 Post subject: Running multiple devices concurrently in separate locations.
PostPosted: Sun Jun 18, 2017 3:37 pm
lblumber - FlightAware user avatar
Dear Sir/Madam,
I've been upgrading / testing new PiAware hardware and at this point, I have two devices associated with my account (lblumber). One is a secondary / backup device with MAC address /site b8:27:eb:ac:f1:4f / 56245 which is showing as my primary feed - how do I change the primary feed to the other MAC address / site ( b8:27:eb:79:d9:b9 / 56952)? The system I'm putting in production is the 56952 site.
Along those lines, I was going to use the 56245 / b8:27:eb:ac:f1:4f backup device as a portable device which may run concurrently with the b8:27:eb:79:d9:b9 / 56952 device, although in a different location. Should I setup that device with a different login / passwd to FA?
Thanks in advance for all the help...
Lenny Blumberg
lenny@lennyblumberg.com
 Post subject: Re: Running multiple devices concurrently in separate locati
PostPosted: Sun Jun 18, 2017 4:58 pm
If your hardware is Raspberry Pi, and if your Pis were registered with Flightaware BEFORE March 20, 2017, a way to swap station numbers between two devices is to swap mac addresses.
Current
PRIMARY: 56245 / b8:27:eb:ac:f1:4f
BACKUP: 56952 / b8:27:eb:79:d9:b9
After MAC addresses swap by spoofing mac addresses
PRIMARY: 56245 / b8:27:eb:79:d9:b9
BACKUP: 56952 / b8:27:eb:ac:f1:4f
HOW TO SWAP MAC ADDRESS:
Primary Pi
  • First shutdown the other PI (Backup Pi) to avoid mixup
  • edit /boot/cmdline.txt file. This file has only one line
    At the end of this line, add (without line break) following:
    smsc95xx.macaddr=b8:27:eb:79:d9:b9
    Note: mac address spoof will not work if there is a line break between existing line and new text added.
  • Delete file /var/cache/piaware/feeder_id
  • Reboot Primary Pi
Backup Pi
  • First shutdown the other Pi (Primary Pi) to avoid mixup
  • Power-up Backup Pi
    smsc95xx.macaddr=b8:27:eb:ac:f1:4f
  • Reboot Backup Pi
  • Power up Primary Pi
PostPosted: Sun Jun 18, 2017 5:29 pm
If your hardware is Raspberry Pi, and if your Pis were registered with Flightaware AFTER March 20, 2017, a way to swap station numbers between two devices is to swap feeder-id.
Current
PRIMARY: 56245 / xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
BACKUP: 56952 / yyyyyyyy-yyyy-yyyy-yyyy-yyyyyyyyyyyy
After feeder-id swap
PRIMARY: 56245 / yyyyyyyy-yyyy-yyyy-yyyy-yyyyyyyyyyyy
BACKUP: 56952 / xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
HOW TO SWAP FEEDER-IDs:
First from your Flightaware Stats page note down feeder-id for both Pis
it is in format 12345678-1234-1234-1234-123456789abc
Primary Pi
  • give following command using Back up Pi's current feeder id
    sudo piaware-config feeder-id yyyyyyyy-yyyy-yyyy-yyyy-yyyyyyyyyyyy
  • Reboot Primary Pi
Backup Pi
  • Power up Backup Pi
  • give following command using Primary Pi's current feeder id
    sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
  • Reboot Backup Pi
PostPosted: Mon Jun 19, 2017 10:09 am
Mr. abcd567,
Many Thanks for your suggestions - I added the command line parm to set the MAC address and also switched from a DHCP to a static address so I'm not chasing my Pi all over my network...
At this point the spheres are in harmony (so sez Gustaf Holst..) and I've got good data and the MLAT client is also up and running.
I'm thinking that the user accounts are fairly position-centric, so If I travel out to New Mexico with a portable PiAware setup, I should probably setup a different account/passwd as a login to FA to use with that rig.
Thanks for all your help - Lenny
Lenny Blumberg
Austin, Tx.
PostPosted: Mon Jun 19, 2017 1:10 pm
You don't need a separate account, you can associate multiple sites (with different locations) with a single account.
Users browsing this forum: Google [Bot], invergordon, mruczycho and 1 guest
