10:10AM EDT
Post new topic Reply to topic  [ 23 posts ]
 Post subject: Pilot unresponsive; Plane circling over Gulf of Mexico
PostPosted: Thu Apr 19, 2012 11:01 am
http://www.abc-7.com/story/17585126/pil ... -of-mexico
Posted: Apr 19, 2012 8:44 AM PDT
Updated: Apr 19, 2012 8:44 AM PDT
A private plane is circling over the Gulf of Mexico and the pilot is "incapacitated," and apparently unconscious.
NBC's Pete Williams says authorities are tracking the plane and expect it to soon run out of fuel and crash into the water.
The U.S. Coast Guard is repositioning its assets, according to Williams, to try to help with a rescue.
There is no exact location for the plane yet, but CNN has been told it is closer to Florida than other Gulf states.
 Post subject: Re: Pilot unresponsive; Plane circling over Gulf of Mexico
PostPosted: Thu Apr 19, 2012 11:15 am
http://flightaware.com/live/flight/N48D ... /KASD/KSRQ
PostPosted: Thu Apr 19, 2012 11:22 am
Yep, I've been watching it too. Sad. As I was taking screen shots of the flight path -- I watched as the plane icon "bleeped" off the screen.
*The planed disappeared from screen at 9:19 a.m. (Pacific)
PostPosted: Thu Apr 19, 2012 11:37 am
Plane crashed in water close to florida coast
PostPosted: Thu Apr 19, 2012 1:27 pm
NeedleNose - FlightAware user avatar
http://flightaware.com/live/flight/N48DL/history/20120419/1230Z/KASD/KSRQ
PostPosted: Thu Apr 19, 2012 3:45 pm
Very sad. :( Wonder what happened? I read the F-15s reported iced over windshields. Possible cabin air problem? Passed out? :(
421 to 35,000 - that's quite a leap. (news reported)
PostPosted: Thu Apr 19, 2012 5:24 pm
Likely hypoxia due to cabin pressurization failure. Not the first time: http://aviation-safety.net/database/rec ... 19991025-1
PostPosted: Thu Apr 19, 2012 6:58 pm
Is it normal for small twins to route over so much water? I realize it would save time and gas but....
PostPosted: Thu Apr 19, 2012 9:25 pm
I doubt that ac was RVSM'd. The airplane was flying itself by the time he entered RVSM airspace.
Also the flight plan said REDFN Q100 SRQ and the track on FA shows something other then that.
I assume that once reaching REDFIN the auto pilot went into a hold. The west track of his hold is due to the wids aloft.
PostPosted: Thu Apr 19, 2012 11:32 pm
Jason, why a hold at REDFIN? In a typical GPS like the 430/530 is this what happens when you get to the last point defined? Just goes in circles if it is in the nav mode? Never thought about that before.
PostPosted: Fri Apr 20, 2012 8:22 am
Yep, see the Helios 737 accident: http://aviation-safety.net/database/rec ... 20050814-0
PostPosted: Fri Apr 20, 2012 11:11 am
Is it that hard for someone to make a Oxygen % detector gauge?
PostPosted: Fri Apr 20, 2012 12:40 pm
It's not a lack of O2 it's a lack of pressure.
If we had an explosive de-compress he wouldn't have had very long to don mask. If he was in poor physical shape he would've reacted even worse to the de-compress the someone more healthy.
PostPosted: Fri Apr 20, 2012 1:11 pm
Heard of this hours ago, but hadn't commented expecting more details to be out. TIME article states "the plane was fluctuating between 25,000 and 35,000 feet".
There are some mentions (and even a photo) of the presumed pilot on some websites.
Thought I posted this yesterday.
PostPosted: Fri Apr 20, 2012 1:41 pm
Yes, thanks, pressure is the issue I realize.
In this case it is assumed it's explosive decompression but with Helios I think it was progressive un-pressurization? As in it did not pressurize in the first place.
Can't be that hard to have a gauge that displays correct cabin pressure vs actual?
PostPosted: Fri Apr 20, 2012 2:17 pm
In pressurized AC, there is a cabin differential gauge. There are also alarms when the cabin alt gets too high.
This was most likely an explosive decompress, he would've had plenty of time to don a mask or decend if it wasn't.
PostPosted: Sat Apr 21, 2012 6:43 am
I wait for a good NTSB report.
I looks like the had a disabling event> A heart attack, pulmonary embolism, cerebrovascular accident, etc. could have rendered him uncouncious or fainted. It looks the plane was very well stabilized since it hit the water in a rather flat mode ...enough to stay a float for few minutes ..so it was NOT a plunge. It could have been that the supplemental oxygen system malfunctioned and he got trapped.
Rare to see 421 taken so high in RVSM space. Normally 421s are for FLT levels 150 to 200 if equipped for that altitude and must be checked frequently for door seal problems, oxygen equipment problems, etc. Freezing temps also can create a lot of failures in engines and systems.
It looks like the autopilot was always engaged and the GPS Nav mode went into holding pattern or circles.
Sad situation.
PostPosted: Sun Apr 22, 2012 8:29 am
Sad situation.
First- 150 is not a flight level even over the gulf
Second the aircraft windows wouldn't have frosted over because he had a heart attack etc.
PostPosted: Tue Apr 24, 2012 1:19 pm
memery - FlightAware user avatar
wow
PostPosted: Fri May 04, 2012 6:09 pm
There has been talk that the pilot was having severe financial issues... so who knows what really happened.
PostPosted: Fri May 04, 2012 6:37 pm
honestly that is speculation best kept to yourself. Rumors and hearsay...
PostPosted: Sun May 06, 2012 10:17 pm
pika1000 - FlightAware user avatar
Bad interwebs.
PostPosted: Wed May 09, 2012 2:03 am
The "rumor" was from a news broadcast in the pilot's home state, and disgruntled patients apparently have unresolved issues, so yes it
is an unsubstantiated rumor, and obviously it's a private family matter. I didn't intend to sound "gossipy", and I wasn't speculating - just
repeating what was broadcast on the news.
