Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: ARF call signs
PostPosted: Sun Feb 14, 2010 10:10 pm
Offline
Charter Member
lieberma - FlightAware user avatar
Friend of mine did an animal rescue flight. He flew IFR
ARF0JH was the tail number.
Is ARF call sign a recognized sign in Flight Aware?
Top
 Profile
 Post subject:
PostPosted: Sun Feb 14, 2010 11:20 pm
Offline
mduell - FlightAware user avatar
It's not in our list of codes, but more importantly it doesn't appear that it has been unfiltered by the FAA. The ARF organization needs to contact the FAA (we can provide them with the details) if they want to be included in ASDI.
Top
 Profile
 Post subject:
PostPosted: Sun Feb 14, 2010 11:25 pm
Offline
New FlightAware Member
damiross - FlightAware user avatar
A new search engine called Google helped me with this question.
Animal Rescue Flights
http://www.pilotsnpaws.org/forum/viewto ... f=9&t=4763
http://aviation.meetup.com/95/messages/archive/
You friend's registration is one of the following, correct? (Aircraft such as the Pitts Special and B767 and bizjets deleted from this list as are some aircraft base a long ways from Mississippi))
100JH CESSNA 310Q (most probable)
420JH BEECH G33
500JH CESSNA 182Q
510JH CESSNA 510
60JH CESSNA 414A
670JH CESSNA U206G
700JH PIPER PA-30
770JH BEECH B300
(Source: FAA Registry)
Top
 Profile
 Post subject:
PostPosted: Sun Feb 14, 2010 11:46 pm
Offline
Looks like a good organization. Before reading about it, I thought it might be connected to Tony LaRussa's Animal Rescue Foundation. This is where I got Archie (see my avatar).
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 12:02 am
Offline
Charter Member
Thanks Mark,
I will let my friend know.
Dami,
My friend resides in NY. For callsigns in cases I know of, you adopt the mission's three letters and last three numbers of your tail number to derive your mission callsign. None of the types you listed above is his plane
ARF43L would be my call sign for an ARF mission.
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 12:37 am
Offline
I know.
I also know I should have listed all of the registrations I found ending in 0JH. There were several in the northeastern USA. :)
For those interested and don't want to go to the references I provided, here's the requirements for using the ARF call sign.
Quote:
GREAT NEWS! Pilots flying animal rescue flight missions are now authorized by the FAA to use a designated call sign and three letter identifier for radio and written communication with ATC!
The designated call sign is comprised of the words "Animal Rescue Flight" followed by the last three digits of the participating aircraft's registration number and is used to identify the aircraft to ATC in place of the full registration number. For example, if your tail number is N12345, you will use ?Animal Rescue Flights 345? when communicating with ATC.
Instructions for filing a flight plan:
1) VFR or IFR flight plans that include the identifier must be filed through a Flight Service Station (FSS). The three letter "ARF" identifier cannot be used on a flight plan filed via DUATS
2) The use of the Animal Rescue Flight call sign cannot be initiated after a flight has commenced. This includes communication with ATC for the purpose of picking up flight following or radar services while airborne, requesting clearance through airspace, or on initial contact with the tower at the destination. In other words, intent to use the call sign can only be presented to an FSS or ATC for approval prior to the flight.
3) In place of the full registration number in the Aircraft Identifier section on VFR and IFR flight plans, use the three letter identifier "ARF" followed by the last three digits of the participating aircraft's registration number. For example, if your tail number is N12345, you will use ?ARF345? for the Aircraft Identifier section
4) "Animal Rescue Flights" followed by the aircraft's full registration number should be included in the Comments section. For example, if your tail number is N12345, you will put ?Animal Rescue Flights N12345? in the Comments section
If you plan to use Flight Following:
1) Pilots planning VFR flights without flight plans but utilizing "flight following" or "radar services" should identify their aircraft to Clearance Delivery or Ground Control as "Animal Rescue Flight" followed by the last three digits of their registration number. For example, if your tail number is N12345, you will use ?Animal Rescue Flights 345? when communicating with ATC
If you have any questions, please email [address removed]. This information is posted on the message board under "ARF Important Information" for your future reference.
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 9:47 am
Offline
Charter Member
coma24 - FlightAware user avatar
Damiross,
Your google search didn't really clarify much. The FA staff member certainly did, though :)
I'm well aware of the document on the meetup group...that's why I filed a flight plan using the ARF callsign to begin with. The original question was why the flight didn't show up in flightaware.
I've PM'd the FA staff as suggested. It will be an excellent tool for the ARF team members to be able to track flights, particularly the folks on the ground who are waiting for aircraft to arrive.
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 11:08 am
Offline
FlightAware Member
porterjet - FlightAware user avatar
So, if you do a round trip is the call sign ARF ARF?
sorry, been a long day.
John in Saudi
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 1:02 pm
Offline
Charter Member
I've learned that the ARF organizers have already been working with the FAA to get this data included in the feed.
Top
 Profile
 Post subject:
Offline
Charter Member
pika1000 - FlightAware user avatar
I hope they keep hounding the FAA.
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 1:04 pm
Offline
Charter Member
I think you barking up the wrong tree! :P
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 1:06 pm
Offline
Charter Member
John in Saudi
Only if you are a freight dog pilot? :lol:
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 1:17 pm
Offline
FlightAware Member
fholbert - FlightAware user avatar
I fail to see the need of using a special call sign for this or other flights like Angel Flight. Simply use your tail number.
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 1:18 pm
Offline
FlightAware Member
will744 - FlightAware user avatar
Same thing I was thinking...
