Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: How many people are flying at any one time?
PostPosted: Tue Dec 15, 2015 9:46 am
Offline
WarrenOpen - FlightAware user avatar
I am investigating certain myths which seem to have taken root, namely a question of "How many people are flying at any one time?", which the often repeated there are a million people flying at any one time seems to be the mythical answer.
I would be keen to find out if someone can provide a substantive answer to this query, in such a way that my year 1 undergraduate students in environmental studies can understand it. If you would happen to have a visual which shows the peak and trough of how many people typically fly in a 24 hr period, then that would be even better as it would allow them to understand the flow of flights globally.
I thank you in advance for any info or other sources of information/leads that you might be able to provide.
AND my apologies if this subject has already been discussed - but I could not locate it easily.
My kindest regards
James
Top
 Profile
 Post subject: Re: How many people are flying at any one time?
PostPosted: Tue Dec 15, 2015 12:19 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
You may be better off trying to work backwards from airport passenger data rather than forwards from the number of aircraft in the air; while you can probably count the aircraft to some extent from ADS-B data, working out the passenger load is going to be tricky.
e.g. http://www.aci.aero/Data-Centre/Annual- ... 2011-final
Atlanta @ 92M implies ~275k/day, or about 17000 "in the air" simultaneously involving that airport if you assume 1.5 hour flights evenly spread across the day (which is not going to be true, but..)
1M simultaneous sounds like it's in the right ballpark at least.
Top
 Profile
PostPosted: Wed Dec 16, 2015 9:03 pm
Offline
bob2013 - FlightAware user avatar
According to this site, they were expecting 3.3 billion people flying during 2014.
https://www.iata.org/pressroom/pr/Pages ... 30-01.aspx
Using obj's calculations which seem pretty reasonable, you get 9 million/day. With an average flight time of 1.5 hours, that would be 9m/16 = 565,000. So for there to be 1 million at any given time, the average flight time would have to be 2 hours and 40 minutes. Which world wide may very well be.
The hard part would be peaks and troughs which are local. Peak in the US is trough time in Asia and vice versa. So it probably evens out over a 24 hour period.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
