Post new topic Reply to topic  [ 416 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17
 Post subject: Re: What is the Maximum Range I can Get?
PostPosted: Tue Dec 20, 2016 4:03 pm
Akissack - FlightAware user avatar
mgunther wrote:
hixter wrote:
Without reading through all 15 pages of posts (although I will probably do so at some point) is it safe to assume that these snazzy new features won't work with a new PiAware 3 installation that uses the OpenStreetMap data instead of Google Maps?
Yes that is my understanding also. @lignumaqua would need to re-write all that stuff to work with the OpenStreetMap. I hope he will do so soon;)
I have managed to get the range plot working with open layers. moving onto heatmap next
PostPosted: Tue Jan 03, 2017 3:02 pm
m82g - FlightAware user avatar
Can you explain how you managed to get the range plot?
PostPosted: Wed Jan 04, 2017 2:59 pm
Sure, I seem to have problems posting PM's etc and dont want to clutter this thread. PM your email address and I'll send details
PostPosted: Fri Jan 06, 2017 6:11 am
MikeMathee - FlightAware user avatar
Could you post the instructions on a new thread? I'm sure there is going to be a few interested in it, like me.
PostPosted: Sat Jan 07, 2017 5:59 am
PeterHR - FlightAware user avatar
... and once done - edit / update post 1 on the thread so it always has the latest detail version.
PostPosted: Mon Jan 16, 2017 9:03 pm
rack201 - FlightAware user avatar
Hi,
I'm just starting out and I"ve been through the thread but its not clear to me if I can get the range rings from heywhatsthat.com setup under windows? I'm usingn an SDRplay with dump1090 and VRS. On Windows I can't see any of the referenced json files to edit/add?
PostPosted: Wed Jan 25, 2017 9:45 am
bergmanmartin - FlightAware user avatar
Hullo,
A question about purging existing predicted-range rings from map:
Apart from the concentric distance rings I have added terrain-limit rings to the dump1090-mutability local gmap, using the coordinates data in the /usr/share/dump1090-mutability/html/upintheair.json file generated at the heywhatsthat.com site. The "problem" is that these rings don't match reality very well. So I figured it would be interesting to try to substitute a custom hand-made json file, based on several weeks statistical experience and actual range maps from PF.
What confuses me now is the fact that I simply can't make the map "forget" the original set of rings. In order to reach a "blank slate" state in regard to this I have deleted the upintheair.json file, and also commented out the whole section in /usr/share/dump1090-mutability/html/script.js that deals with the generation of terrain-limit rings.
Even so, the rings are still drawn on the map! The polylines are are pretty complex, so it is obvious that the coordinates are stored permanently somewhere else between reboots. But where? What can I do to get rid of those existing, irrelevant rings?
PostPosted: Wed Jan 25, 2017 10:17 am
It's probably just cached in your browser, try clearing your browser cache.
PostPosted: Wed Jan 25, 2017 10:29 am
That simple, huh?
Excuse me while I empty my cache... Wait... Yes, indeed!
PostPosted: Tue Mar 14, 2017 3:34 pm
k5ted - FlightAware user avatar
Still working on maximum range...
50nm rings
PostPosted: Wed Mar 15, 2017 12:49 pm
@k5ted:
Wow, maximum range exceeds 450 nm (extends beyond 9th 50nm ring).
How did you manage to get such a maximum range?
PostPosted: Wed Mar 15, 2017 9:43 pm
abcd567 wrote:
@k5ted:
$10 Ground Plane and the 15dB LNA, at 50'-ish. BUT... Seems as if in any direction, the max caps off at 480nm or so. Is that the end-all, maximum radio horizon, or is it artificially created by the VR software?
PostPosted: Thu May 04, 2017 12:34 pm
yeu2 - FlightAware user avatar
My new site is up and the statistics are really nice. The setup is co-co 12 elements, 33ft(10m) of RG6, FA stick(with bandpass filter, the blue one), pi3. The range is ~240nm with peaks to 270nm.
PostPosted: Mon May 08, 2017 1:03 am
toxx - FlightAware user avatar
Good range to Transylvania, as i see you are near Ploiesti, and to W, WNW direction you have lots of mountains. Probably doesn't matter as anyway over the mountains the planes are 10000ft+ so you still catch them. You might want to use a LNA for 10 meters of cable and regardless of that, it helps for range. What kind of CoCo do you have, shorted end or open end , matching impedance resistance on top ?
BR,
Radu
[quote="yeu2"]My new site is up and the statistics are really nice. The setup is co-co 12 elements, 33ft(10m) of RG6, FA stick(with bandpass filter, the blue one), pi3. The range is ~240nm with peaks to 270nm.
PostPosted: Fri May 12, 2017 5:08 pm
The coco is an open ended one with last segment the same length as the other ones. I've also had the possibility to cut the last segment in half and short the core to the shield layer but I've preferred the open ended design for sake of simplicity. I've made more than one antennas with small different segments lengths hoping to get the best matching in frequency and as I saw there where no problems with differences of 2-3mm/segment, all the antennas performed really well. I don't have the instrumentation needed to measure the impedance of the antenna and make a stub or add a resistor to adapt it to the cable run but this doesn't seem to be a problem. I saw something interesting, the message rate on dump1090 is around 2200 msgs/s with mode ac enabled but as traffic increases(more than 100 targets) the number of messages drops most probably because there is too much information and the receiver cannot decode it(130 targets with 1700 msgs/s). So if I add a 10db amp most probably the situation will get worst. The site is located 8km SE of Targoviste, Dambovita, Romania, in Lazuri county for a more precise location.
I also have another site in Targoviste, Dambovita, Romania, and that antenna is exposed directly to the outer environment and it also works fine, the problem here is the spectrum pollution, I have a GSM site near to the antenna and the receiver is saturated if the antenna is exposed directly to the GSM antennas. So I've had no option but to hang it on a locker that serves as a shield so I've lost around 90-120* of the skies but the range is surprisingly good on the remaining sight. Also the segments are hydro isolated with heat shrinking tube and mastic and reinforced with zip ties.
What is saw on this forum is that people is trying a lot of various antenna designs that are more or less reliable and the effort to build that antennas is not negligible . A four segment coco antenna has the length of 46cm / 18 in (or less with the last segment cut in half) and works really well. It can also be directly exposed to the outer environment by hanging it on any surface and it is not mandatory to keep the antenna standing with the top up, it can also hang top down. I have a small backup antenna for tests that works excellent and it hangs top down. It took around 15 minutes to build that so my suggestion for everyone is to build one coco antenna of 4, 8 or 12 segments and give it a try before trying other designs or spending the money to buy an antenna.
Andrei
Backup antenna 4 segments coco hanging top down, cable run of around 1m / 3 ft.
My 2nd site, 12 segments coco, 10m / 33ft cable run, 1090 bandpass filter(fa blue one), orange stick, pi3.
PostPosted: Sat May 13, 2017 2:35 am
This is with my 8 legged spider made from coax cable only (ab cd's solution), no filter, cheap 75 ohm cable , about 3.5 meters long
Note that i can't see anything behind me (towards Oman) as the building is faced NW (where the antenna sits)
Users browsing this forum: jojo3544, leearmstrongpf, navzptc, slammer99uk and 1 guest
