Sure!
Method: Enroute
Airport: KSAN
howMany: 15
Offset: 3
Filter: [no filter]
Results (See SKW6342, SWA1937):
Code:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:FlightAwareDirectFlight="http://directflight.flightaware.com/soap/DirectFlight">
<SOAP-ENV:Body>
<ns:EnrouteResponse SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns="FlightAwareDirectFlight">
<return xsi:type="FlightAwareDirectFlight:EnrouteStruct">
<next_offset xsi:type="xsd:int">18</next_offset>
<enroute xsi:type="SOAP-ENC:Array" SOAP-ENC:offset="[0]" SOAP-ENC:arrayType="FlightAwareDirectFlight:EnrouteFlightStruct[15]">
<item xsi:type="FlightAwareDirectFlight:EnrouteFlightStruct">
<ident xsi:type="xsd:string">AWE191</ident>
<aircrafttype xsi:type="xsd:string">A320</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254276480</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254276480</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254279900</estimatedarrivaltime>
<origin xsi:type="xsd:string">KPHX</origin>
<destination xsi:type="xsd:string">KSAN</destination>
<originName xsi:type="xsd:string">Phoenix Sky Harbor Intl</originName>
<originCity xsi:type="xsd:string">Phoenix, AZ</originCity>
<destinationName xsi:type="xsd:string">San Diego Intl</destinationName>
<destinationCity xsi:type="xsd:string">San Diego, CA</destinationCity>
</item>
<ident xsi:type="xsd:string">ASA572</ident>
<aircrafttype xsi:type="xsd:string">B737</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254272460</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254272160</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254280320</estimatedarrivaltime>
<origin xsi:type="xsd:string">KPDX</origin>
<originName xsi:type="xsd:string">Portland Intl</originName>
<originCity xsi:type="xsd:string">Portland, OR</originCity>
</item>
<ident xsi:type="xsd:string">UAL395</ident>
<aircrafttype xsi:type="xsd:string">A319</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254265860</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254265080</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254280380</estimatedarrivaltime>
<origin xsi:type="xsd:string">KORD</origin>
<originName xsi:type="xsd:string">Chicago O'Hare Intl</originName>
<originCity xsi:type="xsd:string">Chicago, IL</originCity>
</item>
<ident xsi:type="xsd:string">AAL225</ident>
<aircrafttype xsi:type="xsd:string">B752</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254260100</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254259920</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254280980</estimatedarrivaltime>
<origin xsi:type="xsd:string">KBOS</origin>
<originName xsi:type="xsd:string">Boston Logan Intl</originName>
<originCity xsi:type="xsd:string">Boston, MA</originCity>
</item>
<ident xsi:type="xsd:string">SWA1781</ident>
<aircrafttype xsi:type="xsd:string">B733</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254273120</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254273360</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281100</estimatedarrivaltime>
<origin xsi:type="xsd:string">KDEN</origin>
<originName xsi:type="xsd:string">Denver Intl</originName>
<originCity xsi:type="xsd:string">Denver, CO</originCity>
</item>
<ident xsi:type="xsd:string">AWE155</ident>
<aircrafttype xsi:type="xsd:string">A321</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">1254262980</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254262620</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281220</estimatedarrivaltime>
<origin xsi:type="xsd:string">KPHL</origin>
<originName xsi:type="xsd:string">Philadelphia Intl</originName>
<originCity xsi:type="xsd:string">Philadelphia, PA</originCity>
</item>
<ident xsi:type="xsd:string">ASA498</ident>
<aircrafttype xsi:type="xsd:string">B734</aircrafttype>
<filed_departuretime xsi:type="xsd:int">1254272520</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281340</estimatedarrivaltime>
<origin xsi:type="xsd:string">KSEA</origin>
<originName xsi:type="xsd:string">Seattle-Tacoma Intl</originName>
<originCity xsi:type="xsd:string">Seattle, WA</originCity>
</item>
<ident xsi:type="xsd:string">AWE198</ident>
<actualdeparturetime xsi:type="xsd:int">1254264300</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254263940</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281400</estimatedarrivaltime>
<origin xsi:type="xsd:string">KCLT</origin>
<originName xsi:type="xsd:string">Charlotte/Douglas Intl</originName>
<originCity xsi:type="xsd:string">Charlotte, NC</originCity>
</item>
<ident xsi:type="xsd:string">SKW6342</ident>
<aircrafttype xsi:type="xsd:string">E120</aircrafttype>
<actualdeparturetime xsi:type="xsd:int">0</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254279660</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281640</estimatedarrivaltime>
<origin xsi:type="xsd:string">KLAX</origin>
<originName xsi:type="xsd:string">Los Angeles Intl</originName>
<originCity xsi:type="xsd:string">Los Angeles, CA</originCity>
</item>
<ident xsi:type="xsd:string">SWA1937</ident>
<filed_departuretime xsi:type="xsd:int">1254278760</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254281820</estimatedarrivaltime>
<origin xsi:type="xsd:string">KLAS</origin>
<originName xsi:type="xsd:string">Mc Carran Intl</originName>
<originCity xsi:type="xsd:string">Las Vegas, NV</originCity>
</item>
<ident xsi:type="xsd:string">DAL1061</ident>
<actualdeparturetime xsi:type="xsd:int">1254266700</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254267000</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254282000</estimatedarrivaltime>
<origin xsi:type="xsd:string">KATL</origin>
<originName xsi:type="xsd:string">Hartsfield-Jackson Intl</originName>
<originCity xsi:type="xsd:string">Atlanta, GA</originCity>
</item>
<ident xsi:type="xsd:string">JBU411</ident>
<actualdeparturetime xsi:type="xsd:int">1254260400</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254260340</filed_departuretime>
</item>
<ident xsi:type="xsd:string">SWA94</ident>
<actualdeparturetime xsi:type="xsd:int">1254277620</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254277860</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254282120</estimatedarrivaltime>
<origin xsi:type="xsd:string">KSMF</origin>
<originName xsi:type="xsd:string">Sacramento Intl</originName>
<originCity xsi:type="xsd:string">Sacramento, CA</originCity>
</item>
<ident xsi:type="xsd:string">SWA1949</ident>
<actualdeparturetime xsi:type="xsd:int">1254277800</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254277500</filed_departuretime>
<origin xsi:type="xsd:string">KSFO</origin>
<originName xsi:type="xsd:string">San Francisco Intl</originName>
<originCity xsi:type="xsd:string">San Francisco, CA</originCity>
</item>
<ident xsi:type="xsd:string">JBU185</ident>
<actualdeparturetime xsi:type="xsd:int">1254262260</actualdeparturetime>
<filed_departuretime xsi:type="xsd:int">1254263220</filed_departuretime>
<estimatedarrivaltime xsi:type="xsd:int">1254282240</estimatedarrivaltime>
<origin xsi:type="xsd:string">KJFK</origin>
<originName xsi:type="xsd:string">John F Kennedy Intl</originName>
<originCity xsi:type="xsd:string">New York, NY</originCity>
</item>
</enroute>
</return>
</ns:EnrouteResponse>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
