Post new topic Reply to topic  [ 13 posts ]
Author Message
 Post subject: unable to configure dump1090-fa config.js
PostPosted: Tue Mar 14, 2017 10:13 am
Offline
anandks - FlightAware user avatar
I am running dump1090-fa v3.3.0 and piaware 3.1.0, I am unable to get any changes to my configuration when I change /usr/share/dump1090-fa/html/config.js
for example, I want to enable chartbundle, clock and add more circles.
changed, all the settings appropriately. But, no change at all.
anyone else have similar issues ? or any pointers please.
Top
 Profile
 Post subject: Re: unable to configure dump1090-fa config.js
PostPosted: Tue Mar 14, 2017 10:56 am
Offline
FlightAware Member
jonhawkes2030 - FlightAware user avatar
restart lightttpd for the changes to take effect.
You can re-boot the whole device if it is easier.
You may also need to refresh your browser.
Top
 Profile
PostPosted: Tue Mar 14, 2017 11:11 am
Offline
Did All of those mentioned, I even confirmed by chmod 000 index.html to see if I get a 404 and I do, So. I know that the file in /usr/share/dump1090-fa/html/index.html is the one that the lightttpd is sourcing and not from somewhere else.
Just doesn't honor the settings in config.js.
Top
 Profile
PostPosted: Thu Mar 16, 2017 11:44 am
Offline
made a fresh install of rPI, PIaware and dump1090.
Still I can't seem to reflect the changes I make in /usr/share/dump1090-fa/html/config.js or script.js
I tried the alternating red/blue circles - no effect.
yes, I have restarted the services, restarted pi. no effect.
I am now running 3.3.0 on both piaware and dump1090
Top
 Profile
PostPosted: Thu Mar 16, 2017 11:53 am
Offline
FlightAware Staff
obj - FlightAware user avatar
Fetch the config file by hand (e.g. using wget or curl) and check you get what you're expecting.
If you don't get what you're expecting, there is a problem on the Pi side.
If you do get what you're expecting, there is a problem on the browser side.
Top
 Profile
PostPosted: Thu Mar 16, 2017 12:31 pm
Offline
NeoDuder - FlightAware user avatar
Chrome/Settings/Advanced/Clear Browsing Data/Check Cached Images and Files/Clear Browsing Data/Refresh the page.
Top
 Profile
PostPosted: Sat Mar 18, 2017 1:47 pm
Offline
Thanks, that was it. Feel like an idiot, barking at the wrong tree.
Top
 Profile
PostPosted: Sun Mar 19, 2017 7:53 am
Offline
Aye, it's a PITA. I manually add any aircraft to the database whenever I spot one without full details and I have to go through this little process everytime :(
Top
 Profile
PostPosted: Sun Mar 19, 2017 12:00 pm
Offline
went ahead and modified the index.html with meta tags to stop the browser from caching, I know this does not work with all browsers, but I Am happy that it works with chrome and I do see changes reflected when I refresh without clearing cache.
right after the meta tag below, add the ones in red.
<meta charset="utf-8"/>
<meta http-equiv="cache-control" content="max-age=0" />
<meta http-equiv="cache-control" content="no-cache" />
<meta http-equiv="expires" content="0" />
<meta http-equiv="expires" content="Tue, 01 Jan 1980 1:00:00 GMT" />
<meta http-equiv="pragma" content="no-cache" />
Top
 Profile
PostPosted: Mon Mar 20, 2017 2:43 pm
Offline
HuffTheWeevil - FlightAware user avatar
For me, the PITA is adding the data. So I modified the csv-to-json.py script in the tools to take csv data and amend the database, instead of replacing the entire database (which is how the default script works). I can't access it right now, but when I get home I'll share the script.
As for a slightly faster way to clear the cache, click the three dots in the top right of Chrome, goto More tools, then Clear browsing data... That gets you to the dialog box quicker.
Top
 Profile
PostPosted: Mon Mar 20, 2017 2:53 pm
Offline
An alternative to that is to modify dbloader.js. Near the bottom you will see two different (but nearly identical) AJAX requests that include a "cache: true" parameter. Change both of these to "false" and you're in business.
Note that disabling the cache for the database (with either method) does slow things down a bit, particular when the page is first loaded, and anytime an aircraft is picked up that is not already on the map.
Top
 Profile
PostPosted: Tue Mar 21, 2017 1:41 pm
Offline
I don't mind manually editing the database tbh. It's only very occasionally that I spot an unknown aircraft and I have WinSCP open permanently so that I can quickly Google the code and then edit the DB.
Top
 Profile
PostPosted: Tue Mar 21, 2017 2:15 pm
Offline
mictronics - FlightAware user avatar
https://raspberrypi.nerdcamp.net/aircraftdb/export.php
Top
 Profile
Who is online
Users browsing this forum: homestea and 1 guest
Search for:
Jump to:
