Post new topic Reply to topic  [ 8 posts ]
 Post subject: Boeing still stalling the Dreamliner?
PostPosted: Tue Jul 02, 2013 5:31 pm
greglinton13 - FlightAware user avatar
hey guys,
I was on flightaware about a week ago and i accidentally found 787 without a tail number flying. It turns out to be Boeing's 5th 787. I noticed it's been making some really weird flights in the past 2 weeks, whether its a 8 hour circle around KBFI or flying into the middle of no where. Why would Boeing be testing the 787 so late? looking at the graphs, I can clearly tell that the crew tested multiple stalls, etc. Would someone like to take a look just look up BOE5 on flightaware and see for yourself
 Post subject: Re: Boeing still stalling the Dreamliner?
PostPosted: Tue Jul 02, 2013 5:56 pm
It may not be actual stalls, the radar reported ground speeds in the US and Canada tend to dip when turning.
PostPosted: Tue Jul 02, 2013 6:25 pm
jimcander - FlightAware user avatar
greglinton13 wrote:
hey guys,
Any number of reasons. Flight software mod testing? Something changed aerodynamically that might show up on new (and old) birds? Something for the -9 or -10? The list goes on and on...
PostPosted: Wed Jul 10, 2013 10:09 pm
Lonewolf24 - FlightAware user avatar
FlightAware is registering BOE5 as a Boeing 737-800 - um, last I checked, that isn't a 787 Dreamliner.... :wink:
PostPosted: Wed Jul 10, 2013 10:44 pm
rw812 - FlightAware user avatar
BOE5 was both a 788 and a 738 on 10 July 2013.
http://flightaware.com/live/flight/BOE5 ... %2070/KBFI
http://flightaware.com/live/flight/BOE5 ... 20230%2070
PostPosted: Wed Jul 10, 2013 10:47 pm
greglinton13 wrote:
... accidentally found 787 without a tail number flying. ... Why would Boeing be testing the 787 so late? looking at the graphs, I can clearly tell that the crew tested multiple stalls, etc.....
Don't confuse tail number and flight ID - BOE5 is a flight ID. The tail number, for USA registered aircraft, is a 3 to 5 alphanumeric string.
Boeing tests all aircraft prior to their delivery to customers so it's not unusual to have an established aircraft (e.g. 737) perform multiple stalls prior to delivery.
PostPosted: Thu Jul 11, 2013 10:34 am
I think they use the last couple digits of the line number as the flight number, so any time a 737 comes out XXnn005 it will fly as BOE5.
PostPosted: Fri Jul 12, 2013 10:41 pm
jrl22 - FlightAware user avatar
I was a flight test engineer at Boeing starting in Feb 79, was Test Director on the #4 767 and several others (including "Spirit of Delta" which resides at the DL museum in ATL) from Dec 81 thru Sep 82
they actually use what is called the Tab (Tabulation) Number ... each model has a unique first letter (as I recall, major production variants get unique second letters), and customer orders are assigned blocks of numbers ... here's what I remember
727-200 is Q (the 727-100 was E followed by four numbers)
737-200 is P
747 is R (the #1 jet at the Museum of Flight is RA001)
757-200 is N
767-200 is V
777-200 is W
787 is Z
> UA was the launch customer for the 767-200 with an order for 19 jets; they were Tab Numbers VA002-VA020 (again, the #1 jet was VA001)
> DL was the second customer and had Tab Numbers VA301-VA315 for their -200s
> other early 767-200 customers were AA and TW; their blocks started at VA501 and VA801 (not sure which was which)
when VA004 was on a test flight we would use "Boeing 004" as our call sign ... if the #4 757 (NA004) was going to be in the air before we landed, they would typically use "Boeing 574" or something similar ... on occasion there were two production jets with the same block numbers but different tabs (for example, 737s with Tab Numbers PH478 and PN478 -- these may or may not be real; one might be a -700 and the other a -900); one would file with the Tab Number and the other would likely use its production line number ... note that the Tabulation Blocks are irrespective of production line number, since customers typically take delivery of a block of jets over several years; I seem to recall that they are assigned in increments of 10 (and "in bulk" for many orders, particularly if the customer includes options), so not all Tab Numbers in a Tab Block may actually be produced
the #1 jets typically used the model number as their call sign (e.g., "Boeing 747" and "Boeing 767")
here are some examples of downstream Tab Blocks:
> NW was the launch customer for the P&W JT9D-7Q engine on the 747-200; their first jet was RD251 and the call sign throughout the certification flight test program was "Boeing 251"
> the four 767-200s converted to AWACS for Japan were VF181-VF184
> the first in the block of 20 British Airways 737-200s delivered around 1980 was PK731; it required a rather extensive flight test program for CAA certification and was known as "Boeing 731" for most of that period
> the 747SPs were tabbed RG and RH; the two that were delivered to TWA were RG191 and RG192
> I think the first 767-300 was VN001
