jlb56
September 5, 2021, 11:13am
21
I did another system apt update and there was 1 more update, done but still got another error message line 235.
Had a look back at the install script and noted this:
collectd isn’t working, trying to install various libpython versions to work around the issue.
jlb56:
ERROR on line number 235
Yeah i’m changing around the install script.
Some systems have broken collectd versions …
Please run the install script one more time.
Also show the output for this:
find /usr/lib/python3* | grep '.so'
jlb56
September 5, 2021, 11:35am
23
His will be long, the output. I also have saved the 40 lines above the error message as requested by the script;
your output
oh no good too many characters, I will have to do it in 2 lots
jlb56
September 5, 2021, 11:36am
24
All done! Graphs available at http://192.168.0.249/graphs1090
It may take up to 10 minutes until the first data is displayed
odroid@odroid:~$ find /usr/lib/python3* | grep ‘.so’
/usr/lib/python3/dist-packages/_dbus_glib_bindings.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/_dbus_bindings.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/psutil/_psosx.py
/usr/lib/python3/dist-packages/psutil/pycache /_psosx.cpython-38.pyc
/usr/lib/python3/dist-packages/psutil/_psutil_posix.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/psutil/_psutil_linux.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/yaml/resolver.py
/usr/lib/python3/dist-packages/yaml/pycache /resolver.cpython-38.pyc
/usr/lib/python3/dist-packages/PIL/_webp.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/PIL/_imagingmorph.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/PIL/_imagingft.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/PIL/_imagingcms.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/PIL/_imaging.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/PIL/_imagingmath.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/requests_unixsocket-0.2.0.egg-info
/usr/lib/python3/dist-packages/requests_unixsocket-0.2.0.egg-info/requires.txt
/usr/lib/python3/dist-packages/requests_unixsocket-0.2.0.egg-info/not-zip-safe
/usr/lib/python3/dist-packages/requests_unixsocket-0.2.0.egg-info/PKG-INFO
/usr/lib/python3/dist-packages/requests_unixsocket-0.2.0.egg-info/top_level.txt
/usr/lib/python3/dist-packages/requests_unixsocket-0.2.0.egg-info/dependency_links.txt
/usr/lib/python3/dist-packages/cupsext.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/markupsafe/_speedups.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/simplejson
/usr/lib/python3/dist-packages/simplejson/tool.py
/usr/lib/python3/dist-packages/simplejson/pycache
/usr/lib/python3/dist-packages/simplejson/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/pycache /scanner.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/pycache /encoder.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/pycache /tool.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/pycache /raw_json.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/pycache /decoder.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/pycache /compat.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/pycache /errors.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/pycache /ordered_dict.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/init .py
/usr/lib/python3/dist-packages/simplejson/decoder.py
/usr/lib/python3/dist-packages/simplejson/encoder.py
/usr/lib/python3/dist-packages/simplejson/tests
/usr/lib/python3/dist-packages/simplejson/tests/test_iterable.py
/usr/lib/python3/dist-packages/simplejson/tests/test_unicode.py
/usr/lib/python3/dist-packages/simplejson/tests/test_pass1.py
/usr/lib/python3/dist-packages/simplejson/tests/pycache
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_unicode.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_pass2.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_pass1.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_separators.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_raw_json.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_encode_for_html.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_iterable.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_indent.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_dump.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_errors.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_decode.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_check_circular.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_recursion.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_scanstring.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_speedups.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_decimal.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_subclass.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_bitsize_int_as_string.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_item_sort_key.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_str_subclass.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_pass3.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_fail.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_encode_basestring_ascii.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_for_json.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_namedtuple.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_tool.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_bigint_as_string.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_float.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_tuple.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/pycache /test_default.cpython-38.pyc
/usr/lib/python3/dist-packages/simplejson/tests/test_default.py
/usr/lib/python3/dist-packages/simplejson/tests/init .py
/usr/lib/python3/dist-packages/simplejson/tests/test_fail.py
/usr/lib/python3/dist-packages/simplejson/tests/test_speedups.py
/usr/lib/python3/dist-packages/simplejson/tests/test_scanstring.py
/usr/lib/python3/dist-packages/simplejson/tests/test_check_circular.py
/usr/lib/python3/dist-packages/simplejson/tests/test_tuple.py
/usr/lib/python3/dist-packages/simplejson/tests/test_pass2.py
/usr/lib/python3/dist-packages/simplejson/tests/test_encode_basestring_ascii.py
/usr/lib/python3/dist-packages/simplejson/tests/test_bitsize_int_as_string.py
/usr/lib/python3/dist-packages/simplejson/tests/test_decimal.py
