Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
 Post subject: Re: Changes to how new PiAware feeders are identified
PostPosted: Tue May 02, 2017 10:46 am
jimcander - FlightAware user avatar
Hey Oliver -
Any word on converting MAC based installations to ID based installations?
Jim
PostPosted: Wed May 17, 2017 1:18 pm
Ljungskile - FlightAware user avatar
obj wrote:
If you have an existing site this does not affect you - existing sites will continue to be identified by MAC address at the moment.
I have changed hardware on my site, I would like to keep the old site ID, Im using the same image (different SD-card, but I have made sure it has the old sites ID now)
Could you please remove site 43294 and make sure that site 19882 identifies by ID instead of MAC?
Edit:
I didnt want to loose my "longest streak" (from the first day I started with this) on 19882, so I did as GeorgLichtblau and many others, i spoofed the MAC from the old Pi. But I still hope to be able to identify 19882 by ID instead of MAC in the future. It would make it easier when changing out hardware.
PostPosted: Wed May 17, 2017 2:41 pm
GeorgLichtblau - FlightAware user avatar
I've changed hardware at one of my receivers (registered before the feeder-id) today...
As I wanted to keep my old stats I changed the mac-address to the old one and fiddling around for two hours with just creating new feeder-ids :)
So the quick and very, very dirty hack to get it to work by just using the mac-address was:
rm /var/cache/piaware/feeder_id
touch /var/cache/piaware/feeder_id
chmod 000 /var/cache/piaware/feeder_id
As said... very, very dirty.. but it works :)
PostPosted: Wed May 17, 2017 6:24 pm
That will break in the near future.
PostPosted: Wed May 17, 2017 8:23 pm
The Piaware of a new Pi with new image obtains a new feeder-id immediately at FIRST BOOT, if:
(1) Mac address spoof was not done BEFORE FIRST BOOT
OR
(2) Mac address spoof was done, but it did not work due to line break in file cmdline.txt
The trouble free way to spoof mac address is to do it BEFORE FIRST BOOT of the newly written image, and to ensure there is no line break in file cmdline.txt.
After writing the image, and while the microSD card is still in card reader of Laptop/Desktop, click on the drive letter of microSD card. This will open the /boot folder (the only folder visible in laptop/desktop). Then open the file cmdline.txt using Wordpad (do not use Notepad, as it creates a line break in the file when it is saved, and because of line break, the mac spoof does not work).
This file has only one line. At the end of this line, add (without line break) following and save file.
smsc95xx.macaddr=xx:xx:xx:xx:xx:xx
(replace xx:xx:xx:xx:xx:xx by mac address of old Pi)
Now take out card from laptop/desktop, plugin into Pi and do the FIRST BOOT.
If a line break was introduced, then even if you edit file cmdline.txt in nano editor in SSH console and remove the line break, Piaware by that time has already obtained a new 128 bit site identifier, and you will be faced with problem of getting rid of it.
To enable SSH, you will also need to create a new file SSH in /boot folder BEFORE FIRST BOOT, while the microSD card is still in card reader of laptop/desktop.
Users browsing this forum: CommandPost2017, k6rtm and 1 guest
