Post new topic Reply to topic  [ 194 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
Author Message
 Post subject: Re: Three Easy DIY Antennas for Beginners
PostPosted: Sun Nov 06, 2016 8:37 am
Offline
FlightAware Member
jcinnb - FlightAware user avatar
You may well find the "store bought" antenna does not perform much better than spider. You did a good, neat job on the spider.
Top
 Profile
PostPosted: Mon Nov 07, 2016 3:28 am
Offline
FlightAware Member
Thanks for measuring and plotting the VSWR vs Frequency sweep.
I always wanted to have a spectrum Analyzer/Signal Generator/VNA and other necessary equipment to test the antennas, but these are too costly.
brianroyal wrote:
abcd567 wrote:
EASY ANTENNA #2 : CANTENNA
Completed Cantenna
Designed & Built by Author of this post (abcd567)
The best part about this antenna is it's deafness to frequencies that are out of band for ADSB. It's easy to make so that it's got a good SWR (about 1.5) at 1090 band and it all but completely attenuates anything below about 900. MUCH easier to build right than a Colinear Coaxial with better bandpass characteristics.
This helps to keep the receiver from dropping it's AGC when it gets bombarded with extraneous noise.
EDIT: Can't recommend this design enough for a simple and reliable antenna that you WILL probably make correctly on the first try. If you're trying for maximum gain - Yeah, build a COCO. Just be prepared for a "learning experience" or two.
Build one of these FIRST so you have a decent antenna to fall back on while you troubleshoot your quad or eight element coco.
Top
 Profile
PostPosted: Sat Nov 12, 2016 12:50 pm
Offline
FlightAware Member
I came across a very EZ, accurate and SAFE way to cut the can for a cantenna.
Cut a small piece of wood the height desired.
Place a razor knife across the top of the wood
Grasp the can by the top, away from knife and hold agains the knife blade
Turn can until it first is scored, then cut.
Very crude drawing:
Top
 Profile
PostPosted: Fri Nov 18, 2016 10:40 pm
Offline
FlightAware Member
zeek70706 - FlightAware user avatar
Very crude drawing:
I just used a pair of scissors.
Top
 Profile
PostPosted: Wed Nov 30, 2016 4:21 pm
Offline
biekerc - FlightAware user avatar
I am wondering where to position my antenna in the attic.
I just moved it there from a windows facing westwards, it now it sits in the middle of the attic, ca 1,50 from the top of the roof, pretty much in the center of the whole building, which is rectangular. The reason for this is that on either side is a relatively small windows. This way, I thought, it can "look out" of both of the windows.
Now get a lot more positions and planes from the East, but I am wondering if it might make more sense to
a) put it as close as possible to the top of the roof, even if that means that there is no line of sight out of the windows
b) put it away from the windows, closer to the gable, so it is close to the outer walls/roof on three sides?
I could try this out and maybe I will, but I also would like to have a better theoretical understanding why one of the locations is better than the other.
Any ideas?
Top
 Profile
PostPosted: Wed Nov 30, 2016 8:09 pm
Offline
RickBoatright - FlightAware user avatar
Open the window. use a hot-glue-gun, or a clamp, or whatever to position it OUTSIDE the window.
Then, get a hunk of foam rubber, and close the window on that to keep the rain out, etc. (this is assuming you're unwilling or unable to drill a hole in the window frame...)
Then, if you want to get REALLY fancy, get another pi, and another rtl-sdr, and put another antenna on the outside of the window on the OTHER side of the house... :-) I know, I know, shear insanity.
Any ideas?
Top
 Profile
PostPosted: Thu Dec 01, 2016 12:14 pm
Offline
FlightAware Member
Any ideas?
You will get lot of ideas about indoor installations from this thread:
Post your PiAware setup
Selected posts from above thread, pertaining to "installation in attic":
1) post182995.html#p182995
2) post183692.html#p183692
3) post197639.html#p197639
4) post197656.html#p197656
Top
 Profile
PostPosted: Thu Dec 01, 2016 2:09 pm
Offline
brianroyal - FlightAware user avatar
Ok, so after two weeks of testing with both the pro-stick with filter and without and the pro-stick plus, I can conclude that, with gain settings at auto, the cantenna does not appear to need a filter, at least not in my relatively rural area.
Top
 Profile
PostPosted: Fri Dec 02, 2016 5:17 pm
Offline
Thanks for the suggestions, it seems people are opting to mounting the antenna as high as possible and as close to walls.
My assumption was that the signal travels more easily through glas than wood and clay, so a position closer to a window is better.
However, being closer to the windows to the east increases the distance to the window and roof to the west, so fewer signals are picked up from this direction.
I'll try to move closer to the top, closer to the walls, but at a greater distance to the windows that are basically on the same level as the floor and see what happens.
Outside is no option at the moment, I haven't got the right antenna for that. Several Pi would be, a have a small collection of them...
Top
 Profile
PostPosted: Sun Dec 04, 2016 8:53 am
Offline
So I did some quick and dirty tests.
I achieved by far the best results in terms of number of planes by putting the antennal as high up and close as possible to the outside walls.
Top
 Profile
PostPosted: Mon Dec 05, 2016 4:17 am
Offline
myalias - FlightAware user avatar
Glass attenuates the 1090 MHz signal. Wood blocks it less.
Top
 Profile
PostPosted: Mon Dec 05, 2016 10:25 am
Offline
FlightAware Member
For details of attenuation, please see this post:
RF Signal Loss in Penetrating a Building
Top
 Profile
PostPosted: Mon Dec 05, 2016 3:40 pm
Offline
In my case the roof is made of clay tiles and some insulation, (and the walls are solid red brick masonry).
In this case, I guess being close to a single glazed window is still an advantage, but only for the reception in this direction, and a disadavante for the reception in all other.
Being close to the top reduces the distance to the tow sides of the roof, which should also reduce the signal loss. In sum, this seems to be the best option.
It is like a triangle, if you move to the left or right hand corner, you increase the distance to the other side, only if you move upwards to the top, the distance to the left and right are reduced.
Top
 Profile
PostPosted: Tue Dec 06, 2016 11:21 pm
Offline
Thank you for the heads-up on that thread. I hadn't come across it yet. No doubt it will come in useful!
Top
 Profile
PostPosted: Sat Dec 10, 2016 7:28 pm
Offline
FlightAware Member
aldoir - FlightAware user avatar
Folks,
After a couple of weeks running this antenna I would like to see how it performs for you too.
I started this thread http://discussions.flightaware.com/ads-b-flight-tracking-f21/disappointing-results-with-my-setup-what-s-wrong-t38177.html after some unsucessful atemps with the Coaxial Collinear and after some research found the antenna I would like to share here.
I's a J-Pole Collinear, an easy to build and tune antenna.
Here is its diagram and 1090Mhz lengths
Wire: 16 AWG copper (enameled if available)
Coils: 16 turns of 5mm inner diameter 53mm long
(you can build with 2 to 4 elements (1 to 3 coils)
The feed line should be connected at 6mm from the bottom (shield to the short element, as per this image).
If anyone is interested in building it please let me know and I'll update the needed details.
EDIT: Updated dimensions to reflect new tests.
Top
 Profile
PostPosted: Sun Dec 11, 2016 7:39 pm
Offline
FlightAware Member
k6rtm - FlightAware user avatar
what size wire did you use for this?
--bob k6rtm
Top
 Profile
PostPosted: Sun Dec 11, 2016 8:44 pm
Offline
FlightAware Member
Ops, sorry, 16AWG enamelled copper
Top
 Profile
PostPosted: Mon Dec 12, 2016 7:15 am
Offline
FlightAware Member
triggers - FlightAware user avatar
@aldoir
Just about to make your antenna.
I have a question for the experts. I have the orange Pro-stick on my test system which is currently connected to a 6 element CoCo. The J pole is a "shorted" antenna. Do I need a DC blocker to make sure the amp in the Pro-stick doesn't fry?
Top
 Profile
PostPosted: Mon Dec 12, 2016 9:03 am
Offline
FlightAware Member
You dont need dc blocking for the ProStick. It's only needed for tee bias sat amplifiers
I've tested both, currently I'm using a 20dB amp with a std rtlsdr stick
Top
 Profile
PostPosted: Mon Dec 12, 2016 9:30 am
Offline
FlightAware Member
Thanks, the antenna is on test.
I only had 1mm wire so built it to your dimensions.
Top
 Profile
PostPosted: Mon Dec 12, 2016 9:56 am
Offline
FlightAware Member
How many elements did you make?
Top
 Profile
PostPosted: Mon Dec 12, 2016 10:45 am
Offline
FlightAware Member
Just the one coil for now.
Top
 Profile
PostPosted: Mon Dec 12, 2016 11:14 am
Offline
FlightAware Member
I believe the 2 elements will perforform something around 30% more messages than a 1/4 ground plane, not that great.
Top
 Profile
PostPosted: Mon Dec 12, 2016 1:16 pm
Offline
FlightAware Member
Preliminary results show the Collinear J pole is not as good as my 9 element CoCo. I will add another 2 elements tomorrow.
Here is my CoCo for comparison
What is the length of the wire used to make the coil? Is it half wavelength or something else?
Top
 Profile
PostPosted: Mon Dec 12, 2016 2:37 pm
Offline
FlightAware Member
Fairly good results, 70% of the message rate of a 4 elements CoCo
This article trys to explain the black magic behind these antennas and was the main source of my findings. Search for a section named "Wire length in Collinear J-Pole Phasing Coil"
http://www.hamradio.me/antennas/improvi ... per-j.html
I've tested 18turns / 60mm and the gain decreased significantly, meaning poorer SWR. Will try another sizes to see if is there any improvement, but so far this was the best results I got.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