/usr/lib/python3/dist-packages/simplejson/tests/test_encode_for_html.py
/usr/lib/python3/dist-packages/simplejson/tests/test_recursion.py
/usr/lib/python3/dist-packages/simplejson/tests/test_tool.py
/usr/lib/python3/dist-packages/simplejson/tests/test_bigint_as_string.py
/usr/lib/python3/dist-packages/simplejson/tests/test_item_sort_key.py
/usr/lib/python3/dist-packages/simplejson/tests/test_for_json.py
/usr/lib/python3/dist-packages/simplejson/tests/test_float.py
/usr/lib/python3/dist-packages/simplejson/tests/test_indent.py
/usr/lib/python3/dist-packages/simplejson/tests/test_raw_json.py
/usr/lib/python3/dist-packages/simplejson/tests/test_str_subclass.py
/usr/lib/python3/dist-packages/simplejson/tests/test_separators.py
/usr/lib/python3/dist-packages/simplejson/tests/test_namedtuple.py
/usr/lib/python3/dist-packages/simplejson/tests/test_decode.py
/usr/lib/python3/dist-packages/simplejson/tests/test_dump.py
/usr/lib/python3/dist-packages/simplejson/tests/test_errors.py
/usr/lib/python3/dist-packages/simplejson/tests/test_pass3.py
/usr/lib/python3/dist-packages/simplejson/tests/test_subclass.py
/usr/lib/python3/dist-packages/simplejson/errors.py
/usr/lib/python3/dist-packages/simplejson/compat.py
/usr/lib/python3/dist-packages/simplejson/_speedups.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/simplejson/scanner.py
/usr/lib/python3/dist-packages/simplejson/raw_json.py
/usr/lib/python3/dist-packages/simplejson/ordered_dict.py
/usr/lib/python3/dist-packages/aptsources
/usr/lib/python3/dist-packages/aptsources/sourceslist.py
/usr/lib/python3/dist-packages/aptsources/pycache
/usr/lib/python3/dist-packages/aptsources/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/aptsources/pycache /distro.cpython-38.pyc
/usr/lib/python3/dist-packages/aptsources/pycache /distinfo.cpython-38.pyc
/usr/lib/python3/dist-packages/aptsources/pycache /sourceslist.cpython-38.pyc
/usr/lib/python3/dist-packages/aptsources/init .py
/usr/lib/python3/dist-packages/aptsources/distro.py
/usr/lib/python3/dist-packages/aptsources/distinfo.py
/usr/lib/python3/dist-packages/libfuturize/fixes/fix_absolute_import.py
/usr/lib/python3/dist-packages/libfuturize/fixes/pycache /fix_absolute_import.cpython-38.pyc
/usr/lib/python3/dist-packages/ldb.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/systemd/id128.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/systemd/login.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/systemd/_journal.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/systemd/_reader.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/systemd/_daemon.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/nacl/bindings/pycache /sodium_core.cpython-38.pyc
/usr/lib/python3/dist-packages/nacl/bindings/sodium_core.py
/usr/lib/python3/dist-packages/nacl/_sodium.abi3.so
/usr/lib/python3/dist-packages/netifaces.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/apt_pkg.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/oauthlib/oauth1/rfc5849/endpoints/pycache /resource.cpython-38.pyc
/usr/lib/python3/dist-packages/oauthlib/oauth1/rfc5849/endpoints/resource.py
/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/grant_types/pycache /resource_owner_password_credentials.cpython-38.pyc
/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/grant_types/resource_owner_password_credentials.py
/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/endpoints/pycache /resource.cpython-38.pyc
/usr/lib/python3/dist-packages/oauthlib/oauth2/rfc6749/endpoints/resource.py
/usr/lib/python3/dist-packages/pcardext.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/requests_unixsocket/pycache
/usr/lib/python3/dist-packages/requests_unixsocket/pycache /testutils.cpython-38.pyc
/usr/lib/python3/dist-packages/requests_unixsocket/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/requests_unixsocket/pycache /adapters.cpython-38.pyc
/usr/lib/python3/dist-packages/requests_unixsocket/init .py
/usr/lib/python3/dist-packages/requests_unixsocket/testutils.py
/usr/lib/python3/dist-packages/requests_unixsocket/adapters.py
/usr/lib/python3/dist-packages/samba/werror.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/net.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/security.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/netbios.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dsdb_dns.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/param.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/security.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/epmapper.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/dfs.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/drsuapi.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/dcerpc.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/dnsserver.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/dns.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/ntlmssp.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/witness.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/idmap.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/messaging.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/windows_event_ids.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/server_id.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/preg.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/atsvc.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/initshutdown.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/irpc.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/drsblobs.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/misc.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/wkssvc.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/winbind.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/lsa.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/samr.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/echo.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/spoolss.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/srvsvc.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/dnsp.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/svcctl.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/auth.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/unixinfo.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/krb5pac.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/netlogon.