Post new topic Reply to topic  [ 429 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9 ... 18  Next
Author Message
 Post subject: Re: What is the Maximum Range I can Get?
PostPosted: Thu Jan 21, 2016 7:13 pm
Offline
FlightAware Member
dschaper - FlightAware user avatar
TomMuc wrote:
if you did go for the antenna i mentioned you'll see a good improvement in reach.
Where did you get your Yagi-Uda? I'm thinking about adding one to pick up KSNA to the south of me, I can't quite get to the ground with my current ebaySpider and I'm thinking adding a Yagi might give me a little more to pick up the traffic there...
Top
 Profile
PostPosted: Thu Jan 21, 2016 7:19 pm
Offline
FlightAware Member
TomMuc - FlightAware user avatar
this is the one i've tested: http://www.amateur-radio-antenna.com/ism-aeronautical-antenna/secondary-radar-1090/antenna-secondary-radar-flu-sr-y13.php. they have the same in a heavy duty version - but costs more than twice as much: http://www.amateur-radio-antenna.com/ism-aeronautical-antenna/secondary-radar-1090/antenna-secondary-radar-flu-sr-y13-prof.php
edit: funny - actually i'm thinking about sending mine to la too with a view to lax. other option is to buy the flightaware from amazon.com. not sure at the moment what my decision will be ...
Top
 Profile
PostPosted: Thu Jan 21, 2016 7:36 pm
Offline
FlightAware Member
My sister lives in Burbank and has a good view of the regional out there, trying to figure out how to get an install at her place without getting the HOA involved...
Top
 Profile
PostPosted: Thu Jan 21, 2016 7:42 pm
Offline
FlightAware Member
in my findings especially the yagi can sit in a housing made of (thin) wood or plastic - without real loss in range ...
Top
 Profile
PostPosted: Thu Jan 21, 2016 8:02 pm
Offline
FlightAware Member
jonhawkes2030 - FlightAware user avatar
Probably not applicable it this case, however, I saw a recent post regarding HOAs and their antenna rules.
One HAM hid his antenna in a 3-4" diameter pvc pipe that was made to look like a vent pipe.
I thought it was a clever idea.
Not much help for a yagi. It could work for the FA antenna(mine arrived today).
Top
 Profile
PostPosted: Thu Jan 21, 2016 8:11 pm
Offline
FlightAware Member
sjacket99 - FlightAware user avatar
This is how you get around a HOA.. LOL
Top
 Profile
PostPosted: Thu Jan 21, 2016 8:29 pm
Offline
FlightAware Member
Thanks for the pointers. I'll make sure there is power up there on the roof, it's a 3 storey townhouse.
Top
 Profile
PostPosted: Thu Jan 21, 2016 9:43 pm
Offline
FlightAware Member
wnypoker - FlightAware user avatar
Fun to watch the planes in fast forward. May have to find a way to automate time lapse recording on a regular basis.
http://vid300.photobucket.com/albums/nn30/adsbjunkmail/output_1_zpshds16wqk.mp4
Top
 Profile
PostPosted: Fri Jan 22, 2016 6:41 pm
Offline
FlightAware Member
lignumaqua - FlightAware user avatar
A storm front came through yesterday and I noticed that flights were being put in a holding stack waiting to get into IAH. It occurred to me that a weather overlay might be fun to add to the map so you could see when the weather passed.
This was relatively easy to do for the US as map tile servers are available for weather radar. Not so easy for Europe (or the rest of the world) as such servers don’t seem as easy to find. For now I've just added US and Europe, where Europe uses a single map image overlay updated every 15 minutes. The US maps update every minute.
Here's the US (there's no weather in Texas today so I'm showing the East Coast storm)
And the current EU:
As before there is a toggle to turn on/off the weather layer.
I've also fixed some bugs I had in the use of local storage to store the state of the Toggle settings. They should all now be 'sticky' in that the map should open with the same options you left it with when closed.
All updates in https://github.com/lignumaqua/dump1090 (Just gmap.html, script.js and style.css have been amended)
Top
 Profile
PostPosted: Fri Jan 22, 2016 8:33 pm
Offline
FlightAware Member
tjowen - FlightAware user avatar
Once again, works perfectly, thank you.
Top
 Profile
 Post subject: What is the Maximum Range I can Get?
PostPosted: Fri Jan 22, 2016 8:39 pm
Offline
FlightAware Member
usafpride - FlightAware user avatar
I like the "lightning rod" protecting the flag pole!!
Top
 Profile
PostPosted: Sat Jan 23, 2016 12:22 pm
Offline
FlightAware Member
phillx19090 - FlightAware user avatar
The weather map update failed for me. Just the gmap spinner and loading bar.
