Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
 Post subject: Re: MLAT Anomalies
PostPosted: Thu May 04, 2017 3:57 pm
sebgray - FlightAware user avatar
So that 3 of us with a Pi 2 that gives timing errors for M-LAT with kernel version 4.9.x that was resolved by downgrading to 4.5.x... I've no idea why either but I can live with that as I'd rather have stability. I'll continue to update the Pi software as normal however I'll not be running rpi-update for a while! :roll:
PostPosted: Thu May 04, 2017 5:05 pm
You might want to report the problem upstream to the Pi Foundation
(timing errors generally mean that USB traffic is being dropped, presumably in the kernel's USB stack in this case)
PostPosted: Sun May 07, 2017 12:31 pm
g7ruh - FlightAware user avatar
And another one which makes 4. I upgraded to a yellow flight stick and dump1090-mutability and had a huge increase in position reports that I had to upgrade to a Pi2 (CPU overload in the PiiB). I thought it was the increase in volume that triggered the mlat issue, until I saw this thread. I downgraded to 4.5.x and it has been running fine for the last 5 hours.
I guess it is an issue that the dump1090-mutability folks should take up with the pi firmware folks.
Is anyone using a Pi 3 getting these issues??
thanks for the pointer sebgrey 8)
EDIT with update: after 2.5 days using the 4.5.x firmware MLAT is still working very well, no drops at all :D
Roger
PostPosted: Thu May 11, 2017 6:14 pm
Some possibly related issues: https://github.com/raspberrypi/firmware/issues/753 https://github.com/raspberrypi/linux/issues/1998
PostPosted: Fri May 12, 2017 3:23 am
Roger
I have a 2nd pi3 running 4.9 Kernel/piaware v3.50 and it seems ok, been running it for about 3-4 days with the new kernel.
PostPosted: Sat May 13, 2017 3:58 am
conligwx wrote:
Roger
thanks, that confirms my findings:
I have replaced the offending Pi 2 with a Pi 3 and the 4.9.x kernel and it has been working fine for 3 days, so it seems to be a Pi2 only issue. I will use the P2 elsewhere.
PostPosted: Tue May 16, 2017 10:27 am
Dudley - FlightAware user avatar
I have 2 RPi 2 that experienced this problem after upgrade to 4.9 & resolved when downgraded to 4.5
PostPosted: Wed May 17, 2017 5:01 pm
MatthewZinicola - FlightAware user avatar
I suffered this issue on a high-profile/high-traffic (remote) piaware site of mine. I was going crazy trying to figure it out (my raspbian upgrade coincided with my upgrade to 3.5.0 and other changes)...
Sincerest thanks to the folks that figured this out, determined the solution and posted it...!! :D
PostPosted: Wed May 24, 2017 6:43 am
phg2k - FlightAware user avatar
Reverting Kernel worked for both my PIs...
Not great, but at least working.
Many thanks!
PostPosted: Wed May 24, 2017 7:57 am
KarlNapf - FlightAware user avatar
add +1 to the statistics:
Pi2 MLAT clock stable with kernel 4.4.50 but not 4.9.xx
Pi3 MLAT clock stable with kernel 4.9.29, too.
PostPosted: Wed May 24, 2017 2:15 pm
Radiostationx - FlightAware user avatar
+1
Listed on Github
https://github.com/jprochazka/adsb-rece ... -303758098
PostPosted: Wed May 24, 2017 6:39 pm
tonyscanga - FlightAware user avatar
I have some anomalous MLAT data. On May 18th, I got a spike in MLAT position reports and since then, the number has tanked. Its been relatively constant for months. Also, the number of airplanes has remained relatively constant even as the number of reports has dropped off the table.
I'm not sure what is going on. Any insight as to cause. I uses the standard FA 3.1 SD card. This behavior is the same on both of my sites, so I don't think its related to my system or configuration.
Tony
PostPosted: Wed May 24, 2017 6:46 pm
Upgrading to 3.5.0 would be a starting point.
Users browsing this forum: CommandPost2017, k6rtm, user92891 and 1 guest
