Post new topic Reply to topic  [ 216 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
 Post subject: Re: Gain Adjustment...
PostPosted: Sun Jan 15, 2017 3:35 pm
What confused me was that the message value peaked at a gain value of 22 with 166,000, then went down to just 322 at 49.6, then up again to 160,000 at -10. Two gain values so close to each other, and so different results.
Now I have added a filter, and this changed things, the higher the gain, the higher message count, peaking at a gain value of 48. -10 still leads to a lower message count, comparable to a gain value of 16.
Interestingly. the filter did not make a perceptible difference with a standard TV antenna or a homebrew spider, but the FA antenna apparently profits from it.
But now I will stop hijacking this thread, and many thanks to obj for your help.
PostPosted: Mon Jan 16, 2017 12:26 am
andrew6721 - FlightAware user avatar
No, no, no - this is all useful stuff to do with the subject matter - I've always had mine set to AGC (both with the DVB-T dongle and now the ProStick) and am trying to work out whether to leave it or play around with manually setting the gain.
PostPosted: Mon Jan 16, 2017 6:57 am
davidglynn - FlightAware user avatar
biekerc, can you post your ADS-B Signal graph from before and after installing the noise filter?
PostPosted: Mon Jan 16, 2017 4:25 pm
Not very pretty, but these are the values of running the gain script coded by wittrup58. They show gain and messages. The absolute values are not comparable, they ran at different times.
    Gain w/o filter with filter
    0,00 3.890 10.663
    0,90 13.756 19.594
    1,40 19.529 19.124
    2,70 32.050 39.971
    3,70 43.231 50.626
    7,70 62.037 70.073
    8,70 80.542 88.908
    12,50 96.533 103.656
    14,40 104.417 114.737
    15,70 114.134 132.246
    16,60 127.569 146.833
    19,70 146.052 161.232
    20,70 163.105 163.632
    22,90 161.169 180.127
    25,40 162.152 186.239
    28,00 135.730 185.976
    29,70 135.226 187.130
    32,80 72.662 186.608
    33,80 77.703 187.752
    36,40 51.427 189.557
    37,20 47.634 182.157
    38,60 44.095 175.168
    40,20 38.865 185.081
    42,10 27.775 185.781
    43,40 24.053 185.428
    43,90 6.496 184.309
    44,50 5.173 187.369
    48,00 384 190.305
    49,60 322 186.080
    -10 156.974 132.837
Up to gain values of around 20, both show an increase in messages, but without the filter they then go down again, while with the filter, they continue to rise or at least stay the same. It the same for position values, btw.
Gain -10 leads to an average number of messages, even though it technically it represents in the highest possible gain, so one would expect a result like that of gain = 49.6. Maybe the optimize-script changes the gain to the next value before -10 actually leads to gain being set at the highest possible value?
 Post subject: Re: Gain Adjustment...script errors
PostPosted: Thu Mar 16, 2017 6:38 am
navzptc - FlightAware user avatar
I have Dump 1090-mutability (ver 1.15 ~dev) running on a RPI3 using the latest Jessie Lite March 2017 image (python ver 2.7.9) which is running fine and outputting data with no problems.
I have tried to run lignumaqua's script from the first page, but keep running into errors, which are beyond my experience :cry:
The first error which came up was 'SyntaxError: Non-ASCII character '\xc2' in file ./set-gain.py on line 13, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details' and after looking on the interweb came across an answer to add '# -*- coding: utf-8 -*-' to the file - This I have done on the second line.
The script now gets further, but now runs into this error - 'File "./set-gain.py", line 15 ...... print "test", i+1, "of", ntests' - I am now stumped!!!
Any help/suggestions much appreciated.
Andy
PostPosted: Fri Mar 24, 2017 1:33 pm
cpohlad - FlightAware user avatar
So I wanted to post my numbers to make sure I am doing this correctly.
I have an RPi 3 running the ADSB Receiver project image dumping to FA, FR24, PF and ADSBExchange. I have my antenna in the west-facing window of my bonus room on the second floor connected to a ProStick Plus.
I previously set my gain to 45 using the piaware-config command.
This was started at 1PM EDT near Richmond, VA
===Totals===
Gain, Messages, Positions, Aircraft
49.6 47941 1823 157
48.0 48803 1982 146
44.5 46738 2036 153
43.9 43054 1909 151
43.4 41588 1868 148
42.1 40154 1852 152
40.2 39432 1864 145
38.6 39967 1669 142
37.2 38882 1576 139
36.4 37132 1481 132
33.8 36363 1533 135
32.8 34410 1509 133
29.7 32930 1492 117
28.0 33487 1509 118
25.4 28992 1317 98
22.9 27040 1095 94
20.7 21403 721 79
PostPosted: Sat Mar 25, 2017 7:15 pm
mkeflyer - FlightAware user avatar
wittrup58 wrote:
I give up. Whenever I try to post all the command lines required I end up with "Forbidden You don't have permission to access /posting.php on this server."
Take a look at the command wget.
Download this file: https://raw.githubusercontent.com/wittr ... iaware3.py
And run it by typing: optimize-gain-piaware3.py
Wait for result.
Yes, your reports will still go through to FA during the tests. Except for the apx. 600 milliseconds every time dump1090-fa restarts.
So I am finally taking a bite and here comes the dumb newbie questions: Is this script supposed to work with 3.3.0 SD image?
I was able to download via the wget command but when I try to run via the above command I get "command not found".
I am very much a follow directions kind of person as I have zero clue what I am doing with any of this piaware stuff other than what a step by step writing would tell me.
PostPosted: Tue Mar 28, 2017 9:45 am
I too am a noob here, and wish to run a Gain script on my 3.30 SD image. though getting errors too. I have tried 3 different scripts but all seem to be written for other builds.
PostPosted: Tue Mar 28, 2017 11:03 am
chrisjohnston50 - FlightAware user avatar
I can't figure this stuff out either.
Can someone lend me their "PiAware for Dummies"?? :oops:
PostPosted: Tue Mar 28, 2017 11:41 am
Think the python paths are different too.
pi@piaware:/$ sudo find -name "python*"
./usr/lib/python2.7
./usr/lib/python3
./usr/share/nano/python.nanorc
./usr/share/gcc-4.9/python
pi@piaware:/$
pi@piaware:~$ python -V
-bash: python: command not found
pi@piaware:~$
I honestly dont think it is installed under PiAware 3.3.0
PostPosted: Tue Mar 28, 2017 12:01 pm
It's not, but you can install it via apt-get.
PostPosted: Tue Mar 28, 2017 6:21 pm
Thanks for that. I wasnt sure on the Build of PiAware.
PostPosted: Tue Mar 28, 2017 6:26 pm
So I am running mutability on an RPi 3 with a Prostick Plus. Do I need to adjust the gain in piaware-config and in the dump1090-mutability file?
PostPosted: Tue Mar 28, 2017 6:31 pm
I would post the full script and process for piaware but for some unknown reason I keep getting
Forbidden
even though I am posting within the limit.
guess it wont let me post code or ascii characters.
I have made the file available to download instead with a brief readme.txt file on instructions. hope this helps anyone with a Standard piaware setup.
https://www.conligwx.org/files/piware_gain_script.zip
PostPosted: Wed Mar 29, 2017 3:27 pm
Forbidden
So this doesn't do anything for the SD Card Image based PiAware. Nothing works.
PostPosted: Wed Mar 29, 2017 5:07 pm
so do I guess what error message you get?
how can anyone help you if you just say it "doesnt work" or is that the error message?
if you followed the instructions in the zip file, installed python2.7 onto your piaware 3.3.0 card, and then copy the python script over to you card as well
run the correct command, and you get an error message of "NOTHING WORKS" ????
PostPosted: Wed Mar 29, 2017 5:30 pm
Same thing as above : "command not found"
There is no file structure other than one folder. PiAware itself is installed on the SD Card hence the image. Using the included commands from the walk through resulted in nothing happening.
PostPosted: Thu Mar 30, 2017 2:09 am
and what "command is not found" ? -please copy, paste the exact input/output you are using, there are several commands I have listed in the readme, do I have to guess what one you used to diagnose you fault?
have you installed Python2.7?
have you installed the "optimize-gain-piaware.py" file from the zip file and placed it into the correct folder?
did you run the command as
or
./optimize-gain-piaware.py
or
sudo ./optimize-gain-piaware.py
try them all.
it works here
here is the example from logon and running the script. I adjusted the script for a quicker run. measure_duration = 10 #seconds ntests = 5
login as: pi
pi@172.16.10.73's password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Mar 29 22:24:56 2017 from homepc
SSH is enabled and the default password for the 'pi' user has not been changed.
This is a security risk - please type 'passwd' to set a new password.
