aircrafttype encoding
Does aircrafttype return results in UTF-8 encoding? I am receiving a UTF-8 encoding error when I ask for the aircrafttype FA50, a Dassault Mystre 50. I’m guessing that the is causing the error.
{http://xml.apache.org/axis/}stackTrace:java.io.UTFDataFormatException: Invalid byte 2 of 3-byte UTF-8 sequence.
	at org.apache.xerces.impl.io.UTF8Reader.invalidByte(Unknown Source)
	at org.apache.xerces.impl.io.UTF8Reader.read(Unknown Source)
	at org.apache.xerces.impl.XMLEntityScanner.load(Unknown Source)
	at org.apache.xerces.impl.XMLEntityScanner.scanContent(Unknown Source)
	at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanContent(Unknown Source)
	at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
	at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
	at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
	at org.apache.xerces.parsers.XML11Configu... ''
Thanks,
dev444
ISO-8859-1. If you’re using UTF-8, the Mystre will throw you off.