Phill
Top
 Profile
PostPosted: Sat Jan 23, 2016 12:39 pm
Offline
FlightAware Member
Phill
Try a hard browser refresh (Ctrl-F5).
Top
 Profile
PostPosted: Sat Jan 23, 2016 12:52 pm
Offline
FlightAware Member
I learnt my lesson last time. :wink: :wink: :wink:
Hard refresh makes no difference.
Phill
Top
 Profile
PostPosted: Sat Jan 23, 2016 5:07 pm
Offline
FlightAware Member
Phill
OK, things to check.
1. Reboot your browser and computer.
2. Try a different browser. Which one are you using?
3. You may have got out of sync. Redownload the following files from Github to your html folder:
script.js
style.css
gmap.html
planeObject.js
maplabel.js
formatter.js
4. If all that fails, please open the javascript / debugging console in your browser and let me know of any error messages you see.
Top
 Profile
PostPosted: Sat Jan 23, 2016 7:41 pm
Offline
FlightAware Member
Phill
I kind of had the same issue. So I did the following and it seem to fix it.
Code:
sudo service lighttpd restart
After that I was able to see the new update with the weather on the Dump1090 map. Using Safari. But I can not get it to work now on Google chrome, I.E and the new Windows 10 browser and Firefox. HMMM.. :shock:
Top
 Profile
PostPosted: Sat Jan 23, 2016 7:44 pm
Offline
FlightAware Member
sjacket99 wrote:
Thanks, I also use Safari. Let me test with the others and fix.
Edit: Yes, I agree, something is broken in all browsers apart from Safari! :shock: Mea culpa. Stand by...
Top
 Profile
PostPosted: Sat Jan 23, 2016 9:04 pm
Offline
FlightAware Member
Should now be fixed. Stupid mistake... :?
Only file changed is script.js, pull that down and do a hard reset of the browser.
Tested in Safari, Chrome, Opera, and Edge.
Top
 Profile
PostPosted: Sat Jan 23, 2016 10:29 pm
Offline
FlightAware Member
Frazpo - FlightAware user avatar
Been out a while and return find a lot of new addons!
Thanks Lignumaqua for your addons and for sharing your work.
I have wanted weather radar for a long time!
Top
 Profile
PostPosted: Sun Jan 24, 2016 3:31 am
Offline
FlightAware Member
Lignumaqua, you are the man!
Works perfectly apart from lack of weather!
Another sunny January day in Spain!
Many thanks,
Phill
Top
 Profile
PostPosted: Sun Jan 24, 2016 1:12 pm
Offline
FlightAware Member
Many thanks,
Phill
I see what appears to be two range plots. I only have a green one on the addons I loaded. Did I miss something??
Top
 Profile
PostPosted: Sun Jan 24, 2016 1:27 pm
Offline
FlightAware Member
Those are terrain limited range predictions provided by the API on heywhatsthat.com. Oliver added support for those. Here's the instructions:
Quote:
// Add terrain-limit rings. To enable this:
// create a panorama for your receiver location on heywhatsthat.com
// note the "view" value from the URL at the top of the panorama
// i.e. the XXXX in http://www.heywhatsthat.com/?view=XXXX
// fetch a json file from the API for the altitudes you want to see:
// wget -O /usr/share/dump1090-mutability/html/upintheair.json \
// 'http://www.heywhatsthat.com/api/upintheair.json?id=XXXX&refracti$
// NB: altitudes are in _meters_, you can specify a list of altitudes
You can have as many as you like at different altitudes.
I have one set at 40,000 ft (blue) and one at 10,000 ft (red) . The 40,000 somewhat corresponds with the actual (green). Interesting that I don't seem to get as far over the gulf as predicted. That could just be lack of high level flights pushing out the actual polygon.
Top
 Profile
PostPosted: Sun Jan 24, 2016 1:31 pm
Offline
FlightAware Member
mgunther - FlightAware user avatar
These are heywhatsthat theoretical range lines that dump1090-mutability can add semi-automatically. Probably the easiest way is to run the automatic setup scripts: http://discussions.flightaware.com/ads-b-flight-tracking-f21/ads-b-feeder-project-setup-scripts-t36532.html
Top
 Profile
PostPosted: Sun Jan 24, 2016 1:37 pm
Offline
FlightAware Member
The manual command to get the json file looks like this:
Code:
sudo wget -O /usr/share/dump1090-mutability/html/upintheair.json "http://www.heywhatsthat.com/api/upintheair.json?id=xxxxxxxx&refraction=0.25&alts=9144,12192"
The above is for 30000 and 40000 foot but you can change the 'alts' parameter to suit your requirements.
Top
 Profile
PostPosted: Sun Jan 24, 2016 4:56 pm
Offline
FlightAware Member
Thanks for the replies. Got it going. Goes to prove if you leave the forum for a bit you get behind pretty quick!
Thanks again.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
