Can anyone please point me in the right direction towards a project where I could build this? I have a spare Pi and a spare e-Paper HAT for the Pi and would love to have one of these up and running
Thanks in advance
Thanks in advance
I have since found some text that was attached to the image as below but it gives no indication as to how to pull the data from a feeder and configure the display correctly so it shows it:
I purchased this Hat for one of my raspberry pi 4b’s. The project was to display ads-b data for the closest aircraft to my location. It would display call sign, relative distance, squawk and a few other statistics. With a bit of custom python code it reads information from a second raspberry pi 4b running an SDR with readsb and tar 1090. I must admit it’s a niche hobby but the display is clear and concise and with it being a hat there’s no messy wiring to contend with. It comfortably runs 24 hours a day and uses minimum power. There’s also a bit of logging or journalling being collected but that’s for another day. Would highly recommend!
Through many hours of googling until late last night (early this morning?) I have got something together. The Pi that has the e-Paper display connected to it is now pulling ADSB data from my other Pi that has the FlightAware dongle.
Issuing the command “sudo systemctl status readsb” on the “display” Pi gives me this: readsb.service - readsb ADS-B receiver
Loaded: loaded (/usr/lib/systemd/system/readsb.service; enabled; preset: enabled)
Active: active (running) since Wed 2026-10-14 10:00:34 BST; 1h 17min ago
Invocation: 9ec24193d50f411bbc5b4ee34db4c872
Docs: https://github.com/wiedehopf/readsb
Main PID: 867 (readsb)
Tasks: 7 (limit: 806)
CPU: 1min 56.592s
CGroup: /system.slice/readsb.service
└─867 /usr/bin/readsb --write-json /run/readsb --quiet --net-only --net-connector 192.168.1.112,30005,beast_in --max-range 450 --w>
Oct 14 10:00:34 ADSB-Monitor readsb[867]: 30002: Raw TCP output port
Oct 14 10:00:34 ADSB-Monitor readsb[867]: 30005: Beast TCP output port
Oct 14 10:00:34 ADSB-Monitor readsb[867]: 30003: SBS TCP output ALL port
Oct 14 10:00:34 ADSB-Monitor readsb[867]: 30001: Raw TCP input port
Oct 14 10:00:34 ADSB-Monitor readsb[867]: 30004: Beast TCP input port
Oct 14 10:00:34 ADSB-Monitor readsb[867]: 30104: Beast TCP input port
Oct 14 10:00:34 ADSB-Monitor readsb[867]: Beast TCP input: Connection to 192.168.1.112 port 30005 failed: Transport endpoint is not connected
Oct 14 10:00:35 ADSB-Monitor readsb[867]: Beast TCP input: Connection to 192.168.1.112 port 30005 failed: Transport endpoint is not connected
Oct 14 10:00:36 ADSB-Monitor readsb[867]: Beast TCP input: Connection established: 192.168.1.112 port 30005
Running this command “journalctl --no-pager -u readsb” gives me this output
Oct 14 10:00:34 ADSB-Monitor systemd[1]: Started readsb.service - readsb ADS-B receiver.
Oct 14 10:00:34 ADSB-Monitor readsb[867]: invoked by: /usr/bin/readsb --write-json /run/readsb --quiet --net-only --net-connector 192.168.1.112,30005,beast_in --max-range 450 --write-json-every 1 --net --net-ri-port 30001 --net-ro-port 30002 --net-sbs-port 30003 --net-bi-port 30004,30104 --net-bo-port 30005 --json-location-accuracy 2 --range-outline-hours 24
Oct 14 10:00:34 ADSB-Monitor readsb[867]: [2026-10-14 10:00:34.570 BST] readsb starting up.
Oct 14 10:00:34 ADSB-Monitor readsb[867]: readsb version: 3.16.17 wiedehopf git: v3.16.17 (committed: Sun Sep 27 10:20:44 2026 0000)
The command “ls -l /run/readsb” gives me this:
total 128
-rw-r–r-- 1 readsb nogroup 10444 Oct 14 11:21 aircraft.binCraft.zst
-rw-r–r-- 1 readsb nogroup 94044 Oct 14 11:21 aircraft.json
drwxr-xr-x 2 readsb nogroup 40 Oct 14 10:00 getState
-rw-r–r-- 1 readsb nogroup 193 Oct 14 10:00 receiver.json
-rw-r–r-- 1 readsb nogroup 4443 Oct 14 11:21 stats.json
-rw-r–r-- 1 readsb nogroup 2975 Oct 14 11:21 stats.prom
-rw-r–r-- 1 readsb nogroup 342 Oct 14 11:21 status.json
-rw-r–r-- 1 readsb nogroup 502 Oct 14 11:21 status.prom
Would you say from a viewpoint of getting the data from the feeder to the display Pi is working or am I missing something ?
I literally spent another entire day of Googling and using Chat GPT and it is working
Will add a photograph to my post Tomorrow
Maybe also describe how you got to the result, that can help others to get to the same point if they would want to enhance their setup ![]()
That e-Paper setup looks amazing! Inspired by your project, I wanted to share how I monitor and visualize aircraft data around my area (Aomori, Japan).
I’m running tar1090 as the base and have built a few custom dashboards on top of it:
Live Aircraft Map (tar1090): Tracking local traffic and coverage.
Upper-Air Temperature & Altitude Monitor: Real-time tracking of aircraft altitude alongside outside air temperature.
Wind Speed & Direction Map: Correlating flight paths with local high-altitude jet streams.
Flight Analytics: Tracking daily and rare flights.
It’s such a fun rabbit hole to dive into. Great job on getting your display up and running!
If only it were that simple I would be happy to but 95% of the configuration and setup came from ChatGPT and each time I hit an error or something that didn’t display I put that back into the same chat and I was given corrective steps.
I have very poor short term memory so don’t recall most of what I did which unfortunately means if ever I want to build another one I will need to take the same route again!
Anyway, here is the finished item which took a LOT of effort. It refreshes every 180 seconds which is the recommended refresh time for e-Paper to prevent burn in etc.
That looks really good and I am sure it took a lot of work!
It was fun getting my e-paper display up and running although pretty much all of the congrats need to to Chat-GPT ![]()
Thanks! To be honest, I built most of these tools with Gemini’s help as well! AI is truly a game-changer for these DIY projects. ![]()
Speaking of which, here is another tool we created together: an All-Days Coverage Overlay! It loads all historical data from tar1090_archive (79 days so far) and overlays the coverage polygons to visualize the maximum reception range over time.
Keep enjoying your e-Paper setup!
I want to share the code in the config file that AI created for me to output from READSB to the e-Paper HAT, whats the best way to do this without the post formatting things oddly?
Best way is to put 3 backticks before and after the code.
See:
Thanks, but that formatting didn’t come out too well. Some parts are formatted while others are not. As a result, the indentations are not correct. Also, some straight quotes are replaced with curly quotes and at least one character is not defined. Probably best to put it on Github or one of the storage sites.
Thanks Jim, will do
Dave
My ADS-B MONITOR has gone through quite a few code revisions and I have now replaced the small e-paper display with a 4.26" display from WaveSure so I wanted to share what it looks like now:
This is the original one with the much smaller display
The latest version with the 4.26" display
Today I spent time getting a nice shiny new 7.5” red,yellow, back and white display and with a lot of help from AI this is what I have :slight_smile
First image is main screen and second image is what shows every other refresh (refreshes every 300 seconds)
