ADS-B flightfeeder under performing
Hello all, ive received my flight feeder from Flightaware, version 11 and 5 metres of cable, connected to ethernet on 1600 meg…Now I have three flight feeders that are my own hardware, raspberry pi’s 4 and 5…both on a 5 metres antenna cable, the flightaware flight feeder is underperforming by almost half compared to my own equipment. The antennas are all high above my house mounted on the chimney, all have a clear view of the sky and surrounding areas, and yet their own equipment is only receiving half the data…Could this be faulty equipment from flightaware…?
Faulty gear tends to be pretty binary.
Check your antenna lead is tight.
Hi Jamie,
The data in the “Nearby Sites” section you are looking at is historical, and an average over a past period. I don’t remember the exact number of days they use. Because your newest system is only 5 days old, it will take time for the new system totals to build up for a good comparison.
If you look at the stats for all 3 of your systems at the same time in different browser tabs, you will see that they are all fairly close together.
If you look at the “Aircraft Reported (All sites)” graph further up the page, you can see all 3 are pretty close together. You can also uncheck “All Sites” to remove the total line, and just display the individual 3 sites.
Regards,
-Dan
Wait at least 15 to 30 days to get an idea of ​​the equipment’s performance in the FlightAware rankings. Check that the cables are okay (as the other user mentioned) and look at your FlightFeeder’s gain settings—specifically, whether they are set to automatic or if the gain is too high or too low.
How are the daily position/aircraft reports between the three sites for the past four days?