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/mgmt.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/smb_acl.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/base.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/winreg.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/nbt.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/winspool.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/dcerpc/xattr.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/xattr_native.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/messaging.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/samba3/param.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/samba3/libsmb_samba_internal.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/samba3/passdb.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/samba3/smbd.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/xattr_tdb.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/policy.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/gensec.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/_ldb.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/tests/pycache /source.cpython-38.pyc
/usr/lib/python3/dist-packages/samba/tests/pycache /pso.cpython-38.pyc
/usr/lib/python3/dist-packages/samba/tests/blackbox/pycache /netads_json.cpython-38.pyc
/usr/lib/python3/dist-packages/samba/tests/blackbox/netads_json.py
/usr/lib/python3/dist-packages/samba/tests/source.py
/usr/lib/python3/dist-packages/samba/tests/pso.py
/usr/lib/python3/dist-packages/samba/dsdb.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/ntstatus.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/netcmd/pycache /pso.cpython-38.pyc
/usr/lib/python3/dist-packages/samba/netcmd/pso.py
/usr/lib/python3/dist-packages/samba/registry.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/auth.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/posix_eadb.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/gpo.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/third_party/iso8601
/usr/lib/python3/dist-packages/samba/third_party/iso8601/pycache
/usr/lib/python3/dist-packages/samba/third_party/iso8601/pycache /test_iso8601.cpython-38.pyc
/usr/lib/python3/dist-packages/samba/third_party/iso8601/pycache /iso8601.cpython-38.pyc
/usr/lib/python3/dist-packages/samba/third_party/iso8601/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/samba/third_party/iso8601/init .py
/usr/lib/python3/dist-packages/samba/third_party/iso8601/iso8601.py
/usr/lib/python3/dist-packages/samba/third_party/iso8601/test_iso8601.py
/usr/lib/python3/dist-packages/samba/credentials.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/_glue.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/samba/crypto.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/tdb.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/pkg_resources
/usr/lib/python3/dist-packages/pkg_resources/extern
/usr/lib/python3/dist-packages/pkg_resources/extern/pycache
/usr/lib/python3/dist-packages/pkg_resources/extern/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/extern/init .py
/usr/lib/python3/dist-packages/pkg_resources/pycache
/usr/lib/python3/dist-packages/pkg_resources/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/pycache /py31compat.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/pycache /py2_warn.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/init .py
/usr/lib/python3/dist-packages/pkg_resources/py31compat.py
/usr/lib/python3/dist-packages/pkg_resources/py2_warn.py
/usr/lib/python3/dist-packages/pkg_resources/_vendor
/usr/lib/python3/dist-packages/pkg_resources/_vendor/pycache
/usr/lib/python3/dist-packages/pkg_resources/_vendor/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/pycache /six.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/pycache /appdirs.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/pycache /pyparsing.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/init .py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/pyparsing.py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/appdirs.py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/markers.py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/pycache
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/pycache /markers.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/pycache /_structures.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/pycache /_compat.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/pycache /utils.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/pycache /version.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/pycache /about .cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/pycache /specifiers.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/pycache /requirements.cpython-38.pyc
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/init .py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/requirements.py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/specifiers.py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/utils.py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/_structures.py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/about .py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/_compat.py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/version.py
/usr/lib/python3/dist-packages/pkg_resources/_vendor/six.py
/usr/lib/python3/dist-packages/netifaces.cpython-38d-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Util/_counter.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Util/strxor.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Hash/_MD2.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Hash/_SHA224.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Hash/_SHA256.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Hash/_SHA512.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Hash/_SHA384.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Hash/_RIPEMD160.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Hash/_MD4.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Cipher/_CAST.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Cipher/_AES.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Cipher/_DES.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Cipher/_ARC4.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Cipher/_Blowfish.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Cipher/_DES3.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Cipher/_ARC2.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/Cipher/_XOR.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Crypto/PublicKey/_fastmath.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/_cffi_backend.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/softwareproperties
