 Post subject: Problems in piaware installation
PostPosted: Sun Feb 12, 2017 5:03 am
joeshee - FlightAware user avatar
Hello everyone,
I was trying to install piaware in another sd card to use it with the free kit received. I followed the instructions provided here https://flightaware.com/adsb/piaware/install
When I run
sudo piaware-status
it gives me the following error:
PiAware master process (piaware) is running with pid 1794.
PiAware ADS-B client (faup1090) is not running.
PiAware mlat client (fa-mlat-client) is not running.
Local ADS-B receiver (dump1090) is not running.
no program appears to be listening for connections on port 30005.
faup1090 is NOT connected to the ADS-B receiver.
piaware is connected to FlightAware.
got 'couldn't open socket: connection refused'
dump1090 is NOT producing data on localhost:30005.
Here's my piaware.log
Feb 12 09:46:39 raspberrypi piaware[1794]: piaware version 3.3.0 is running, process ID 1794
Feb 12 09:46:39 raspberrypi piaware[1794]: your system info is: Linux raspberrypi 4.4.38-v7+ #938 SMP Thu Dec 15 15:22:21 GMT 2016 armv7l GNU/Linux
Feb 12 09:46:41 raspberrypi piaware[1794]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Feb 12 09:46:46 raspberrypi piaware[1794]: no ADS-B data program seen listening on port 30005 for 7 seconds, next check in 60s
Feb 12 09:46:46 raspberrypi piaware[1794]: Connection with adept server at piaware.flightaware.com/1200 established
Feb 12 09:46:47 raspberrypi piaware[1794]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Feb 12 09:46:48 raspberrypi piaware[1794]: FlightAware server certificate validated
Feb 12 09:46:48 raspberrypi piaware[1794]: encrypted session established with FlightAware
Feb 12 09:46:48 raspberrypi piaware[1794]: logged in to FlightAware as user joeshee
Feb 12 09:46:48 raspberrypi piaware[1794]: my feeder ID is xxxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Feb 12 09:47:16 raspberrypi piaware[1794]: 0 msgs recv'd from dump1090; 0 msgs sent to FlightAware
Feb 12 09:47:46 raspberrypi piaware[1794]: no ADS-B data program seen listening on port 30005 for 67 seconds, next check in 60s
How do I start these services?
faup1090, dump1090 and fa-mlat-client
Do I need to install some other packages to run them? I already tried "sudo service dump1090-fa restart" but that didn't help either.
 Post subject: Re: Problems in piaware installation
PostPosted: Sun Feb 12, 2017 8:34 am
The "free kit" is a FlightFeeder that FA is loaning to you. You need to run the FlightFeeder software on it; please use the sdcard provided. If you need a new sdcard or need to reimage the sdcard, please contact adsbsupport@flightaware.com.
Users browsing this forum: ebugakov, turracaine and 1 guest
