Post new topic Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 18  Next
Author Message
 Post subject: Re: What is the Maximum Range I can Get?
PostPosted: Fri Feb 05, 2016 8:29 pm
Offline
FlightAware Member
jonhawkes2030 - FlightAware user avatar
MikeIsler wrote:
Any thoughts on how to add "Bearing from site" to "Distance from Site" for a specific aircraft? a Bearing/Distance readout would be pretty useful, but I don't have the chops to create that.
Distance is given on the mutability version of dump1090.
Top
 Profile
PostPosted: Fri Feb 05, 2016 9:30 pm
Offline
MikeIsler - FlightAware user avatar
Yes, running Mutability...I have distance, but don't have Bearing. I'm looking for "Plane is 240° @ 52NM from site" information. Mutability is halfway there, and I have the Position info as well in Lat/Long, but would love if Plane Lat/Long vs Site Location Lat/Long was calculated into a Bearing.
Top
 Profile
PostPosted: Fri Feb 05, 2016 10:06 pm
Offline
FlightAware Member
usafpride - FlightAware user avatar
lignumaqua wrote:
Some updates now on Github at https://github.com/lignumaqua/dump1090 :
1. Added toggle for heywhatsthat predicted range polygons
2. Added option to produce any number of range polygons at any
specified altitudes. New config.js option to set range altitudes and
colors for polygons.
You need to make the additions to config.js manually, do NOT pull the version on Github or you will overwrite your personal settings. Add the following to the end of the file:
I chose to overwrite the files from the Github and the dump1090 page won't load. The loading bar goes all the way to the right and just spins. Thoughts?
Upon further testing, just copying the new script.js to the existing directory breaks it.
Top
 Profile
PostPosted: Fri Feb 05, 2016 10:43 pm
Offline
FlightAware Member
That is simple trig. I am sure it has already been written. It just needs to be added to the display.
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:49 am
Offline
FlightAware Member
lignumaqua - FlightAware user avatar
You can't do that, the files are dependent on each other and must be used as a set, you can't mix and match. Pull all the files in the html folder over except for config.js. For config.js you need to add the extra lines to your existing file.
If you still have problems open the JavaScript console or debugger in your browser and let us know what the error message(s) are.
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:52 am
Offline
FlightAware Member
The bearing data exists, where do you want to see it? As another column in the table, or in the data block for the selected aircraft?
Top
 Profile
PostPosted: Sat Feb 06, 2016 5:55 am
Offline
FlightAware Member
mgunther - FlightAware user avatar
You must enter the additional lines at the end of the config.js file. These declare new variables that the updated script.js relies on. If the variables are not set, then the new script.js won't work and you'll see the never-ending spinner.
Top
 Profile
PostPosted: Sat Feb 06, 2016 10:29 am
Offline
Wanted to use it in the data block for a selected aircraft, so instead of just "Distance from Site", it will read "Bearing/Distance from Site" for that aircraft.
Top
 Profile
PostPosted: Sat Feb 06, 2016 11:27 am
Offline
FlightAware Member
the problem lied within script.js both
Code:
RangeAltitude
UseMlatDataForRange
was undefined. Fixed by adding below to script.js
Code:
var RangeAltitude = [];
var UseMlatDataForRange = [];
Although, Toggle Range doesn't do anything. The only error currently showing is
Code:
"Google Maps API warning: SensorNotRequired https://developers.google.com/maps/documentation/javascript/error-messages#sensor-not-required"
Top
 Profile
PostPosted: Sat Feb 06, 2016 11:53 am
Offline
FlightAware Member
Code:
RangeAltitude
UseMlatDataForRange
Code:
@usafpride - you just keep installing a very small part of the needed changes. This is exactly what you will get if you ignore the above advice from both me and mgunther to update your config.js. :o : The edits you suggest to to the new script.js are NOT needed and will instead break the Range system.
Can I suggest you do the following to start again:
1. Save your current config.js file to a different location.
2. Copy *everything* (including sub-folders) that is in the public_html folder on https://github.com/lignumaqua/dump1090 over your current public_html folder
3. Edit your curent, saved, config.js, by adding the following lines at the end.
Code:
// Grid size for heatmap. Range in miles from Site. Default 200.
HeatMapRange = 200;
// Set Altitudes and Colors for Range Rings
// RangeAltitude is an array of altitudes in feet
// Use 99999 for range at any altitude
// RangeColor is a corresponding array containing the color values of the rings
RangeAltitude  = new Array(99999,30000,10000);
RangeColor     = new Array('#008000','#000080','#800000');
// Allow use of MLAT data for the range poly
UseMlatDataForRange = true;
4. Put your edited config.js back in the public_html folder
Top
 Profile
PostPosted: Sat Feb 06, 2016 11:54 am
Offline
FlightAware Member
Cool, I'll add that. :D
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:01 pm
Offline
FlightAware Member
Code:
HeatMapRange = 200;
I did follow your advice and I copied everything over from GitHub brand new. Completely new install. config.js contains those lines already. Maybe I'm not getting the most recent copy from GitHub, but I simply did a
Code:
sudo cp -rf ~/dump1090/public_html/* /usr/share/dump1090-mutability/html/
I'll give it another try.
<edit> Still no joy. Clean install results in these errors with FF 44.0
Code:
Using //@ to indicate sourceMappingURL pragmas is deprecated. Use //# instead jquery.min.js:1:0
unreachable code after return statement script.js:1142:8
ReferenceError: RangeAltitude is not defined
script.js:22:17
39.93922141570338 45.72077858429662 -89.4288833207844 -81.55111667921557 script.js:621:9
InvalidValueError: not an Array <unknown>
"Google Maps API warning: SensorNotRequired https://developers.google.com/maps/documentation/javascript/error-messages#sensor-not-required" util.js:23:322
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:09 pm
Offline
FlightAware Member
@usafpride:
I have a update_lignumaqua.sh file with the following in my home directory:
Code:
rm -rf dump1090/
git clone -n https://github.com/lignumaqua/dump1090 --depth 1
cd ./dump1090
git checkout HEAD:public_html formatter.js gmap.html planeObject.js script.js style.css maplabel.js
rm -rf ./.git
sudo cp ./*.* /usr/share/dump1090-mutability/html/
It copies and updates all required files. But you still need to manually add some lines to config.js.
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:19 pm
Offline
FlightAware Member
mgunther wrote:
@usafpride:
Code:
rm -rf dump1090/
cd ./dump1090
rm -rf ./.git
I removed everything from
Code:
, ran your update script. The page now loads, but with no planes showing. Error is as follows
Code:
Starting to load history (120 items) script.js:283:17
Loading history #0 script.js:296:9
GET XHR http://192.168.1.107:20800/dump1090/upintheair.json [HTTP/1.1 404 Not Found 26ms]
Loading history #1
<snip>
Done loading history script.js:318:9
Sorting history script.js:324:17
Applying history 0/120 at: 1454775386.7 script.js:330:25
TypeError: PolyRange[j] is undefined planeObject.js:349:1
upintheair.json makes sense not being there as it isn't in the repo to copy over.
These lines are in config.sys
Code:
HeatMapRange = 200;
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:25 pm
Offline
FlightAware Member
mgunther shows the right way to do this, much better than my instructions! :)
If you've copied over config.js then you will need to go into that and re-enter your site coordinates and any other changes you had made previously.
PS - Also make sure you do a 'hard' reload in FF (Ctrl-F5) to ensure that cached copies of the old files are discarded
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:29 pm
Offline
FlightAware Member
This is a very strange error:
Code:
Do you know where those lines are coming form? They aren't in the script.js file. can you see them in config.js or any of the files?
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:31 pm
Offline
FlightAware Member
Done and Done. No planes show. I fired up IE11 and it loads fine, so it is a FF issue
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:34 pm
Offline
FlightAware Member
Code:
it is coming from this block of code in script.js (in particular, the console.log is the line)
Code:
if (SitePosition) {
        maxlat = google.maps.geometry.spherical.computeOffset(SitePosition, HeatMapRange * 1609,0).lat();
        minlat = google.maps.geometry.spherical.computeOffset(SitePosition, HeatMapRange * 1609,180).lat();
        maxlon = google.maps.geometry.spherical.computeOffset(SitePosition, HeatMapRange * 1609,90).lng();
        minlon = google.maps.geometry.spherical.computeOffset(SitePosition, HeatMapRange * 1609,270).lng();
        console.log(minlat, maxlat, minlon, maxlon);
        latstep = (maxlat - minlat)/(HeatMapRange *2);
        lonstep = (maxlon - minlon)/(HeatMapRange *2);
        HeatMapValid = true;
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:35 pm
Offline
FlightAware Member
Ah - thanks! I test in Safari, IE, Chrome, and Opera. Haven't used Firefox in many years... Looks like I need to install it and address its quirks. Sorry you had these problems.
(I'm used to javscript consoles that separate errors from console logs, thanks also for solving that mystery.)
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:42 pm
Offline
FlightAware Member
No worries. Some days I'm not the sharpest knife in the drawer, but today seems to be a good day :)
<edit>
Interesting note, "Select Closest" will display that plane on the map.
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:49 pm
Offline
FlightAware Member
Hmmm, there must be something more to this. I just tested in Firefox V35, V43.01, and V44. Worked fine in all of them. :|
What version of FF are you running and on which OS?
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:51 pm
Offline
FlightAware Member
FF 44.0, Windows 7 Home Premium SP1
Check my edit in the post above.
Top
 Profile
PostPosted: Sat Feb 06, 2016 12:56 pm
Offline
FlightAware Member
because I'm fairly github ignorant, how would I pull the last version down?
Also confirmed Chrome works.
Top
 Profile
PostPosted: Sat Feb 06, 2016 1:10 pm
Offline
FlightAware Member
I still can't make it fail in FF 44. Can you try clearing the cache/recent history in FF and see if that makes any difference? If I recall, FF is very tenacious about hanging on to old versions of files.
Top
 Profile
PostPosted: Sat Feb 06, 2016 1:19 pm
Offline
FlightAware Member
That was it. I flushed everything hard and it now shows up. Thanks for sticking with this!!
Top
 Profile
Who is online
Users browsing this forum: invergordon and 1 guest
Search for:
Jump to:
