 Post subject: What do you guys terminate a collinear DIY antenna with?
PostPosted: Fri Jul 07, 2017 4:17 am
J89eu - FlightAware user avatar
Hi all
I built a collinear antenna and it works great but I have used F type connectors and they keep falling off the cable as it's not tight enough. I'd like to use N Type connectors as they seem the more solid alternative but these look to be even bigger and I'm not sure SMA will take the weight/movement whilst outside.
What is the general consensus for terminating the end of the array?
Also I've been looking at changing to a better cable quality now that I want the antenna on the roof as the cable run will be a good 10m-ish and found LMR400 seems to be recommended, can this be used for the entire array and cabling run as I may buy a reel and do the whole lot again.
 Post subject: Re: What do you guys terminate a collinear DIY antenna with?
PostPosted: Fri Jul 07, 2017 5:05 am
SoNic67 - FlightAware user avatar
You are probably using the wrong cable. RG59 is thinner than RG6, so the connector is different.
https://sewelldirect.com/learning-center/rg59-or-rg6
PostPosted: Fri Jul 07, 2017 5:33 am
So would you recommend going with RG6 rather than LMR400? The price difference is substantial!
PostPosted: Fri Jul 07, 2017 6:07 am
The point is that you need F connectors that are designed for the cable diameter you're using.
Either F or N should be fine if they're properly installed. You don't really want to be putting mechanical stress on a connector regardless of what it is..
Lower loss cable is generally a good thing (look at the specs for loss at 1GHz, and beware that it's sometimes quoted per 100ft and sometimes per 100m) but whether it makes a big difference depends on the length of the cable run.
PostPosted: Fri Jul 07, 2017 8:15 am
w7psk - FlightAware user avatar
I use Crimp type F connectors. A lot more secure.
PostPosted: Fri Jul 07, 2017 11:12 am
theresjam - FlightAware user avatar
twist the shielding braid together to form a tail. then push that tale backwards up the cable then attach the f-connector.
This will increase the diameter of the cable and the f connector may stay on. Its a abodge but it does work.
PostPosted: Fri Jul 07, 2017 11:04 pm
AFAIK there is no F connector for the LMR400, only N:
http://www.awcwire.com/productspec.aspx ... connectors
Users browsing this forum: domefin, Google [Bot], spotterssol and 1 guest
