 Post subject: location being incorrect
PostPosted: Wed Mar 08, 2017 12:51 pm
flieger28 - FlightAware user avatar
I have a question regarding entering the location.
I looked the location up on an Website and put it in the "configure location" box on the website.
Is that enough? Or must i enter it also in the dump1090 configuration, in my case dump mutability?
Because i have entered the correct location but the webpage still says location incorrect.
Regards
Eike
 Post subject: Re: location being incorrect
PostPosted: Wed Mar 08, 2017 12:54 pm
Which webpage?
PostPosted: Wed Mar 08, 2017 1:04 pm
My-ADS-B
Where i can configure the location of the receiver
Anomaly report for PiAware feeder with a MAC address of XXX:
This feeder is not being used for multilateration because its timing information appears to be unreliable. This can be caused by the site location being incorrect, or because your Pi is running out of free CPU.
PostPosted: Wed Mar 08, 2017 1:27 pm
sloefkesloeber - FlightAware user avatar
if you're feeding via a raspberry, maybe your pi is not set correctly in it's configuration
did you set your location in it ?
in terminal use " sudo raspi-config "to access the configuration part where you can set your location/time region
PostPosted: Wed Mar 08, 2017 1:33 pm
Yeah, i guess that's the problem. Haven't set the location in the pi, only on the Webpage :(
PostPosted: Wed Mar 08, 2017 1:44 pm
Setting the location on the stats page is sufficient. However piaware won't notice the change until it reconnects or about 6 hours has passed. I forced a reconnection so it should be using the new location now.
PostPosted: Wed Mar 08, 2017 2:06 pm
Thank's
Yes it worked
Feeder Type: PiAware (Debian Package Add-on) 3.3.0
Multilateration (MLAT): Supported / Enabled (synchronized with 102 nearby receivers)
Users browsing this forum: agretch, Google [Bot], jluebbe, tdrane and 1 guest