pi@piaware:~$ ls
pi@piaware:~$ sudo ./optimize-gain-piaware.py
test 1 of 5
gain= 49.6 messages= 1440 positions= 115 planes= 13
gain= 48.0 messages= 1392 positions= 100 planes= 11
gain= 44.5 messages= 1274 positions= 101 planes= 12
gain= 42.1 messages= 1380 positions= 113 planes= 13
gain= 40.2 messages= 1500 positions= 116 planes= 12
gain= 38.6 messages= 1223 positions= 91 planes= 13
gain= 36.4 messages= 1182 positions= 97 planes= 12
test 2 of 5
gain= 49.6 messages= 1308 positions= 107 planes= 14
gain= 48.0 messages= 1222 positions= 95 planes= 11
gain= 44.5 messages= 1151 positions= 102 planes= 11
gain= 42.1 messages= 1126 positions= 88 planes= 10
gain= 40.2 messages= 1118 positions= 81 planes= 14
gain= 38.6 messages= 1114 positions= 101 planes= 13
gain= 36.4 messages= 1236 positions= 106 planes= 11
test 3 of 5
gain= 49.6 messages= 1584 positions= 126 planes= 16
gain= 48.0 messages= 1736 positions= 127 planes= 15
gain= 44.5 messages= 1682 positions= 145 planes= 14
gain= 42.1 messages= 1713 positions= 158 planes= 16
gain= 40.2 messages= 1676 positions= 157 planes= 18
gain= 38.6 messages= 1598 positions= 162 planes= 14
gain= 36.4 messages= 1463 positions= 132 planes= 13
test 4 of 5
gain= 49.6 messages= 1687 positions= 142 planes= 15
gain= 48.0 messages= 1762 positions= 145 planes= 14
gain= 44.5 messages= 1779 positions= 139 planes= 14
gain= 42.1 messages= 1644 positions= 129 planes= 13
gain= 40.2 messages= 1599 positions= 125 planes= 13
gain= 38.6 messages= 1332 positions= 114 planes= 13
gain= 36.4 messages= 1407 positions= 108 planes= 12
test 5 of 5
gain= 49.6 messages= 1751 positions= 130 planes= 14
gain= 48.0 messages= 1918 positions= 141 planes= 15
gain= 44.5 messages= 1538 positions= 114 planes= 13
gain= 42.1 messages= 1582 positions= 124 planes= 11
gain= 40.2 messages= 1248 positions= 95 planes= 11
gain= 38.6 messages= 1206 positions= 106 planes= 11
gain= 36.4 messages= 1162 positions= 93 planes= 10
===Totals===
49.6 7770 620 27
48.0 8030 608 24
44.5 7424 601 24
42.1 7445 612 22
40.2 7141 574 24
38.6 6473 574 23
36.4 6450 536 24
pi@piaware:~$
PostPosted: Thu Mar 30, 2017 11:20 am
Gain Optimization Script for Piaware 3.3 Image
One hour ago, I downloaded Piaware 3.3 image, formatted a spare microSD card, wrote Piaware3.3 image.
I then executed the procedure listed below. It worked.
(1) Install Python:
pi@piaware:~$ sudo apt-get install python
(2) Create new blank file:
pi@piaware:~$ sudo nano optimize-gain-piaware3.py
(3) Copy code in my post for Piaware 3.0.4 image on page 3 of this thread (CLICK HERE), and paste it in newly created file "optimize-gain-piaware3.py". Save file.
(4) Make executable the file "optimize-gain-piaware3.py"
pi@piaware:~$ sudo chmod +x optimize-gain-piaware3.py
(5) Run the code
pi@piaware:~$ sudo ./optimize-gain-piaware3.py
test 1 of 5
gain= 49.6 messages= 10304 positions= 755 planes= 62
PostPosted: Thu Mar 30, 2017 12:45 pm
wittrup58 - FlightAware user avatar
abcd567 wrote:
(1) Install Python:
(5) Run the code
test 1 of 5
Untested! Should work...
Replace step 2 & 3 with:
pi@piaware:~$ wget https://raw.githubusercontent.com/wittrup/piawarebash/master/pyh/optimize-gain-piaware3.py
PostPosted: Thu Mar 30, 2017 5:27 pm
Don't forget to use alo -10 (AGC) in the test script. After a lot of testing, we found that it still provided the best setting, over time.
/M
PostPosted: Fri Mar 31, 2017 4:17 pm
(1) Install Python:
(5) Run the code
test 1 of 5
Thank you for the steps for stupid people. 8) Not all of us are Pi savvy but I have it running now.
PostPosted: Sat Apr 01, 2017 5:48 am
rsmath - FlightAware user avatar
i'm extremely pi stupid (I see the steps in a nearby post how to setup a script but I don't know how to access the pi to do those steps).
I think I need to do a gain adjustment using the new piaware stick plus that just came.
What I want to know is if I can avoid the script stuff that's been dominating this thread and just edit a line in a config text file or something on the sd card of my piaware. Can I put the SD card in my windows pc SD card slot, navigate to a config text file, edit a gain setting in that file, put the sd card back in the pi and do a pi reset command from the FA ADS-B user page where you have dropdown piaware commands?
Alternately, can I use windows explorer to connect to the PI through my home network to edit a config text file?
thanks from someone who is more at home with arduino.
PostPosted: Sat Apr 01, 2017 6:12 am
If you know the gain you want, then yes you can do exactly that. Edit piaware-config.txt on the sdcard (it is on the first, FAT, partition so should be visible on Windows etc) and edit in a line like this:
rtlsdr-gain 40
Replace 40 with the gain you want. Save the file, safely-eject the sdcard, return it to the Pi.
This thread is more about automatically finding the "right value" but you can always do manual trial-and-error.
PostPosted: Sun Apr 02, 2017 12:45 pm
/M
when set at -10 is there any actual command to find what it is really set at?
"sudo systemctl status dump1090-fa -l" shows the Gain at 0.00 dB
Users browsing this forum: danoxx, PE2KM and 1 guest
