Post new topic Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18
Author Message
 Post subject: Re: What is the Maximum Range I can Get?
PostPosted: Thu Jun 15, 2017 2:12 am
Offline
FlightAware Member
Akissack - FlightAware user avatar
After several years of running adsb I've decided to get a FA dongle. You can see from the graphs that it did improve results. Very happy with my purchase.
Top
 Profile
PostPosted: Thu Jun 22, 2017 4:16 am
Offline
SoNic67 - FlightAware user avatar
CXA007 wrote:
With my homemade 12 segment collinear antenna, I see traffic 250+miles out regularly, for about 14,000 position reports a day at the 200mn+ range..
Having outside on my 39th floor balcony helps too :lol:
That's all about the height there, you have a direct line of sight of more than 310 miles!
http://www.calculatoredge.com/electroni ... fsight.htm
My antenna is only on top of my garage. I hate you :lol:
Top
 Profile
PostPosted: Thu Jun 22, 2017 11:25 am
Offline
FlightAware Member
That's NOT all about the height. The contribution of height of RECEIVING antenna is much less than the contribution of height of the plane.
A plane at 40000 feet, contributes 283 miles to line of sight.
A receiving antenna at 15 feet height (garage roof) contributes 5 miles
A receiving antenna at 390 feet height (39th floor) contributes 28 miles.
With antenna above garage (15 ft above ground), the line of sight = contribution of RECEIVING antenna + contribution of plane = 28 + 283 = 311 miles
With antenna at 39th floor (390 ft above ground), the line of sight = contribution of RECEIVING antenna + contribution of plane = 5 + 283 = 288 miles
Improvement going from Garage roof to 39th floor = 311 - 288 = 23 miles
Image.Image
If the antenna is surrounded by tall houses/buildings or trees, which block its view of horizon, then raising antenna above the height of these obstruction does improve message count and range. Once antenna is above these obstructions, any further increase in height brings in very little improvement.
Top
 Profile
PostPosted: Thu Jun 22, 2017 7:02 pm
Offline
Well yes and no... To me it is important if you have buildings (houses) around you. The further the plane is, lower to the horizon it will be. That means that my line of sight cannot reach the theoretical LOS because it will have objects in the way.
If you are at the 39th floor, probably not too many tall buildings are around you. Or at least that's what I think.
An object, even if smaller height than the antennas, if is situated between them can block the LOS. Imagine one in the middle of this figure:
As my house antenna is only at 2 feet above roof, a house at 1 block away might block me - when plane is towards the extreme of my range.
Top
 Profile
Who is online
Users browsing this forum: invergordon and 1 guest
Search for:
Jump to:
