.
piaware[8903]: 43069 msgs recv’d from dump1090-fa (751 in last 5m); 43069 msgs sent to FlightAware
Assuming you are sending data, that means you are not being recognized as the same site.
Try opening a command prompt on your Pi, and enter:
sudo piaware-config feeder-id UUID
Where UUID is your old site number
Are you running any form of filtering on the network to which the Pi is connected; MAC filtering, firewall ports closed off, etc. How are you ‘getting’ status messages - are these from a terminal locally connected, or have you SSH’d in? Your status page reports an old local IP address - what does running ip addr give you as an IP address? Have you reserved the IP address for the Pi on the router’s DHCP; if so, does this match the results of the ip addr command?
I wasn’t able to get it to take my old UUID and thus I just created a new one so I have two sites on my account now. I’d like to merge the old stats with the new site but it’s not clear to me how that is accomplished.
3 ways this could be achieved; On the assumption that you know what your ‘old’ UUID was,
  • from either the local console or SSH’d in, enter:sudo piaware-config feeder-id UUID (where UUID is your old user ID)
  • Second option is shut down your Pi and remove the SD card, place this into a Windows-based pc, which will see a drive labelled bootfs. Open this, and find a file called piaware-config - open this with a text editor such as notepad or Notepad++ and find the line starting feeder-id and the new UUID - replace the new UUID with your original one, save the file, dismount the SD card and return to your Pi.
  • Option 3 (if you don’t have a record of your old UUID) would be for the FA support team to search for your email address in the user registration database and combine the two accounts; I needed to use this route before learning to keep a copy of the current piaware-config file off my Pi!!
When you are logged into piaware and got to your old site your UID should be displayed there on the right of the screen.
See the example below of one of my sites
In the top row of the 4th segment that displays your unique identifier of the old site.
The use that as the last portion of this command (the UUID bit).
You can copy and paste it from the page into the commandline of the raspberry pi and they you reactivate the old UUID again.
Thanks, I’ll check it out tonight.
@tomvdhorst good point on getting his old UUID from his status page. :clap:
Thanks @tomvdhorst , got it swapped back to my old one. I guess I have to wait to delete the “new” feeder off my account once it’s been inactive for a while. Cheers.
BH
Glad to be of assistance.
You can delete the new feeder after 24 hrs of inactivity or it will be removed automatically after 30 days of inactivity.
Yup, your temporary UUiD will be deleted after 30 days of innactivity. Glad everything worked out
For future reference, save a copy of your piaware-config off the Pi as I mentioned earlier - saves a huge amount of grief if you have to either upgrade or rebuild.
FYI - the site is never deleted, it just stops being displayed on your Stats page.
If you go to https://www.flightaware.com/adsb/piaware/claim/UUID
(where UUID is any of your stations), you will see a list of every UUID associated with your account (both working and defunct)
  • The UUID is never deleted from account.
  • The SITE number is deleted from accont
If you configure a new Pi using your old UUID which is out of use for over a month, you wont get back the same Site number. You will get a new Site number.
I just tried it and resurrected a site that had been offline a couple of years - came up with the same Site Number (Site 81771)
Could someone else confirm please?
I just now tested it using my UUID which was obtained 10 years ago (in year 2016). Those days 4-digit Site numbers were issued. This site was abandoned about 4 years ago (late 2022)
Please see #13 in screenshot below.
Using UUID which was abandoned 4 years ago and originally had a 4-digit Site number from 2016, I got a 6-digit Site number (164456), which shows it is a new current number.
Not as straight forward as we thought then.
I created a new site, november last year (261464), so ‘164456’ certainly isn’t current.
How long ago?
You are right, but 164456 being a 6-digit number, it is definitely not the original year 2016 4-digit Site number.
Sorry, 20 was a typo, 2016 was 10 years ago. I have corrected my post now. Thanks for pointing out.
Agreed - it’s neither current nor original - very odd.
My site from early 2016 is 5-digit.