/usr/lib/python3/dist-packages/softwareproperties/pycache
/usr/lib/python3/dist-packages/softwareproperties/pycache /MirrorTest.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /AptAuth.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /LivepatchSnap.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /ppa.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /cloudarchive.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /distro.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /LivepatchService.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /GoaAuth.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /CountryInformation.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /shortcuts.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/pycache /SoftwareProperties.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/init .py
/usr/lib/python3/dist-packages/softwareproperties/distro.py
/usr/lib/python3/dist-packages/softwareproperties/dbus
/usr/lib/python3/dist-packages/softwareproperties/dbus/pycache
/usr/lib/python3/dist-packages/softwareproperties/dbus/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/dbus/pycache /SoftwarePropertiesDBus.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/dbus/init .py
/usr/lib/python3/dist-packages/softwareproperties/dbus/SoftwarePropertiesDBus.py
/usr/lib/python3/dist-packages/softwareproperties/ppa.py
/usr/lib/python3/dist-packages/softwareproperties/CountryInformation.py
/usr/lib/python3/dist-packages/softwareproperties/cloudarchive.py
/usr/lib/python3/dist-packages/softwareproperties/shortcuts.py
/usr/lib/python3/dist-packages/softwareproperties/MirrorTest.py
/usr/lib/python3/dist-packages/softwareproperties/LivepatchService.py
/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py
/usr/lib/python3/dist-packages/softwareproperties/AptAuth.py
/usr/lib/python3/dist-packages/softwareproperties/gtk
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /CdromProgress.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /dialogs.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /SoftwarePropertiesGtk.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /SimpleGtkbuilderApp.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /DialogEdit.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /utils.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /LivepatchPage.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /DialogAdd.cpython-38.pyc
jlb56
September 5, 2021, 11:37am
25
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /DialogCacheOutdated.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /DialogAddSourcesList.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /DialogAuth.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /DialogLivepatchError.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/pycache /DialogMirror.cpython-38.pyc
/usr/lib/python3/dist-packages/softwareproperties/gtk/init .py
/usr/lib/python3/dist-packages/softwareproperties/gtk/DialogCacheOutdated.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/DialogAddSourcesList.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/DialogAuth.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/DialogEdit.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/CdromProgress.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/utils.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/DialogMirror.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/SimpleGtkbuilderApp.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/DialogAdd.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/DialogLivepatchError.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/dialogs.py
/usr/lib/python3/dist-packages/softwareproperties/gtk/LivepatchPage.py
/usr/lib/python3/dist-packages/softwareproperties/GoaAuth.py
/usr/lib/python3/dist-packages/softwareproperties/LivepatchSnap.py
/usr/lib/python3/dist-packages/simplejson-3.16.0.egg-info
/usr/lib/python3/dist-packages/bcrypt/_bcrypt.abi3.so
/usr/lib/python3/dist-packages/Xlib/pycache /Xcursorfont.cpython-38.pyc
/usr/lib/python3/dist-packages/Xlib/Xcursorfont.py
/usr/lib/python3/dist-packages/Xlib/xobject/pycache /resource.cpython-38.pyc
/usr/lib/python3/dist-packages/Xlib/xobject/pycache /cursor.cpython-38.pyc
/usr/lib/python3/dist-packages/Xlib/xobject/cursor.py
/usr/lib/python3/dist-packages/Xlib/xobject/resource.py
/usr/lib/python3/dist-packages/gi/_gi_cairo.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/gi/_gi.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/httplib2/pycache /socks.cpython-38.pyc
/usr/lib/python3/dist-packages/httplib2/socks.py
/usr/lib/python3/dist-packages/Onboard/pycache /HardwareSensorTracker.cpython-38.pyc
/usr/lib/python3/dist-packages/Onboard/HardwareSensorTracker.py
/usr/lib/python3/dist-packages/Onboard/pypredict/lm.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/Onboard/osk.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/launchpadlib/testing/pycache /resources.cpython-38.pyc
/usr/lib/python3/dist-packages/launchpadlib/testing/resources.py
/usr/lib/python3/dist-packages/aptdaemon/pycache /console.cpython-38.pyc
/usr/lib/python3/dist-packages/aptdaemon/console.py
/usr/lib/python3/dist-packages/dateutil/parser/pycache /isoparser.cpython-38.pyc
/usr/lib/python3/dist-packages/dateutil/parser/isoparser.py
/usr/lib/python3/dist-packages/click/pycache /_winconsole.cpython-38.pyc
/usr/lib/python3/dist-packages/click/_winconsole.py
/usr/lib/python3/dist-packages/brlapi.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/wadllib/pycache /iso_strptime.cpython-38.pyc
/usr/lib/python3/dist-packages/wadllib/iso_strptime.py
/usr/lib/python3/dist-packages/wadllib/tests/data/root.json
/usr/lib/python3/dist-packages/wadllib/tests/data/personset.json
/usr/lib/python3/dist-packages/wadllib/tests/data/person-limi.json
/usr/lib/python3/dist-packages/wadllib/tests/data/personset-page2.json
