Post new topic Reply to topic  [ 412 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17
Author Message
 Post subject: Re: What is the Maximum Range I can Get?
PostPosted: Tue Dec 20, 2016 4:03 pm
Offline
FlightAware Member
Akissack - FlightAware user avatar
mgunther wrote:
hixter wrote:
Without reading through all 15 pages of posts (although I will probably do so at some point) is it safe to assume that these snazzy new features won't work with a new PiAware 3 installation that uses the OpenStreetMap data instead of Google Maps?
Yes that is my understanding also. @lignumaqua would need to re-write all that stuff to work with the OpenStreetMap. I hope he will do so soon;)
I have managed to get the range plot working with open layers. moving onto heatmap next
Top
 Profile
PostPosted: Tue Jan 03, 2017 3:02 pm
Offline
m82g - FlightAware user avatar
Can you explain how you managed to get the range plot?
Top
 Profile
PostPosted: Wed Jan 04, 2017 2:59 pm
Offline
FlightAware Member
Sure, I seem to have problems posting PM's etc and dont want to clutter this thread. PM your email address and I'll send details
Top
 Profile
PostPosted: Fri Jan 06, 2017 6:11 am
Offline
MikeMathee - FlightAware user avatar
Could you post the instructions on a new thread? I'm sure there is going to be a few interested in it, like me.
Top
 Profile
PostPosted: Sat Jan 07, 2017 5:59 am
Offline
FlightAware Member
PeterHR - FlightAware user avatar
... and once done - edit / update post 1 on the thread so it always has the latest detail version.
Top
 Profile
PostPosted: Mon Jan 16, 2017 9:03 pm
Offline
rack201 - FlightAware user avatar
Hi,
I'm just starting out and I"ve been through the thread but its not clear to me if I can get the range rings from heywhatsthat.com setup under windows? I'm usingn an SDRplay with dump1090 and VRS. On Windows I can't see any of the referenced json files to edit/add?
Top
 Profile
PostPosted: Wed Jan 25, 2017 9:45 am
Offline
bergmanmartin - FlightAware user avatar
Hullo,
A question about purging existing predicted-range rings from map:
Apart from the concentric distance rings I have added terrain-limit rings to the dump1090-mutability local gmap, using the coordinates data in the /usr/share/dump1090-mutability/html/upintheair.json file generated at the heywhatsthat.com site. The "problem" is that these rings don't match reality very well. So I figured it would be interesting to try to substitute a custom hand-made json file, based on several weeks statistical experience and actual range maps from PF.
What confuses me now is the fact that I simply can't make the map "forget" the original set of rings. In order to reach a "blank slate" state in regard to this I have deleted the upintheair.json file, and also commented out the whole section in /usr/share/dump1090-mutability/html/script.js that deals with the generation of terrain-limit rings.
Even so, the rings are still drawn on the map! The polylines are are pretty complex, so it is obvious that the coordinates are stored permanently somewhere else between reboots. But where? What can I do to get rid of those existing, irrelevant rings?
Top
 Profile
PostPosted: Wed Jan 25, 2017 10:17 am
Online
FlightAware Staff
obj - FlightAware user avatar
It's probably just cached in your browser, try clearing your browser cache.
Top
 Profile
PostPosted: Wed Jan 25, 2017 10:29 am
Offline
That simple, huh?
Excuse me while I empty my cache... Wait... Yes, indeed!
Thanks!
Top
 Profile
PostPosted: Tue Mar 14, 2017 3:34 pm
Offline
FlightAware Member
k5ted - FlightAware user avatar
Still working on maximum range...
50nm rings
Top
 Profile
PostPosted: Wed Mar 15, 2017 12:49 pm
Offline
FlightAware Member
@k5ted:
Wow, maximum range exceeds 450 nm (extends beyond 9th 50nm ring).
How did you manage to get such a maximum range?
Top
 Profile
PostPosted: Wed Mar 15, 2017 9:43 pm
Offline
FlightAware Member
abcd567 wrote:
@k5ted:
$10 Ground Plane and the 15dB LNA, at 50'-ish. BUT... Seems as if in any direction, the max caps off at 480nm or so. Is that the end-all, maximum radio horizon, or is it artificially created by the VR software?
Top
 Profile
Who is online
Users browsing this forum: BartJr, jcrtp, navzptc, NewPort01, obj and 1 guest
Search for:
Jump to:
