 Post subject: Incorrect ADS-B Position Reports
PostPosted: Fri Mar 17, 2017 4:22 pm
HuffTheWeevil - FlightAware user avatar
Can anyone explain what causes this:
Clearly this UPS aircraft did not land on top of the terminals. It did indeed land on the runway a couple hundred feet to the south of that path. And once on the ground, it continued to report a position that was offset a bit and was a bit "sketchy". The real taxiway he exited on is actually off that image to the right.
This happens to about 0.5-1% of the flights I see.
And it's not MLAT (in my config, the lat/lon in the selected box would be italicized if this were an MLAT position).
 Post subject: Re: Incorrect ADS-B Position Reports
PostPosted: Fri Mar 17, 2017 4:59 pm
Semi-constant position offsets like this usually mean that the ADS-B position reported is being derived from an inertial system (which drifts over time) not GPS
PostPosted: Fri Mar 17, 2017 5:10 pm
That was my guess. But I don't understand why an ADS-B unit would be set to rely on an IRS over GPS. I thought in today's world IRS was the backup.
PostPosted: Sat Mar 18, 2017 12:19 pm
NeoDuder - FlightAware user avatar
There's probably a switch somewhere to switch between the two but as ADS-B isn't really used much it probably doesn't matter where it is set.
Users browsing this forum: BartJr, jcrtp, navzptc, NewPort01, obj and 1 guest
