 Post subject: Channel 12 and 13 in UK from PiAware - Solved
PostPosted: Mon Jul 10, 2017 2:53 am
markv2017 - FlightAware user avatar
This may affect any users using piaware in a country that allows WiFi channels above 11.
Out-of-the-box, piaware 3.5.0 supports WiFi Channels 1-11.
The reason this is a problem is that WiFi routers are often set to automatically pick a channel, and so that could be any legal channel (1-13 in the UK). If it happens to pick 12 or 13, your Pi fails to connect. I spent many, many hours getting to the root cause and solving it.
Some of the solutions I found talked about updating the operating system and firmware but I didn't need to do that.
All that is necessary was to correctly set the WiFi Region (GB in my case). After doing that, sudo iwlist wlan0 channel will report Ch1-13.
Setting WiFi region in raspi-config seems the logical way to do it, but that didn't work for me. I think that action creates a wpa_supplicant.conf with REGION=GB but I suspect that when a wpa-roam config is present, wpa_supplicant is ignored.
The solution for me was:
sudo iw reg set GB
That instantly got ch 12 and 13 to appear and my Pi to connect.
It doesn't survive a reboot so I then added that command (without needing sudo) to /etc/rc.local and it's now connecting reliable every time on any channel.
 Post subject: Re: Channel 12 and 13 in UK from PiAware - Solved
PostPosted: Mon Jul 10, 2017 6:43 am
From my limited knowledge of the region management stuff, IIRC the region can also be set in the AP (which is the more natural place to set it, since APs don't usually move)
Users browsing this forum: domefin, Google [Bot], spotterssol and 1 guest
