Adding adsbexchange into my Piaware account
Last week I set up a PiAware account and started tracking aircraft. The small antenna is in a second floor window and I see about 10-15 aircraft. I then purchased a ADSBexchange receiver and outdoor antenna. I got it running today and now see over 100 planes up to 125 miles out.
I would like to enter the ADSBexchange info into my PiAware account. Is this possible?
Don’t use the sd-card that comes with it?
It’s just an SDR as far as i know.
Not sure exactly what you bought.
In general i’d recommend https://adsb.im/ as an sd-card image.
Makes it easy to send data to most aggregators (whichever are chosen).
Or you can just switch back to the sd-card you were using previously if you only care for FA.
No. If you actually meant feeding more than one aggregator from the same RPi setup, then the answer is yes.
I did not use the card. I messed up on he wifi password and then nothing worked. I downloaded the new file and got thinks going. Everything works great but I miss the PiAware webpage because I can see where the flight originated and the destination. ADSB is just RAW data
If you are still feeding FlightAware, you can access its webpage, unless you meant PiAware’s SkyAware page.
I am feeding FlightAware with a Pi4 and a noolec and 10 aircraft. The new adsbexchange shows me 100 aircraft. It is a Pi3 with absb stick.
I can send the adsb stick back to amazon or make the adsbexchange feed send to Flightaware
There is definitively something wrong with the Pi4 setup. The Nooelec is an RTL-SDR based stick, I think, switch it with the one that is currently on the Pi3.
Edit: Going back to your first message, you wrote that the PiAware setup has a small indoor antenna, the ADSBExchange an outdoor antenna. If this is still the case, no way to compare the two.
