Calling AirportInfo in PHP 5.2.6 with the built-in SOAP class for airports whose ICAO code starts with a zero results in the following var_dump:
object(SoapFault)#8 (9) {
["message:protected"]=>
string(55) "can't read "::airportTZ(06N)": no such element in array"
["string:private"]=>
string(0) ""
["code:protected"]=>
int(0)
["file:protected"]=>
string(48) "/usr/local/apache2/htdocs/thunberg/air/index.php"
["line:protected"]=>
int(11)
["trace:private"]=>
array(2) {
[0]=>
array(4) {
["function"]=>
string(6) "__call"
["class"]=>
string(10) "SoapClient"
["type"]=>
string(2) "->"
["args"]=>
array(2) {
[0]=>
string(11) "AirportInfo"
[1]=>
array(1) {
[0]=>
string(3) "06N"
[1]=>
array(6) {
["file"]=>
["line"]=>
int(11)
["function"]=>
["class"]=>
["type"]=>
string(2) "->"
["args"]=>
array(1) {
[0]=>
string(3) "06N"
["faultstring"]=>
["faultcode"]=>
string(4) "NONE"
["detail"]=>
object(stdClass)#6 (1) {
["errorInfo"]=>
object(stdClass)#7 (2) {
["errorCode"]=>
string(4) "NONE"
["stackTrace"]=>
string(488) "can't read "::airportTZ(06N)": no such element in array
while executing
"list name $name location $location longitude $longitude latitude $latitude timezone $::airportTZ($airportCode)"
(procedure "AirportInfo" line 12)
invoked from within
"AirportInfo 06N"
(in namespace inscope "::FlightAwareDirectFlight" script line 1)
invoked from within
"::namespace inscope ::FlightAwareDirectFlight AirportInfo 06N"
invoked from within
"interp eval $interp $fqdn $argValues""
The above error is different than the "airport doesn't exist" error so it's not a matter of an obscure airport -- seems to be a bug with var types / array indices.
If you're confident this is a bug on PHP's end I'll go ahead and file it with them -- let me know.