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 1:20 pm
Offline
Charter Member
Frank,
From what I understand, ATC goes above and beyond for Angel Flight, Life Flight, Animal Rescue, etc. I take this to mean that they're more likely to pick up the phone and coordinate a shortcut with the next sector than they would for a normal flight. If any active controllers would care to comment, I'd love to know if that's true, or whether I'm wasting my time by using the callsign.
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 1:22 pm
Offline
coma24 wrote:
Damiross,
Yea, it didn't really clarify much.
It didn't say what the ARF call sign is. Wait! It did!
It doesn't tell how to create an ARF call sign. Wait! It did!
Quote:
And most importantly it doesn't tell you how to file using the ARF call sign. Wait! It did!
The only thing not clarified is why it wasn't in the ASDI feed.
The only reason I can see for using either of these call signs is to possibly get expedited clearances in recognition of the charitable flight.
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 1:49 pm
Offline
FlightAware Member
It's not going to happen. The 7110.65 section 2-1-4. OPERATIONAL PRIORITY clearly call out who gets what. In the civilian world that would be Emergency, Lifeguard, SAR, Nuclear Emergency Teams and Flight Check (Not check ride). Everyone else is First Come, First Served.
Frank Holbert
http://160knots.com
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 11:25 pm
Offline
Charter Member
3 answers to questions that were never asked. The original question was why the flights weren't showing up in FA, that's all.
The only reason I'm getting on your case is that you seemed to be ridiculing Allen for not using this new-fangled search technology to find the answer. The FA staff member provided the answer to the actual question.
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 11:32 pm
Offline
Charter Member
Frank, that is understood. However, there might be a 'softer' side to it. By that, I mean that a controller might be more likely to attempt to coordinate some enroute shortcuts more willingly for an Angel Flight or Animal Rescue Flight before a 'regular' flight.
I can tell you that using the callsign resulted in my landing fee being waived, ramp fee waived, and a $0.30/gal discount on gas at the FBO at KALB.
I've also heard reports of some controllers being 'PnP' (pilots 'n' paws) friendly at various facilities, although I'm not sure what that actually means.
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 11:37 pm
Offline
FlightAware Member
deef1999 - FlightAware user avatar
What is an animal rescue flight? (damn, should have used google, sorry David)
I don't get it, people are losing thier homes, living in the street, starving, going without medical care, and we're flying dogs and cats across the country to save THEM. WTH is the world coming to.
Top
 Profile
 Post subject:
PostPosted: Mon Feb 15, 2010 11:51 pm
Offline
According to the references I gave, it's basically people flying animals from a shelter that may euthanize them to an organization that won't.
While it's a good idea, I do think that priority should be given to flying and/or rescuing humans first. I remember watching a show about floods where a guy was trying to be rescued but he would not unless his dogs could come also. This idiot would rather have died with his dogs and make his wife a widow and his children fatherless than be rescused without his mutts.
Top
 Profile
 Post subject:
PostPosted: Tue Feb 16, 2010 12:00 am
Offline
Charter Member
I would happily fly for Angel Flight, but they don't allow Experimental aircraft to participate.
Aside from that, Angel Flight has precise and rigid schedules. Animal rescue tends to be considerably more flexible and informal.
Consider this, I intend to go for a recreational flight, on average, once every week. I can go punch random holes in the sky, visit a new destination, find a great place for lunch, or, I can rescue an animal from being put to sleep. If I'm going to fly for fun, and don't particularly care where I fly...why not help out an animal?
Does it honestly seem that far fetched? Yes, the world has the problems you just described. Assuming you are a pilot and used to fly for fun...have you stopped flying completely, and donated all of the money instead to causes that address the problems you listed? I certainly wouldn't expect you to do so, just like I wouldn't expect to be judged for electing to conduct flights to help save some animals, in spite of what is going on in the world.
Top
 Profile
 Post subject:
PostPosted: Tue Feb 16, 2010 12:39 am
Offline
I can't speak for Deef1999 but I for myself I dont' see anything wrong with rescuing animals provided humans are taken care of first. In your case, Coma24, I can see your point. Because you fly an experimental aircraft you can't carry Angel pax.
Even though lieberma said a friend from New York and your location is New Jersey, are you the friend he is talking about? If so, what animal did you carry? If you've flown both cats and dogs, which do you find adapts easier to being flown? What type of plane do you fly?
Just curious. Thanks.
Top
 Profile
 Post subject:
PostPosted: Tue Feb 16, 2010 12:40 pm
Offline
Charter Member
That, and my aircraft is a two-seater...hardly suitable for most Angel Flight missions.
Yes, I'm the person Allen was referring to in his post above. I mentioned in an email to him that I had just undertaken my first flight, but wasn't able to track it after the fact. He posted here to try to find out why (beating me to it).
I carried a terrier and a poodle. The poodle was a little more spirited, but settled down shortly after takeoff, particularly once the ride smoothed out. This was my first flight, so I have very little experience. Pilots I've spoken with have said that 99% of their flights go without any drama from the dogs.
The plane is a Lancair 360. See photos 27-30 for relevant pics within this album: http://aviation.meetup.com/95/photos/827311/
Top
 Profile
 Post subject:
PostPosted: Tue Feb 16, 2010 12:59 pm
Offline
FlightAware Member
Beechluvr - FlightAware user avatar
I think thats really cool you're involved in that. My wife donates her time at the local shelter and they have a website reaching out to people to adopt. She's already made me swear in blood that if I ever buy an aircraft, some of my flying would involve doing this.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
