Post new topic Reply to topic  [ 9 posts ]
Author Message
 Post subject: Specifically assigning SDR (not just by device #)
PostPosted: Sun Jul 16, 2017 2:50 pm
Offline
FlightAware Member
usafpride - FlightAware user avatar
I have reason to put 2 SDR dongles on the same rPi, but I need to absolutely guarantee which dongle is which (2 different antennas, 2 different uses). I've read that you can write to the NVRAM of the dongles, but haven't been able to figure it out.
Does anyone have any experience with this?
Top
 Profile
 Post subject: Re: Specifically assigning SDR (not just by device #)
PostPosted: Sun Jul 16, 2017 2:59 pm
Offline
FlightAware Staff
obj - FlightAware user avatar
You can use rtl_eeprom to write a serial number. see "man rtl_eeprom" or e.g. http://manpages.ubuntu.com/manpages/tru ... rom.1.html
dump1090 will accept a serial number as the device index
Top
 Profile
PostPosted: Sun Jul 16, 2017 4:41 pm
Offline
FlightAware Member
Have you done this? and will it work on the Orange FA dongle?
Top
 Profile
PostPosted: Sun Jul 16, 2017 8:34 pm
Offline
FlightAware Staff
Sure, I've used rtl_eeprom in the past. Not recently. Should work on a prostick, it's the same chipset.
Top
 Profile
PostPosted: Sun Jul 16, 2017 9:48 pm
Offline
FlightAware Member
"Use at your own risk, especially -w!"
Top
 Profile
PostPosted: Mon Jul 17, 2017 3:05 am
Offline
FlightAware Member
PRO STICK (Orange)
pi@raspberrypi:~ $ sudo systemctl stop dump1090-mutability
pi@raspberrypi:~ $ rtl_eeprom -s 00001001
Found 1 device(s):
0: Generic RTL2832U
Current configuration:
__________________________________________
Vendor ID: 0x0bda
Product ID: 0x2832
Manufacturer: Realtek
Product: RTL2832UFA
Serial number: 00001000
Serial number enabled: yes
IR endpoint enabled: no
Remote wakeup enabled: no
New configuration:
Vendor ID: 0x0bda
Product ID: 0x2832
Product: RTL2832UFA
Serial number: 00001001
Write new configuration to device [y/n]? y
Configuration successfully written.
Please replug the device for changes to take effect.
Top
 Profile
PostPosted: Mon Jul 17, 2017 6:48 am
Offline
FlightAware Member
Got it. Where in dump1090-fa do you set the ID up (I see nothing in the help file other than device #)? Or is there a way to tell the Pi that x serial number is always device 0/1/2/x?
Top
 Profile
PostPosted: Mon Jul 17, 2017 8:38 am
Offline
FlightAware Staff
The dump1090 "device index" will try to match on serial numbers too so you can just configure it there.
("piaware-config rtlsdr-device-index" if you're using a piaware sdcard image)
Top
 Profile
PostPosted: Tue Jul 18, 2017 5:15 am
Offline
FlightAware Member
Thanks. Last question, is there a log/debug that shows the actual negotiation using the serial number? I know Murphy (from the famous Murphy's Law) and his cousins will show up when I am out of town and mess things up if I don't confirm this.
Top
 Profile
Who is online
Users browsing this forum: 41south, Google [Bot], matth20man, RenatoRibeiro, speedy314 and 1 guest
Search for:
Jump to:
