when i try to connect to the mysql db from my windows pc:
failed to connect to … :3306
Host"PC" is not allowd to connect to this mysql server.
what can i do?
So far I have found my answer and corrected several things about map page I did not like. **abcd567 **had my answer in a post I finally was able to locate. I now have the Flight Aware map page in mutability just as it appears loading their image file.
Just spun up the version ‘adsb-receiver_2.5.0_dump1090-fa_raspbian-jessie-lite’
The install went smooth and I can see a lot of the expected pages.
My issue is that I do not use a USB stick, I get my BEAST formatted data from another computer on my network that merges all the feeds from my many Raspberry Pi field receivers.
I would like to run a pi with the ADSB Receiver Project on this main feed.
How do I configure the bundled dump1090-fa to get the data from that IP address and port number?
It seems that I can edit the config file by ‘sudo nano /etc/default/dump1090-fa’ but I have spent hours looking on the web and can not find a way to feed it data from another computer?
Thanks for your help, it pointed out the error of my thinking…
(@johnhawkes2030 your command was wrong, but helpfully so).
For those following along, the method and key points are;
‘Relay’ mode is a term that seems to be unique to FlightAware. It does not apply to the ADSB Receiver Project software.
dump1090-fa can not poll another PC for data, the data has to be pushed to the pi running ADSB Receiver Project.
Knowing that, here is what you need to do;
Have another pc running the push software.
This could be beast-splitter, or in my case modeSmixer2.
Add this parameter to the modeSmixer2 bat file;
–outConnect beast:192.168.1.xxx:40006
Note. change the IP address and port number to match that of your ADSB Receiver Pi.
Next, edit your ADSB Receiver Pi dump1090-fa to listen to that port;
The two keys here are --net-only and --net-bi-port
net-only meaning there is no USB RTL and --net-bi-port meaning Beast In and what port number that data will be on.
That should configure things to get your data from the other pc into the Pi.
If you are doing a fresh install on Raspbian image using the method given in First Post of this thread, the Planefinder client and Adsbexchange mlat client both will fail to install, as their versions in script are outdated.
These can be successfully installed by “install.sh” script, if BEFORE running the script (i.e. before the step ./install.sh), the version numbers are manually updated in the file “variables.sh” as shown in remarks in red below:
sudo nano adsb-receiver/bash/variables.sh
SOFTWARE VERSIONS
The ADS-B Receiver Project
PROJECTVERSION=“2.5.0”
FlightAware PiAware
PIAWAREVERSION=“3.1.0” #It may be necessary to change the version from 3.1.0 to 3.5.0. I am not sure about it as I did not build Piaware package from source code. Instead I downloaded the .deb pakage of 3.5.0 by wget command, and installed it by dpkg -i command.
PlaneFinder ADS-B Client
PFCLIENTVERSIONARM=“3.5.461” #Change 3.5.461 to 3.7.20
PFCLIENTVERSIONI386=“3.4.61” #Change 3.4.61 to 3.7.20
Flightradar24 Linux Debian package
FR24CLIENTVERSIONI386=“1.0.18-5”
mlat-client
MLATCLIENTVERSION=“0.2.6” #Change 0.2.6 to 0.2.9
MLATCLIENTTAG=“v0.2.6” #Change v0.2.6 to v0.2.9
