Did you wait 30 minutes before doing. Do it again, shut off the PI for several minutes and turn it on again. Eventually a properly claimed receiver should show on your account. Most of mine too around an hour to appear. The last one I had to do the power cycle trick and then it worked. A reboot doesn’t seem to be long enough. Shut if off, remove power, wait and then turn it back on.
Did it for one hour. Even reset my routeur.
Same issue.
Now weird stuff I have sudo apt-get update - y
Raspi froze.
I unplug re-plug for the tenth time. : now live and feeding on flightaware.com
I just tried to install the package - looks great, except that the graphs for Overall CPU Utilization, Memory Utilization and Disk Usage (/) stopped working after midnight…
pi@piaware:~$ sudo piaware-config -show
allow-auto-updates yes # value set at /boot/piaware-config.txt:110
allow-manual-updates yes # value set at /boot/piaware-config.txt:114
image-type piaware # value set at /usr/share/piaware-support/piaware-image-config.txt:5
manage-config yes # value set at /usr/share/piaware-support/piaware-image-config.txt:4
radarcape-host your-radarcape-hostname # value set at /boot/piaware-config.txt:97
receiver-host your-receiver-hostname # value set at /boot/piaware-config.txt:101
receiver-port 30005 # value set at /boot/piaware-config.txt:102
receiver-type rtlsdr # value set at /boot/piaware-config.txt:88
rfkill no # value set at /boot/piaware-config.txt:121
rtlsdr-device-index 0 # value set at /boot/piaware-config.txt:91
rtlsdr-gain 28.0 # value set at /boot/piaware-config.txt:92
rtlsdr-ppm 0 # value set at /boot/piaware-config.txt:93
wired-address 192.168.1.10 # value set at /boot/piaware-config.txt:26
wired-broadcast 192.168.1.255 # value set at /boot/piaware-config.txt:28
wired-gateway 192.168.1.254 # value set at /boot/piaware-config.txt:29
wired-nameservers “8.8.8.8 8.8.4.4” # value set at /boot/piaware-config.txt:30
wired-netmask 255.255.255.0 # value set at /boot/piaware-config.txt:27
wired-network yes # value set at /boot/piaware-config.txt:18
wired-type dhcp # value set at /boot/piaware-config.txt:22
wireless-address 192.168.0.32 # value set at /boot/piaware-config.txt:65
wireless-broadcast 192.168.1.255 # value set at /boot/piaware-config.txt:67
wireless-gateway 192.168.1.254 # value set at /boot/piaware-config.txt:68
wireless-nameservers “8.8.8.8 8.8.4.4” # value set at /boot/piaware-config.txt:69
wireless-netmask 255.255.255.0 # value set at /boot/piaware-config.txt:66
wireless-network yes # value set at /boot/piaware-config.txt:41
wireless-password # value set at /boot/piaware-config.txt:57
wireless-ssid hippopotamus # value set at /boot/piaware-config.txt:56
wireless-type static # value set at /boot/piaware-config.txt:61
HOW TO SET GAIN VALUE:
Gain value which takes affect, is in file /boot/piaware-config.txt
Either edit file /boot/piaware-config.txt
OR
Give following command (easier):
#set
pi@piaware:~$ sudo piaware-config rtlsdr-gain 32.8
Set rtlsdr-gain to 32.8 in /boot/piaware-config.txt:92
The above method is applicable if you have written Piaware 3.1 img (SD card) on your microSD Card.
If you have not written PIaware 3.1 img, and have written Raspbian Jessie or Armbian (Orange Pi PC) image on your microSD card, and then installed dump1090-fa, the file /boot/piaware-config.txt will not exist. In this case you have to edit the file /etc/default/dump1090-fa to change gain value
Each location and configuration is unique. Some people have turned it down 5-15db and increased their position reports considerably.
The scripts for gain testing are a good start.
That is what is supposed to happen. You start ppup1090 but then close the instance running it. You need to set ppup1090 going in the background so closing the command line does not stop it.
If dump1090 is already starting with Piaware, etc anyway, that script will need modifying for just ppup1090. Will it work? I don’t know but if it does not try asking in the various PP forums.
The scripts are mind mumblingly great, but I have made the same mistake, following two separate upgrades.
During the script we enter Feeder/share code or something like that for FLIGHTRADAR24 and one other, but for FLIGHTAWARE we simply enter our username and password. I thought a lot yesterday and before entering my FA sharecode, not username, first time through. When I saw next entry was “password,” I knew I had screwed up. No big problem, I just reinstalled and all was fine. I know we have to enter the sharecodes during the process and since FA is the first one, I always “bite.” even though it clearly states the entry.
Since I have done this two times in a row, it would be helpful to me, and might be helpful to others to state on the FA entry something like “Password not Sharecode, stupid,” or words to that effect.
For flightaware the best option is to simply leave user name and password blank. Then go to the receiver claim page. Any new receiver reporting in on the same external IP you are using will automatically be associated with your Flightware account. Then turn off the feeder for a minute or two and turn back on and then you will see it associated with your Flightaware account. User name and password only needed when receiver is remote and you cannot connect to the Flightaware website from the same external IP.
