Post new topic Reply to topic  [ 412 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17  Next
Author Message
 Post subject: Re: What is the Maximum Range I can Get?
PostPosted: Sat May 07, 2016 1:09 pm
Offline
FlightAware Member
Radiostationx - FlightAware user avatar
Is there a simple guide to installing this as an add on to JPs script please ?
Tried readme on github but no luck.
Top
 Profile
PostPosted: Sat May 07, 2016 2:31 pm
Offline
GeorgLichtblau - FlightAware user avatar
Quote:
cd ~
git clone -n https://github.com/lignumaqua/dump1090 --depth 1
cd ./dump1090
git checkout HEAD:public_html formatter.js gmap.html planeObject.js script.js style.css maplabel.js config.js
rm -rf ./.git
cp ~/dump1090/* /usr/share/dump1090-mutability/html
This works for me... But you have to insert your Heywhatsthat-File (upintheair.json) manually.
HTH
so long
Georg
P.S.: Thanks to lignumaqua for this enhancement and of course for FSG in GSAK... New abbreviations here.. TFTMacro :)
Top
 Profile
PostPosted: Sun May 08, 2016 11:20 pm
Offline
41south - FlightAware user avatar
Quote:
cd ~
cd ./dump1090
rm -rf ./.git
HTH
so long
Georg
Works perfectly - thanks!
Top
 Profile
PostPosted: Mon May 30, 2016 5:20 pm
Offline
FlightAware Member
Can any one solve this mysterious squint/diplopia and help John?
Range Circle's center is in Cambridge, UK, the correct location of receiver.
Max range for different elevations are centered at Amstardam, Holland !!! :shock:
Please see screenshot in this post:
http://discussions.flightaware.com/post194408.html#p194408
Top
 Profile
PostPosted: Mon May 30, 2016 6:50 pm
Offline
suffolk3000 - FlightAware user avatar
ive read all the thread
i did a full reinstall but alss range squint/diplopia is still showing in netherlands
i added my FIND YOUR MAXIMUM POSSIBLE RANGE
added code it made but nothing changed
http://prntscr.com/bae7pj
john
Top
 Profile
PostPosted: Tue May 31, 2016 11:11 am
Offline
i think i used this info from abcd567
http://forum.flightradar24.com/threads/10232-How-to-Install-dump1090-mutability_1-15-dev-on-RPi
but happy to start over again
running x3 rpi
john
Top
 Profile
PostPosted: Tue May 31, 2016 11:40 am
Offline
FlightAware Member
Hi John!
1) There is nothing wrong with the method of installing "dump1090-mutability v1.15~dev" which I have posted on Flightradar24 forum (http://forum.flightradar24.com/threads/10232-How-to-Install-dump1090-mutability_1-15-dev-on-RPi).
I have tried it on Raspbian Jessie Light and on Piaware latest image. If you have doubts, then please try installing "dump1090-mutability v1.15~dev" using jprochaza's automated scripts.
2) You have posted a link to your screenshot. I will now post your map screenshot to display directly in this post. This makes it easy & quick for others to understand the situation. It is very clear from your screenshot that the center of range rings and terrain limit rings is near Cambridge, UK, which the correct location of receiver. These are the two things installed with dump1090-mutability 1.15~dev. What is off-center is the maximum range curves at different flight levels, which are centered at Amstardam, and this center is determined by configuration settings in lignumaqua's files you have downloaded from github.
Top
 Profile
PostPosted: Tue May 31, 2016 2:39 pm
Offline
Im sure its something simple im doing wrong
have you link to jprochaza's automated scripts.
thanks
john
Top
 Profile
 Post subject:
PostPosted: Tue May 31, 2016 10:03 pm
Offline
https://www.adsbreceiver.net/
Will take you to his image which is really easy to get installed and set up
Sent from my SM-G900F using Tapatalk
Top
 Profile
PostPosted: Thu Jun 02, 2016 6:50 am
Offline
FlightAware Member
idh - FlightAware user avatar
I think that heatmap posted by abcd above comes from here:
ads-b-flight-tracking-f21/heatmap-range-altitude-view-for-dump1090-mutability-v1-15-t35844.html
A version that preceded the one most commonly used now?
Top
 Profile
PostPosted: Tue Jun 07, 2016 5:36 am
Offline
FlightAware Member
sesom - FlightAware user avatar
bonzai24 wrote:
sesom wrote:
Where found i this dump1090 mod with Arrivals,departures Plan Foto.. Please help me
Thanks..
Sorry for the late reply, but I was travelling overseas for quite a while. What is shown in the screenshot is my own version of dump1090. For the aircraft-image a script is necessary that grabs the image from a website. I do not intend to publish that script, as it probably is not legal to spider images from that site. I cache images and deploy them over all 4 of my receivers to reduce traffic. If I would publish that script, the website-owner would not be too happy about the traffic. Sorry, won't get published. The flight-information is something I plan to publish, as the data is available to the public. Right now I do not have the time to set up a proper repository, but I plan to do that in the future.
Klaus
Top
 Profile
PostPosted: Mon Jun 13, 2016 12:30 pm
Offline
Stummel - FlightAware user avatar
dumb question but what file has to be modified to see the traffic on the ppp0 interface? (umts stick..)
https://abload.de/img/ipyrjie.jpg
i can only choose between eth0 and wlan0 with the stock setup...
thanks
Top
 Profile
PostPosted: Sun Jul 10, 2016 8:28 am
Offline
FlightAware Member
mgunther - FlightAware user avatar
@lignumaqua: I updated dump1090-mutability today but now your script does not work anymore. The problem seems to be here in script.js:
Code:
for (var type in ExtraMapTypes) {
      mapTypeIds.push(type);
The ExtraMapTypes variable is not defined. Would you be able to look into that?
Top
 Profile
PostPosted: Sun Jul 10, 2016 8:48 am
Online
FlightAware Staff
obj - FlightAware user avatar
The map code in dump1090-mutability looks completely different now and it's unlikely that existing modifications will work unchanged. You'll need to port them to OpenLayers.
Top
 Profile
PostPosted: Mon Jul 11, 2016 8:13 am
Offline
FlightAware Member
lignumaqua - FlightAware user avatar
Yes, this will take a chunk of work to move over. :roll: It's not obj's fault, it's Google's. I've had the same issues with the maps I do for GSAK and geocaching. Google's change in policy is frustrating. At least they've now re-allowed locally hosted maps to work without a key, for a day or so they cut those off as well! However, even those might disappear after the grandfathering period runs out in October.
I'e been migrating to Leaflet rather than OpenLayers so it's yet another API to digest. On the to-do' list... :D
Top
 Profile
PostPosted: Mon Jul 11, 2016 8:57 am
Offline
FlightAware Member
jonhawkes2030 - FlightAware user avatar
I hated OpenLayers at first. I only have it on one RPI.
I am now getting use to it. I even enabled it on another RPI that still has google working.
Top
 Profile
PostPosted: Mon Jul 11, 2016 9:23 am
Online
FlightAware Staff
On the plus side the new map probably works in China ;-)
The only internet-access-required dependency left now is the tiles themselves, so you could probably set up a layer that used an offline cache without too much pain if you wanted fully disconnected operation.
Top
 Profile
PostPosted: Mon Jul 11, 2016 9:44 am
Offline
FlightAware Member
Thank you! In the meantime, I have been able to revert to an earlier version of dump1090-mutability that still uses Google maps and I have inserted an API key as advised in another thread. So that is working OK for me now.
Top
 Profile
PostPosted: Tue Jul 12, 2016 10:13 pm
Offline
FlightAware Member
ExCalbr - FlightAware user avatar
lignumaqua wrote:
I'm not sure if the dead area south west of San Antonio is because I can't see it, or because it's just not an area where flights normally track.
I'd say it's because you can't see there. I don't have the fancy scripts and add-ons in this thread, but here's what I see from Wooten (between Burnet Rd and 183 north of Anderson Lane).
First image is using my ground plane antenna in the attic.
Second image is from the 26" FA antenna about 12' above the roof.
Graphed by Planeplotter so does not include MLAT planes with my current setup. I noticed that today there is a small segment south of Louisiana that is about 400 miles away from my location.
Top
 Profile
PostPosted: Fri Jul 15, 2016 2:58 am
Offline
yeu2 - FlightAware user avatar
With my setup I get around 300 miles with peaks at 320. The antenna is located on the roof of my building that is 10 stories high. Antenna is a 12 segment coco, cable run is around 12m(rg6) and the receiver setup is a pi3 + ads-b bandpass filter + usb pro stick. The screenshot is taken from modesmixer2.
Top
 Profile
PostPosted: Fri Jul 15, 2016 12:24 pm
Offline
FlightAware Member
I am using dump1090-mutability v1.15~dev, on my two RPi + one OPi. These were installed before the current change by google followed by change in dump1090-mutability by obj. It is working just like before, showing Google map. I will now copy these .deb files built during install process to my desktop, so that I can use it in case any of the 3 Pis crash & I have to format microSD card and reinstall all.
Top
 Profile
PostPosted: Wed Aug 10, 2016 2:38 am
Offline
Pasajero311 - FlightAware user avatar
Hello
You could add the signal level with which the aircraft altitude like to appear on each plane in dump1090-mutability in the version of (lignumaqua) is received
Thank you
Top
 Profile
PostPosted: Thu Aug 11, 2016 8:46 am
Offline
ZMS - FlightAware user avatar
good day together,
i am running into a prob after installing dump-mutability over https://gist.github.com/jprochazka/01bb70930c754f86f0c8
cached the files from lignumaqua and finally made the changes in config.js ...
... however, the screen stays in "loading modus".
it is not a problem of a refresh or restart of web-server. here the error message from browser:
Uncaught ReferenceError: ExtraMapTypes is not defined
    initialize_map @ script.js:446
    (anonymous function) @ script.js:275
    c @ jquery.min.js:3
    fireWith @ jquery.min.js:3
    k @ jquery.min.js:5
    r @ jquery.min.js:5
all refering to script.js
many thanks for any advice
Top
 Profile
PostPosted: Thu Aug 11, 2016 9:14 am
Offline
team ...
sorry, sorry - might be i was to quick. i downloaded some more files from lignumaqua : https://github.com/lignumaqua/dump1090:
    public_html formatter.js gmap.html planeObject.js script.js style.css maplabel.js dbloader.js markers.js config.js
adaped these to my config and now it looks good ...
Top
 Profile
PostPosted: Fri Aug 19, 2016 1:18 pm
Offline
hixter - FlightAware user avatar
Without reading through all 15 pages of posts (although I will probably do so at some point) is it safe to assume that these snazzy new features won't work with a new PiAware 3 installation that uses the OpenStreetMap data instead of Google Maps?
I replaced my old B+ with a new Pi 3 and swapped out my old RTLSDR dongle for a shiny new FA device and 1090 MHz filter and I'm seeing about twice as many aircraft as before and at much greater distances. I'm constrained by hills to the east and west, but this has extended my range greatly.
Top
 Profile
Who is online
Users browsing this forum: BartJr, Google [Bot], jcrtp, navzptc, NewPort01, obj and 1 guest
Search for:
Jump to:
