 Post subject: [Feature request] Load average and temperature display
PostPosted: Wed May 10, 2017 6:30 am
greencedars - FlightAware user avatar
Hello,
As a person who loves to see numbers and data in general, I was wondering if it would be possible to display the load average and temperature of the device in SkyView. It doesn't have to be fancy; maybe a discrete line on top of the panel on the right.
I run other services on the Rpi and it would be useful to see this information; I usually ssh in and check it.
It is also useful to check the CPU temperature if the device is not well ventilated or outdoors.
Thank you for your consideration.
g.
 Post subject: Re: [Feature request] Load average and temperature display
PostPosted: Wed May 10, 2017 6:35 am
I too would like to see some sort of built in values, Perhaps even on a separate page?
PostPosted: Wed May 10, 2017 8:11 am
Thank you for the suggestion. We will consider it for a future update.
PostPosted: Wed May 10, 2017 5:36 pm
AlpineMeadows - FlightAware user avatar
Another vote to show this or give us a command to send the Pi to show it on the log screen.
My Pi is in a metal box in the attic, powered over POE. I don't have easy physical access to it to hook up a monitor/keyboard.
PostPosted: Thu May 11, 2017 1:42 am
btw you can use the command
cat /sys/class/thermal/thermal_zone0/temp
then divide by 1000
PostPosted: Thu May 11, 2017 1:01 pm
Or on a Pi 'sudo vcgencmd measure_temp'
PostPosted: Sun May 14, 2017 3:02 pm
n112 - FlightAware user avatar
I also think that a temperature display on SkyView screen would be nice.
On my RPi, I have a script (tempcheck.sh) that displays temperature in degrees C and F.
This script is called from ~/.bashrc so appears on every login.
This script can be called from other scripts as well or run manually.
The temperature is displayed as part of the login messages. For example:
The CPU's current temperature is:
27.7 °C (81.86 °F)
These two lines are at end of my ~/.bashrc file:
echo "The CPU's current temperature is:"
~/bin/tempcheck.sh
This is the contents of my file ~/bin/tempcheck.sh.
(this file has execute permissions)
#!/bin/bash
tm=`/opt/vc/bin/vcgencmd measure_temp`
tc=`echo $tm| cut -d '=' -f2 | sed 's/..$//'`
tf=$(echo "scale=2;((9/5) * $tc) + 32" |bc)
echo $tc \°C \($tf \°F\)
I believe that the package bc was not included, so
sudo apt-get install bc
was necessary to get the degees F calculation.
Users browsing this forum: CommandPost2017, k6rtm and 1 guest