/usr/lib/python3/dist-packages/gpg/_gpgme.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/_yaml.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/duplicity/_librsync.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/pymacaroons/serializers/pycache /json_serializer.cpython-38.pyc
/usr/lib/python3/dist-packages/pymacaroons/serializers/json_serializer.py
/usr/lib/python3/dist-packages/talloc.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/youtube_dl/pycache /socks.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/extractor/soundgasm.py
/usr/lib/python3/dist-packages/youtube_dl/extractor/pycache /microsoftvirtualacademy.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/extractor/pycache /soundcloud.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/extractor/pycache /sonyliv.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/extractor/pycache /thisoldhouse.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/extractor/pycache /southpark.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/extractor/pycache /sohu.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/extractor/pycache /soundgasm.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/extractor/pycache /freesound.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/extractor/freesound.py
/usr/lib/python3/dist-packages/youtube_dl/extractor/soundcloud.py
/usr/lib/python3/dist-packages/youtube_dl/extractor/sohu.py
/usr/lib/python3/dist-packages/youtube_dl/extractor/thisoldhouse.py
/usr/lib/python3/dist-packages/youtube_dl/extractor/southpark.py
/usr/lib/python3/dist-packages/youtube_dl/extractor/microsoftvirtualacademy.py
/usr/lib/python3/dist-packages/youtube_dl/extractor/sonyliv.py
/usr/lib/python3/dist-packages/youtube_dl/postprocessor
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/common.py
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/pycache
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/pycache /common.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/pycache /embedthumbnail.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/pycache /xattrpp.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/pycache /ffmpeg.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/pycache /execafterdownload.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/pycache /metadatafromtitle.cpython-38.pyc
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/init .py
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/embedthumbnail.py
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/metadatafromtitle.py
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/execafterdownload.py
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/xattrpp.py
/usr/lib/python3/dist-packages/youtube_dl/postprocessor/ffmpeg.py
/usr/lib/python3/dist-packages/youtube_dl/socks.py
/usr/lib/python3/dist-packages/google/protobuf/pycache /json_format.cpython-38.pyc
/usr/lib/python3/dist-packages/google/protobuf/pycache /source_context_pb2.cpython-38.pyc
/usr/lib/python3/dist-packages/google/protobuf/internal/json_format_test.py
/usr/lib/python3/dist-packages/google/protobuf/internal/pycache /json_format_test.cpython-38.pyc
/usr/lib/python3/dist-packages/google/protobuf/internal/_api_implementation.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/google/protobuf/json_format.py
/usr/lib/python3/dist-packages/google/protobuf/util/pycache /json_format_proto3_pb2.cpython-38.pyc
/usr/lib/python3/dist-packages/google/protobuf/util/json_format_proto3_pb2.py
/usr/lib/python3/dist-packages/google/protobuf/source_context_pb2.py
/usr/lib/python3/dist-packages/google/protobuf/pyext/_message.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/hpmudext.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/future/backports/pycache /socketserver.cpython-38.pyc
/usr/lib/python3/dist-packages/future/backports/pycache /socket.cpython-38.pyc
/usr/lib/python3/dist-packages/future/backports/socketserver.py
/usr/lib/python3/dist-packages/future/backports/socket.py
/usr/lib/python3/dist-packages/future/moves/pycache /socketserver.cpython-38.pyc
/usr/lib/python3/dist-packages/future/moves/socketserver.py
/usr/lib/python3/dist-packages/cairo/_cairo.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/mako/ext/preprocessors.py
/usr/lib/python3/dist-packages/mako/ext/pycache /preprocessors.cpython-38.pyc
/usr/lib/python3/dist-packages/lockfile-0.12.2.egg-info/pbr.json
/usr/lib/python3/dist-packages/cryptography/hazmat/bindings/_constant_time.abi3.so
/usr/lib/python3/dist-packages/cryptography/hazmat/bindings/_openssl.abi3.so
/usr/lib/python3/dist-packages/cryptography/hazmat/bindings/_padding.abi3.so
/usr/lib/python3/dist-packages/scanext.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/setproctitle.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/apt_inst.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/lazr/restfulclient/_json.py
/usr/lib/python3/dist-packages/lazr/restfulclient/pycache /resource.cpython-38.pyc
/usr/lib/python3/dist-packages/lazr/restfulclient/pycache /_json.cpython-38.pyc
/usr/lib/python3/dist-packages/lazr/restfulclient/resource.py
/usr/lib/python3/dist-packages/xattr.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/_blueman.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/reportlab/lib/_rl_accel.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/reportlab/graphics/_renderPM.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3/dist-packages/urllib3/contrib/pycache /socks.cpython-38.pyc
/usr/lib/python3/dist-packages/urllib3/contrib/socks.py
/usr/lib/python3/dist-packages/orca/backends/pycache /json_backend.cpython-38.pyc
/usr/lib/python3/dist-packages/orca/backends/json_backend.py
/usr/lib/python3/dist-packages/orca/pycache /sound_generator.cpython-38.pyc
/usr/lib/python3/dist-packages/orca/pycache /sound.cpython-38.pyc
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/speech_generator.py
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/pycache
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/pycache /braille_generator.cpython-38.pyc
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/pycache /script_utilities.cpython-38.pyc
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/pycache /init .cpython-38.pyc
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/pycache /formatting.cpython-38.pyc
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/pycache /spellcheck.cpython-38.pyc
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/pycache /script.cpython-38.pyc
