Have been running ADSBReceiver image successfully for many months - thanks JP! .
However, with pA 3.x now out, thought i’d rerun the ADSBReceiver scripts to update to pA 3.x …
Press enter to continue…Preparing the piaware_builder Git repository…
Entering the piaware_builder git repository directory…
Updating the local piaware_builder git repository…
You are not currently on a branch. Please specify which
branch you want to merge with. See git-pull(1) for details.
git pull <remote> <branch>
Building and installing the PiAware package…
Executing the PiAware build script…
Retrieving 6a883f428912357c252654cb811499e58db87d3a from github.com/flightaware/piaware.git
6a883f4 jessie’s c_rehash doesn’t like multiple certificates per file, split them out.
Retrieving 460debe4d350f06f9c7e54e5400992cac4f1d328 from github.com/flightaware/tcllauncher.git
460debe Update README.md
Retrieving faup1090-2.1-5 from github.com/mutability/dump1090.git
497f88f Don’t match faup1090 tags when generating a version string from git tags.
Retrieving v0.2.4 from github.com/mutability/mlat-client.git
f68b8e3 v0.2.4
Ok, package is ready to be built in ./package
run ‘dpkg-buildpackage -b’ there (or move it to a Pi and do so there, or use pbuilder, etc)
Entering the PiAware build directory…
/home/pi/adsb-receiver/bash/feeders/piaware.sh: line 122: cd: /home/pi/adsb-receiver/build/piaware_builder/package-jessie: No such file or directory
Building the PiAware package…
tail: cannot open ‘debian/changelog’ for reading: No such file or directory
dpkg-buildpackage: error: tail of debian/changelog gave error exit status 1
Installing the PiAware package…
dpkg: error processing archive /home/pi/adsb-receiver/build/piaware_builder/piaware_.deb (–install):
cannot access archive: No such file or directory
Errors were encountered while processing:
Checking that the piaware package was installed properly…
INSTALLATION HALTED!
UNABLE TO INSTALL A REQUIRED PACKAGE.
SETUP HAS BEEN TERMINATED!
Hmmmk… looks like the Performance Graphs in ADSBR may be working - I’ll let it run to get better granularity and confirm.
That said, live maps arent showing any birds, I believe that may be a change in dump1090-mut , I do recall there was some discussion re mapping services etc some time back, but I didnt take note as I wasnt looking to upgrade at the time…?
