10.1 update, where did my 978 receiver go?
I recently updated my piaware to 10.1. Didn’t think to make a backup of the old card or setup data and just installed 10.1 on the same SD card.
Now, only my 1090 receiver is working. My second receiver for 978 is no where to be seen.
I’ve tried looking for instructions on how to setup a 2nd 978 receiver, but have not had any luck. Can someone point me to where those instructions are?
1 - Configure UAT 978
Issue following commands:
sudo piaware-config uat-receiver-type sdr
sudo piaware-config rtlsdr-device-index 00001090
sudo piaware-config uat-sdr-device driver=rtlsdr,serial=00000978
NOTE:
In above commands, I have used serial numbers as follows
  • 1090 Dongle: 8-digit 00001090
  • 978 Dongle: 8-digit 00000978
Instead of above serial numbers, please use the serial numbers with which you have serialized your dongles
You can check their serial numbers by following command
sudo apt install rtl-sdr
rtl_test -t
2 - Reboot Pi to implement configuration settings
sudo reboot
3 - Check Status
sudo systemctl status piaware
sudo systemctl status dump978-fa
That did the trick. Thanks for the quick and concise reply.
