 Post subject: Problem with Dump1090
PostPosted: Tue Jan 19, 2016 3:45 pm
jpdies - FlightAware user avatar
Switched my piaware antenna from old Pi to newer Pi2. New Pi is giving me this error when I tried to run dump1090 --interactive To see if data was being collected.
Found 1 device(s):
0: , , SN (currently selected)
usb_open error -3
Please fix the device permissions, e.g. By installing the udev rules file rtl-sdr rules
Error opening thr RTLSDR device: Permission denied
Flightaware found my second Pi feeder but it only lists the original Pi ip address on the stats page.
I plan on using 2 feeders to compare antenna quality.
Would appreciate any help.
 Post subject: Re: Problem with Dump1090
PostPosted: Tue Jan 19, 2016 4:02 pm
Are you running the piaware image or another image?
Have you checked:-
/tmp/piaware.out
sudo piaware-status
PostPosted: Tue Jan 19, 2016 4:31 pm
idh - FlightAware user avatar
The new Pi2 has the drivers for the dongle to behave as a DVB-T device.
You need to blacklist those.
Install of dump1090 should have done that.
You can try these instructions to see if it fixes the problem or reinstall dump1090.
You need to create two text files: one to allow user “pi” to access the dongle and one to remove the built-in driver for the dongle.
Source for this info is http://forum.flightradar24.com/printthread.php?t=6133&pp=40&page=24and http://www.satsignal.eu/raspberry-pi/dump1090.html if you want to look further.
First run the command
lsusb
For the DVB-T dongle, two sets of numbers/letters are important – in my case “0bda:2838”
Now run the text editor
sudo nano /etc/udev/rules.d/rtl-sdr.rules
and copy the following
SUBSYSTEMS=="usb", ATTRS{idVendor}=="0bda", ATTRS{idProduct}=="2838", MODE:="0666"
modifying the two items 0bda and 2838 to match your dongle.
Use Ctrl-O to save and Ctrl-X to exit nano.
To remove the built-in drivers is similar
sudo nano /etc/modprobe.d/no-rtl.conf
Add the lines
blacklist dvb_usb_rtl28xxu
blacklist rtl2832
blacklist rtl2830
Save and exit.
Reboot the pi and should now be ok. If not further investigation needed.
PostPosted: Tue Jan 19, 2016 5:44 pm
idh
After a lot of typos on my part,
Its. WORKING
Thanks for your help!!!!
Jim
Users browsing this forum: dschre, ldefranco and 1 guest
