Dear Sir,
Finding the Flight tracker window a bit cumbersome to reach and operate. The window is not stable and changes in zoom level and size.
Why can’t we have a bigger OPEN Window, with all Aircraft and Airports visible, without asking Airport name or FLIGHT name to start with. The Percentage size of tracking window is too small and compared to that, the other DATA (of Aircraft and Airport ) takes up too much space.
Clicking an Aircraft should show SPEED,ALTITUDE, FLIGHT NAME data at least and can add DESTINATION, ORIGIN etc only If required.
The following link will provide a window for all flights localized for your area. You can move the map to wherever you would like. flightaware.com/live/. Additionally, if you hover over an airplane, it will show you flight number, aircraft type, speed, altitude, origin, and destination. If you click the airplane, it will take you to the page for that specific flight. If you click the button in the bottom right of the map, it will enlarge the map to full screen. Hope this helps.