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/pycache /speech_generator.cpython-38.pyc
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/init .py
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/spellcheck.py
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/braille_generator.py
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/script_utilities.py
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/formatting.py
/usr/lib/python3/dist-packages/orca/scripts/apps/soffice/script.py
/usr/lib/python3/dist-packages/orca/scripts/web/pycache /sound_generator.cpython-38.pyc
/usr/lib/python3/dist-packages/orca/scripts/web/sound_generator.py
/usr/lib/python3/dist-packages/orca/sound.py
/usr/lib/python3/dist-packages/orca/sound_generator.py
/usr/lib/python3/dist-packages/cups.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/pycache /socketserver.cpython-38.pyc
/usr/lib/python3.8/pycache /socket.cpython-38.pyc
/usr/lib/python3.8/asyncio/pycache /trsock.cpython-38.pyc
/usr/lib/python3.8/asyncio/trsock.py
/usr/lib/python3.8/lib-dynload/_ctypes_test.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_queue.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/audioop.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_curses.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_hashlib.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_ctypes.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/resource.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_sqlite3.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_testmultiphase.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_multibytecodec.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_lzma.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_testimportmultiple.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/readline.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_codecs_iso2022.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/nis.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_ssl.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/mmap.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_codecs_jp.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_codecs_cn.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/termios.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_multiprocessing.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_uuid.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_codecs_kr.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_testbuffer.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_asyncio.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_lsprof.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_xxsubinterpreters.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_crypt.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_bz2.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_codecs_hk.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_testinternalcapi.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_decimal.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/xxlimited.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_codecs_tw.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_posixshmem.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_opcode.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/parser.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_contextvars.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_curses_panel.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_dbm.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/ossaudiodev.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_xxtestfuzz.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_json.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/lib-dynload/_testcapi.cpython-38-aarch64-linux-gnu.so
/usr/lib/python3.8/importlib/pycache /resources.cpython-38.pyc
/usr/lib/python3.8/importlib/resources.py
/usr/lib/python3.8/socketserver.py
/usr/lib/python3.8/config-3.8-aarch64-linux-gnu/libpython3.8.so
/usr/lib/python3.8/encodings/iso2022_kr.py
/usr/lib/python3.8/encodings/iso2022_jp_ext.py
/usr/lib/python3.8/encodings/iso2022_jp.py
/usr/lib/python3.8/encodings/iso8859_2.py
/usr/lib/python3.8/encodings/iso8859_3.py
/usr/lib/python3.8/encodings/pycache /iso2022_jp_1.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso2022_jp_ext.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_4.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_13.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_10.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_15.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso2022_kr.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_1.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_5.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso2022_jp_3.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_11.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_8.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_14.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_6.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_9.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_2.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_7.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso2022_jp.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_3.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso2022_jp_2.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso2022_jp_2004.cpython-38.pyc
/usr/lib/python3.8/encodings/pycache /iso8859_16.cpython-38.pyc
/usr/lib/python3.8/encodings/iso2022_jp_3.py
/usr/lib/python3.8/encodings/iso8859_7.py
/usr/lib/python3.8/encodings/iso8859_4.py
/usr/lib/python3.8/encodings/iso2022_jp_2.py
/usr/lib/python3.8/encodings/iso8859_15.py
/usr/lib/python3.8/encodings/iso8859_10.py
/usr/lib/python3.8/encodings/iso8859_5.py
/usr/lib/python3.8/encodings/iso2022_jp_1.py
/usr/lib/python3.8/encodings/iso8859_8.py
/usr/lib/python3.8/encodings/iso8859_1.py
/usr/lib/python3.8/encodings/iso8859_6.py
/usr/lib/python3.8/encodings/iso2022_jp_2004.py
/usr/lib/python3.8/encodings/iso8859_14.py
/usr/lib/python3.8/encodings/iso8859_9.py
/usr/lib/python3.8/encodings/iso8859_11.py
/usr/lib/python3.8/encodings/iso8859_13.py
/usr/lib/python3.8/encodings/iso8859_16.py
/usr/lib/python3.8/socket.py
/usr/lib/python3.8/multiprocessing/pycache /resource_tracker.cpython-38.pyc
/usr/lib/python3.8/multiprocessing/pycache /resource_sharer.cpython-38.pyc
/usr/lib/python3.8/multiprocessing/resource_tracker.py
/usr/lib/python3.8/multiprocessing/resource_sharer.py
/usr/lib/python3.8/json
/usr/lib/python3.8/json/tool.py
/usr/lib/python3.8/json/pycache
/usr/lib/python3.8/json/pycache /init .cpython-38.pyc
/usr/lib/python3.8/json/pycache /scanner.cpython-38.pyc
/usr/lib/python3.8/json/pycache /encoder.cpython-38.pyc
/usr/lib/python3.8/json/pycache /tool.cpython-38.pyc
/usr/lib/python3.8/json/pycache /decoder.cpython-38.pyc
/usr/lib/python3.8/json/init .py
/usr/lib/python3.8/json/decoder.py
/usr/lib/python3.8/json/encoder.py
/usr/lib/python3.8/json/scanner.py
/usr/lib/python3.9/config-3.9-aarch64-linux-gnu/libpython3.9.so
/usr/lib/python3.9/asyncio/trsock.py
/usr/lib/python3.9/lib-dynload/_json.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_curses.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_hashlib.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/audioop.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_posixshmem.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_multibytecodec.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_ctypes_test.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_bz2.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_queue.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_testbuffer.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_testcapi.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_xxtestfuzz.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_codecs_jp.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_asyncio.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/parser.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_codecs_cn.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/nis.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_decimal.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_sqlite3.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/xxlimited.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/readline.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_ssl.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/mmap.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_codecs_tw.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/resource.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_uuid.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_zoneinfo.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_codecs_hk.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_multiprocessing.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_testmultiphase.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_xxsubinterpreters.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/termios.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_testimportmultiple.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_opcode.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_lsprof.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_crypt.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_ctypes.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_codecs_kr.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_codecs_iso2022.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_contextvars.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_curses_panel.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_dbm.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_testinternalcapi.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/ossaudiodev.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/lib-dynload/_lzma.cpython-39-aarch64-linux-gnu.so
/usr/lib/python3.9/importlib/resources.py
/usr/lib/python3.9/socketserver.py
/usr/lib/python3.9/encodings/iso2022_kr.py
/usr/lib/python3.9/encodings/iso2022_jp_ext.py
/usr/lib/python3.9/encodings/iso2022_jp.py
/usr/lib/python3.9/encodings/iso8859_2.py
/usr/lib/python3.9/encodings/iso8859_3.py
/usr/lib/python3.9/encodings/iso2022_jp_3.py
/usr/lib/python3.9/encodings/iso8859_7.py
/usr/lib/python3.9/encodings/iso8859_4.py
/usr/lib/python3.9/encodings/iso2022_jp_2.py
/usr/lib/python3.9/encodings/iso8859_15.py
/usr/lib/python3.9/encodings/iso8859_10.py
/usr/lib/python3.9/encodings/iso8859_5.py
/usr/lib/python3.9/encodings/iso2022_jp_1.py
/usr/lib/python3.9/encodings/iso8859_8.py
/usr/lib/python3.9/encodings/iso8859_1.py
/usr/lib/python3.9/encodings/iso8859_6.py
/usr/lib/python3.9/encodings/iso2022_jp_2004.py
/usr/lib/python3.9/encodings/iso8859_14.py
/usr/lib/python3.9/encodings/iso8859_9.py
/usr/lib/python3.9/encodings/iso8859_11.py
/usr/lib/python3.9/encodings/iso8859_13.py
/usr/lib/python3.9/encodings/iso8859_16.py
/usr/lib/python3.9/socket.py
/usr/lib/python3.9/multiprocessing/resource_tracker.py
/usr/lib/python3.9/multiprocessing/resource_sharer.py
/usr/lib/python3.9/test/support/socket_helper.py
/usr/lib/python3.9/json
/usr/lib/python3.9/json/tool.py
/usr/lib/python3.9/json/init .py
/usr/lib/python3.9/json/decoder.py
/usr/lib/python3.9/json/encoder.py
/usr/lib/python3.9/json/scanner.py
odroid@odroid:~$
thats all of it
jlb56
September 5, 2021, 11:40am
27
Here are the 40 lines as requested by the script error:
Showing the log for collectd using this command: journalctl --no-pager -u collec td | tail -n40
Sep 05 21:25:56 odroid collectd[13028]: plugin_load: plugin “aggregation” succes sfully loaded.
Sep 05 21:25:56 odroid collectd[13028]: plugin_load: plugin “match_regex” succes sfully loaded.
Sep 05 21:25:56 odroid collectd[13028]: plugin_load: plugin “df” successfully lo aded.
Sep 05 21:25:56 odroid collectd[13028]: plugin_load: plugin “disk” successfully loaded.
Sep 05 21:25:56 odroid collectd[13028]: dlopen(“/usr/lib/collectd/python.so”) fa iled: /usr/lib/collectd/python.so: undefined symbol: PyFloat_Type. The most comm on cause for this problem is missing dependencies. Use ldd(1) to check the depen dencies of the plugin / shared object.
Sep 05 21:25:56 odroid collectd[13028]: ERROR: dlopen(“/usr/lib/collectd/python. so”) failed: /usr/lib/collectd/python.so: undefined symbol: PyFloat_Type. The mo st common cause for this problem is missing dependencies. Use ldd(1) to check th e dependencies of the plugin / shared object.
Sep 05 21:25:56 odroid collectd[13028]: Error: Parsing the config file failed!
Sep 05 21:25:56 odroid collectd[13028]: plugin_load: Load plugin “python” failed with status 2.
Sep 05 21:25:56 odroid collectd[13028]: Found a configuration for the python' p lugin, but the plugin isn't loaded or didn't register a configuration callback. Sep 05 21:25:56 odroid collectd[13028]: Plugin python failed to handle option Mo dulePath, return code: -1 Sep 05 21:25:56 odroid systemd[1]: collectd.service: Main process exited, code=e xited, status=1/FAILURE Sep 05 21:25:56 odroid collectd[13029]: /run/collectd//localhost doesn't have th e expected minimum number of files or doesn't exist! Sep 05 21:25:56 odroid collectd[13029]: not writing contents to disk! Sep 05 21:25:56 odroid systemd[1]: collectd.service: Control process exited, cod e=exited, status=1/FAILURE Sep 05 21:25:56 odroid systemd[1]: collectd.service: Failed with result 'exit-co de'. Sep 05 21:25:56 odroid systemd[1]: Failed to start Statistics collection and mon itoring daemon. Sep 05 21:26:05 odroid systemd[1]: Stopped Statistics collection and monitoring daemon. Sep 05 21:26:05 odroid systemd[1]: Starting Statistics collection and monitoring daemon... Sep 05 21:26:05 odroid collectd[13647]: copying DB from disk to /run/collectd Sep 05 21:26:05 odroid collectd[13655]: plugin_load: plugin "syslog" successfull y loaded. Sep 05 21:26:05 odroid collectd[13655]: plugin_load: plugin "rrdtool" successful ly loaded. Sep 05 21:26:05 odroid collectd[13655]: plugin_load: plugin "table" successfully loaded. Sep 05 21:26:05 odroid collectd[13655]: plugin_load: plugin "interface" successf ully loaded. Sep 05 21:26:05 odroid collectd[13655]: plugin_load: plugin "cpu" successfully l oaded. Sep 05 21:26:05 odroid collectd[13655]: plugin_load: plugin "aggregation" succes sfully loaded. Sep 05 21:26:05 odroid collectd[13655]: plugin_load: plugin "match_regex" succes sfully loaded. Sep 05 21:26:05 odroid collectd[13655]: plugin_load: plugin "df" successfully lo aded. Sep 05 21:26:05 odroid collectd[13655]: plugin_load: plugin "disk" successfully loaded. Sep 05 21:26:05 odroid collectd[13655]: dlopen("/usr/lib/collectd/python.so") fa iled: /usr/lib/collectd/python.so: undefined symbol: PyFloat_Type. The most comm on cause for this problem is missing dependencies. Use ldd(1) to check the depen dencies of the plugin / shared object. Sep 05 21:26:05 odroid collectd[13655]: ERROR: dlopen("/usr/lib/collectd/python. so") failed: /usr/lib/collectd/python.so: undefined symbol: PyFloat_Type. The mo st common cause for this problem is missing dependencies. Use ldd(1) to check th e dependencies of the plugin / shared object. Sep 05 21:26:05 odroid collectd[13655]: Error: Parsing the config file failed! Sep 05 21:26:05 odroid collectd[13655]: plugin_load: Load plugin "python" failed with status 2. Sep 05 21:26:05 odroid collectd[13655]: Found a configuration for the
python’ p lugin, but the plugin isn’t loaded or didn’t register a configuration callback.
Sep 05 21:26:05 odroid collectd[13655]: Plugin python failed to handle option Mo dulePath, return code: -1
Sep 05 21:26:05 odroid systemd[1]: collectd.service: Main process exited, code=e xited, status=1/FAILURE
Sep 05 21:26:05 odroid collectd[13656]: /run/collectd//localhost doesn’t have th e expected minimum number of files or doesn’t exist!
Sep 05 21:26:05 odroid collectd[13656]: not writing contents to disk!
Sep 05 21:26:05 odroid systemd[1]: collectd.service: Control process exited, cod e=exited, status=1/FAILURE
Sep 05 21:26:05 odroid systemd[1]: collectd.service: Failed with result ‘exit-co de’.
Sep 05 21:26:05 odroid systemd[1]: Failed to start Statistics collection and mon itoring daemon.
collectd still isn’t working, you can try and rerun the install script at some o ther time.
Or report this issue with the full 40 lines above.
jlb56
September 5, 2021, 11:41am
28
Sorry that last one didn’t paste as it should have
Sorry… didn’t see this reply.
echo "LD_PRELOAD=/usr/lib/python3.8/config-3.8-aarch64-linux-gnu/libpython3.8.so" | sudo tee -a /etc/default/collectd
sudo systemctl restart collectd
Let’s try the above.
(Similar to this but for your architecture: GitHub - wiedehopf/graphs1090: Graphs for readsb / dump1090-fa / dump1090 (based on dump1090-tools by mutability) )
Also if you need to post more long text, i’d recommend posting a link to the https://pastebin.com/
jlb56
September 5, 2021, 8:35pm
30
I ran those 2 lines, got this warning after the 2nd script:
Warning: The unit file, source configuration file or drop-ins of collectd.service changed on disk. Run ‘systemctl daemon-reload’ to reload units.
Do I need to do that reload??
jlb56
September 5, 2021, 8:40pm
31
wiedehopf:
Houston, we have lift off, thanks and working
jlb56
September 5, 2021, 10:07pm
32
Now in the future, do I need to use this script in the future if I have the same problem with any re installs??
You’d need to find the right file for that box.
That’s what the find was for. The grep just missed a \ … '\.so'
which would have produced less output.
Just don’t use distributions where collectd doesn’t work out of the box.
apt dist-upgrade might have helped.
Finally had some time to start troubleshooting why Graphs1090 was not working on the new v6 installs I did last week. Found this and just did the reinstall and all three are working.
@wiedehopf really deserves credit for the amazing support they provide this community!
I run two versions on Ubuntu.
One native on an Atom PC and the other in a VMWare virtual machine using an Ubuntu VM appliance.
Everything worked but I could never get Graphs to load the images and it seems it was a well known problem with collectd and Ubuntu 20
I came across this thread and ran both
apt dist-upgrade
and
and they are now both working happily.
I wholehaeartedly agree.
S
Added it to the readme in case any of you reinstall or something and can’t find this thread.
It was there but it didn’t specify Ubuntu.
When i had to do this on Debian, it was fixed after some time i believe.
So … let’s just call this an Ubunut fix in the hopes more people who need it will find it.
system
Closed
September 8, 2022, 5:26am
38
