 Post subject: Do not apt-get upgrade on PiAware sdcard 3.3.0 images
PostPosted: Mon Jun 12, 2017 2:45 pm
A warning that if you do an apt-get upgrade (upgrading all packages, including system packages) on a PiAware 3.3.0 or older sdcard image it is likely to break.
The simplest option to avoid this is to re-image with a PiAware 3.5.0 image.
If you can't do that, avoid upgrading the system packages (upgrading just PiAware via the remote command or by "apt-get install piaware" is OK)
There are several interrelated problems, related to a new Raspbian kernel packge that was recently released:
1) You will run out of space on /boot as the partition is not large enough to hold all the required kernels / initrd images / etc, which leaves the kernel half upgraded
2) Using an old (4.4) kernel with newer Pi bootloader/firmware will produce a randomized MAC address on each boot due to an incompatibility with the older kernel
3) The new kernel can panic on boot due to a kernel bug that is tickled by the config.txt (enable_uart=1 setting) used by the 3.3.0 image
Recovering this by hand is somewhat tricky so I strongly recommend you just go with a new 3.5.0 image.
 Post subject: Re: Do not dist-upgrade on PiAware sdcard 3.3.0 images
PostPosted: Mon Jun 12, 2017 4:50 pm
Whenever a new version is released, I re-image rather than upgrade.This has been my practice since long, even when there were no issues in upgrading.
 Post subject: Re: Do not apt-get upgrade on PiAware sdcard 3.3.0 images
PostPosted: Wed Jul 12, 2017 9:05 pm
How would I tell which version I have? My Skyview said 3.5.0, but after upgrading everything it would not boot. I reverted to the backup so no problem getting back up and running. The /boot partition appears to be only about 30% used.
PostPosted: Wed Jul 12, 2017 9:23 pm
uname -a
#output on my android phone
$ uname -a
Linux localhost 3.4.0-5793883 #1 SMP PREEMPT Fri Sep 11 17:43:50 KST 2015 armv7l Android
PostPosted: Wed Jul 12, 2017 9:24 pm
Probably the simplest way to work out the original sdcard version is
sudo grep "Setting up piaware-support" /var/log/raspbian-ua-netinst.log
This will get you the version of piaware-support installed when the sdcard image was originally built.
PostPosted: Wed Jul 12, 2017 10:44 pm
What about Piaware add-on package install?
I am not at home, so cannot try on Pi the following two commands I remember, but tried these two on my Android phone Samsung Galaxy, and got following output:
$ cat / proc / version
Linux version 3.4.0-5793883 (dpi@SWHD4402) (gcc version 4.8 (GCC) ) #1 SMP PREEMPT Fri Sep 11 17:43:50 KST 2015
$ uname -a
PostPosted: Thu Jul 13, 2017 12:11 am
Now at home. Tried various commands on Piaware (sd card image) & Piaware (add-on package)
pi@piaware:~$ sudo grep "Setting up piaware-support" /var/log/raspbian-ua-netinst.log
Setting up piaware-support (3.5.0) ...
pi@raspberrypi:~ $ sudo grep "Setting up piaware-support" /var/log/raspbian-ua-netinst.log
grep: /var/log/raspbian-ua-netinst.log: No such file or directory
pi@orangepipc:~$ sudo grep "Setting up piaware-support" /var/log/raspbian-ua-net inst.log
pi@piaware:~$ uname -a
Linux piaware 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.9.35+ #1014 Fri Jun 30 14:34:49 BST 2017 armv6l GNU/Linux
pi@orangepipc:~$ uname -a
Linux orangepipc 3.4.113-sun8i #18 SMP PREEMPT Thu Jun 15 02:16:06 CEST 2017 armv7l armv7l armv7l GNU/Linux
pi@piaware:~$ cat / proc / version
Linux version 4.9.35-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG c rosstool-ng-1.22.0-88-g8460611) ) #1014 SMP Fri Jun 30 14:47:43 BST 2017
pi@raspberrypi:~ $ cat / proc / version
Linux version 4.9.35+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 Fri Jun 30 14:34:49 BST 2017
pi@orangepipc:~$ cat / proc / version
Linux version 3.4.113-sun8i (root@devel) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #18 SMP PREEMPT Thu Jun 15 02:16:06 CEST 2017
PostPosted: Thu Jul 13, 2017 7:56 am
The question is meaningless except on a sdcard image.
PostPosted: Thu Jul 13, 2017 8:19 am
Thank you. That gave me piaware-support (3.0.4) so it's an older version. For interest's sake, I tried uname -a too. It gives 4.4.0-1-rpi2.
Thanks again for your help.
Users browsing this forum: abcd567, eastofottawa, Google [Bot], matth20man, TomMuc and 1 guest
cron
