Post new topic Reply to topic  [ 181 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8
 Post subject: Re: Announcing the Pro Stick Plus!
PostPosted: Tue Mar 14, 2017 7:35 pm
inoc - FlightAware user avatar
Thanks for all the info, I was thinking about putting an "ultra" low noise amp (~0.6db at 1090MHz) in front of the prostick+, but with both the prostick+ and prostick having an about 0.23dB NF LNA at 1090MHz I sure don't want to do that.
I guess when I think about noise it's in the pass band of the demodulator, any noise outside the demodulated pass band has no effect on performance (unless it overloads something in front of the demodulator).
And you are of course correct on the term system temperature as being an all inclusive term for system noise, varying with the ambient air and component temperatures.
Since ambient air and component temperatures vary with the weather and component cooling methods I usually consider the 1st amplification stage's NF as setting the noise floor.
On the filter, I have the understanding that it reduces both the signal and noise ~2db inside it's pass band but about 40 db outside.
So if there were no LNA in front of the filter, just say a ~2dBi gain antenna, the gain of the antenna would be completely eliminated by the insertion loss of the filter.
OTOH if an LNA with a 0.23 dB NF and ~18dB gain were put between the antenna and filter the antenna gain would only be reduced to ~1.77 dB and the 18 dB of gain would replace the losses due to components temperatures downstream of the LNA, thus the S/N ratio would remain the same downstream of the LNA in the pass band of interest.
PostPosted: Fri Mar 17, 2017 5:02 pm
Definitely the right way to think about how it works. The beginning parts are much more important than the later stages.
This is also the reason we recommend a good antenna and cabling. The biggest increase in performance are in the beginning because once the signal is messed up it can't be fixed in the later stages.
Gain numbers don't quite work like that. dB are relative measurements so you have to know what you are comparing it too. Also dB is logarithmic scale so every 3dB change is about half or twice the power. Something with +3dB higher means it has twice the power. Something -3dB lower means it has half the power. Something with +6dB means it has 4x the power. Something with +9dB means it has 8x the power.
The dBi (it ends with the letter i) is a relative measure compared to a isotropic antenna. A 2dBi antenna means that the antenna has 2dB more gain than an isotropic antenna in the main direction. The other way to think of it is that the antenna instead of antenna receiving energy in all direction it will instead get 2dB more in some directions and a few dB less in other directions.
A dBm (it ends with the letter m) is the power relative to a milliWatt of power. So on an absolute measurement the prostick can measure power levels down to about -90dBm. This is why receivers are usually speced in the lowest power level it can detect in dBm.
You should think of it more like this: A plane has a 200W transmitter which sends the signal through the air and it is picked up by the antenna. The antenna turns the signal into a voltage which is in the microV range. This microV signal then has to be transmitted through the cables , amplified and filtered and you can estimate the final signal based on the gain of each part. So your microV signal has a -3dB loss from the cable, then a 18dB gain from the amp, then a -2dB loss from the filter, and finally a +50dB gain internal to the receiver chip (controlled with the gain setting in piaware). With the right oscilloscope you can measure the voltage at the different stages.
We output the final gain on the local web interface as a dBFS measurement (dB Full Scale). This is a dB measurement based on the receiver scale and it isn't calibrated so you don't know the actual dBm measurement without an oscilloscope. You can see this measurement by clicking on a plane on your PiAware map and then going to the section on the right and read off the dBFS measurement.
Also, there are *lots* of other losses than what we have listed. The main thing is that you get a good signal and then not mess it up in any of the stages.
PostPosted: Mon Mar 20, 2017 9:35 am
WhiteCitadel - FlightAware user avatar
Any update on when any of the Amazon's in Europe will have stock again?
PostPosted: Mon Mar 20, 2017 9:47 am
See post203742.html#p203742. We're not restocking Amazon in Europe because of import issues.
PostPosted: Mon Mar 20, 2017 9:56 am
Availability on Amazon Europe is provided by ModMyPi going forward (and/or any other future retail partners that choose to sell there). You may prefer to order directly from the MyModPi.com web site. They are temporarily out of stock on the Plus but they have more on the way. Demand has exceeded their expectations (good problem to have!) and they are ramping up inventory.
PostPosted: Mon Mar 20, 2017 10:26 am
Ah ok - shame about the 50% price hike :(
Amazon was really convenient, even if you could re-stock just one European Amazon it would be good.
Users browsing this forum: obj and 1 guest
