Post new topic Reply to topic  [ 512 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21
 Post subject: Re: Announcing PiAware 3! (Latest version: 3.3.0)
PostPosted: Wed Feb 01, 2017 7:20 pm
nick0909 wrote:
Is there an easy way to get the config back to run the web server on 8080 again? I have pi-hole running on my PiAware and before they used different ports so it wasn't an issue, but now that the web interface got moved to 80 it no longer shows up because pihole is already configured there.
The config lives under /etc/lighttpd/, you can use that as a basis for whatever you want it to coexist with. I don't know how pi-hole configures things so I can't be more specific.
PostPosted: Thu Feb 09, 2017 1:00 am
geckoVN - FlightAware user avatar
w7psk wrote:
Did sudo apt-get update then upgrade and reboot, My ADS-B says Im still running 3.1.0?
I've been having a somewhat similar issue.
I've got two Pi3b's co-located so I can compare antennas or other changes made to one system while keeping the other as a reference.
The two were installed a few months apart, but both using SD image 3.1.0.
I can't remember, but probably downloaded the image again for the second install.
The second Pi is behaving as you'd expect with the 3.3.0 upgrade (initiated from the Web control panel).
The first on the other hand goes through the motions and happily reports a successful upgrade until it restarts, then after a reboot, it reports 3.1.0 again.
It's not a big deal, but interesting all the same.
The main reason I haven't just loaded a clean install is that the local power is not particularly reliable and it's an easy way to know the power has been out even when I'm out of the country.
cheers,
ian
PostPosted: Thu Feb 09, 2017 8:32 am
Are you upgrading from a shell or via a command on the stats page?
The stats page command will send off an upgrade request, but there's no feedback path to say whether that request eventually succeeded or failed (you'll need to look at the logs)
My experience so far with triggering auto upgrades is that around 5% of installs have some type of problem that prevents the upgrade happening. Broken DNS, problems connecting to flightaware.com for the new packages, and sdcard corruption affecting the package management state are the three main cases I see.
PostPosted: Thu Feb 09, 2017 12:29 pm
I'm initiating the upgrade from "a command on the stats page".
What is odd is that it doesn't fail. The log shows a successful upgrade and the Stats Page reports "Feeder Type: PiAware (SD Card) 3.3.0".
Then, after a restart, it reverts to 3.1.0.
As it continues to decode the whole time, it doesn't seem to be a big deal.
PostPosted: Thu Feb 09, 2017 1:03 pm
That is completely bizarre, I don't know what is going on there.
PostPosted: Thu Feb 09, 2017 10:17 pm
That's reassuring - I thought it was just me!
PostPosted: Fri Feb 10, 2017 9:28 pm
astrodeveloper - FlightAware user avatar
I suspect it might be a cache issue. Many of the browsers save parts of a web page to save redownloading a page or parts of a web page. Clearing the cache is a quick fix, but then you likely lose saved passwords and such.
Give it some time, perhaps reboot the pi or restart your browser. This cleans up most of my problems. YMMV. (Your mileage may vary, always less, seldom more)
PostPosted: Sun Feb 12, 2017 4:54 am
It's not a (PC) cache issue as the Pi continues to report 3.3.0 for weeks, but immediately after a reboot, reverts to 3.1.0 (I can send screen shots if it would help).
PostPosted: Mon Feb 13, 2017 1:28 pm
bbowers - FlightAware user avatar
Was looking to upgrade my install to the latest from 3.1.0... I can't find the send command option on my stats page at all. Am I missing something?
"You may upgrade by using "Send command to device" and selecting the option "Upgrade and restart PiAware" on the My ADS-B Stats page."
PostPosted: Mon Feb 13, 2017 1:36 pm
sparkie624 - FlightAware user avatar
I had to download the image and then write it to the Micro SD Card in the PI from my main computer. You can download it from:
https://flightaware.com/adsb/piaware/build
Go to step 2 and that should work. that is what I had to do and it is working fine.
PostPosted: Mon Feb 13, 2017 1:43 pm
This is unfortunately a bug with 3.1.0 package installs, they can misreport their install type which prevents the send command option from appearing.
You should be able to upgrade manually via "sudo apt-get update" / "sudo apt-get install piaware"
PostPosted: Mon Feb 13, 2017 3:50 pm
Ok cool... this worked... now showing Feeder Type: PiAware (Debian Package Add-on) 3.3.0. Still no send command available. However, the webpage interface still shows version 3.1.0...is that normal?
EDIT: Spoke too soon, I see send command now and have updated dump1090 to 3.3.0. Thanks!
Users browsing this forum: david.baker, Google [Bot], MrNuke, rijulraju and 1 guest
