SOAP requests must use /soap/FlightXML2/op as the endpoint, and the request must be encoded as an XML document in the standard SOAP request body format.
I recommending using the JSON interface to FlightXML instead, if you are needing to generate and parse the bodies manually.
Download the json2.js parser from Douglas Crockford's JSON in JavaScript project at
https://github.com/douglascrockford/JSON-jsSave the following file as test.asp, but substitute your actual username and API key:
<script language="javascript" runat="server" src="json2.js"></script>
Dim postData, httpRequest, jsonResponse
postData = "airport=KAUS"
postData = postData & "&howMany=10"
postData = postData & "&filter=airline"
Set httpRequest = Server.CreateObject("MSXML2.ServerXMLHTTP")
httpRequest.Open "POST", "http://flightxml.flightaware.com/json/FlightXML2/Arrived", False, "YOUR_USERNAME", "YOUR_APIKEY"
httpRequest.SetRequestHeader "Content-Type", "application/x-www-form-urlencoded"
httpRequest.Send postData
If httpRequest.status = 200 Then
Set jsonResponse = JSON.parse(httpRequest.responseText)
For Each flight In jsonResponse.ArrivedResult.arrivals
Response.Write("Flight " & flight.ident & " is arriving from " & flight.origin & "<br>")
Next
Else
Response.Write("Error occurred")
End If
Set httpRequest = Nothing
