 Post subject: PiAware Skyview Map
PostPosted: Tue Apr 04, 2017 10:10 pm
dzimmer43 - FlightAware user avatar
Hello ,
Need some help.
Updated to Version 3.5 today , all went Ok. Updated Dump1090 also , all Ok..
Reading , on this site , that the new Version 3.5 , has the ability to do , "PiAware Sky View User interface Dump1090 Map View" ..
How does one get the , "Sky View" map to display ??
My System : Purchased the , "Pre packaged" , SD Card . Had Version 3.1 on it , now 3.5. .. Raspberry Pi 3, FlightAware ADS-B -BandPass Filter , FlightAware Pro Stick USB Receiver , Power Supply , FlightAware 1090 - outdoor antenna. Receiving , up to 40+ aircraft ..
All the hardware and software work perfect .. I am on , "Wired " , internet , not wireless..
Any and all help , that you can give me on how to active the , "Sky View" , would be much appreciated ..
Thank You ,
Darryl
PostPosted: Tue Apr 04, 2017 10:42 pm
jvcdcarlos - FlightAware user avatar
if I understood right that is nothing new, as is simply as going to your site adsb ip address port 8080
ex: 192.168.xxx.xxx:8080
let me know if you need something else.
Cheers
Sent from my SM-N910F using Tapatalk
 Post subject: Re: PiAware Skyview Map
PostPosted: Tue Apr 04, 2017 11:39 pm
chrisjohnston50 - FlightAware user avatar
Be sure to clear your browser's cache in order to activate Skyview.
PostPosted: Tue Apr 04, 2017 11:50 pm
PostPosted: Wed Apr 05, 2017 10:49 pm
I wish to thank the following members for their help ::JVCDCARLOS ; CHRIS JOHNSTON 50 & ABCD567.
I got it to work , thanks to you .
Darryl
PostPosted: Fri Apr 28, 2017 2:27 pm
shoegolf - FlightAware user avatar
abcd567 wrote:
Wow just updated , nice improvement! info at the click of your finger
RCH3325
PostPosted: Fri Apr 28, 2017 2:51 pm
SEFL - FlightAware user avatar
If you aren't sure what the IP address is for the Pi there should be a link to the SkyView page directly from your Flight aware stat page. It says "Web Interface: View Live Data". You have to be on the local network to see the SkyView. I just set up a VPN so I can see my SkyView remotely now.
PostPosted: Sat Jun 24, 2017 3:12 am
freybear - FlightAware user avatar
Much appreciated!
abcd567 wrote:
PostPosted: Sun Jul 16, 2017 10:57 pm
kevinoleniczak - FlightAware user avatar
I like the map view but would like to see it via the hdmi port on the raspberry pi. I understand this is a web browser app, but the PiAware image doesn't load a GUI to launch a browser from. Anyone know how to make it do that?
PostPosted: Sun Jul 16, 2017 11:21 pm
As Piaware image is built using Jessie Lite image (stripped down), the method shown on these pages for Raspbian Lite & Jessie Lite may also work for Piaware image also.
I have NOT tried these, so cannot tell anything with surety.
[GUIDE] Raspbian Lite with PIXEL/LXDE/XFCE/MATE/i3 GUI
https://www.raspberrypi.org/forums/viewtopic.php?f=66&t=133691
Add GUI to Jessie Lite
https://www.raspberrypi.org/forums/viewtopic.php?f=91&t=177910
On this page someone has suggested:
sudo apt-get install raspberrypi-ui-mods
PostPosted: Mon Jul 17, 2017 4:22 am
SoNic67 - FlightAware user avatar
The method using http://Local_IP_NUMBER:8080 works from outside the internal network if the port 8080 is added to the router's forwarding rules, to redirect incoming packets to the Local_IP number.
The IP is replaced with the Internet (external) IP: http://External_IP_NUMBER:8080
PS: http://FA_IP_NUMBER/dump1090-fa/ shows the same page when inside the network.
PostPosted: Tue Jul 18, 2017 12:46 pm
evangelyul - FlightAware user avatar
a method working for me (install LXDE desktop - lightweight) as follows:
sudo apt-get install -y xinit
sudo apt-get install -y lxde-core lxterminal lxappearance
sudo apt-get install -y lightdm
sudo apt-get install -y midori
after all installations complete run sudo raspi-config and select 3 Boot Options.
in boot options select B1 Desktop / CLI .
in the new tab select B4 Desktop Autologin Desktop GUI
reboot and now the LXDE desktop will appear on your HDMI monitor.
run Midori (web browser) and try the url 127.0.0.1:80 or 8080 or dump1090-fa, to view the map.
HTH
PostPosted: Sat Jul 22, 2017 7:10 pm
PrashantBalhara - FlightAware user avatar
Greetings,
Can somebody help me in configuring my router so that i can view FlightFeeder Skyview map from outside of my local network, like on my cellphone when i am not at home. I am very new to this and i tried port forwarding in my router with following settings but it didn't work.
SERVICE PORT: 8080
INTERNAL PORT: 8080
IP ADDRESS: 192.168.0.100 (FLIGHTFEEDER's IP)
STATUS: ENABLED
I tried on my cellphone by typing my ISP IP address (183.82.66.77:8080) but it didn't work. I have TP-Link router and FlightFeeder 7.7.1.
Users browsing this forum: 41south, matth20man, RenatoRibeiro, speedy314, turracaine and 1 guest
